[petsc-users] CPU utilization during GPU solver
David Fuentes fuentesdt at gmail.com
Sat Nov 17 14:05:03 CST 2012
Thanks Jed.
I was trying to run it in dbg mode to verify if all significant parts of
the solver were running on the GPU and not on the CPU by mistake.
I cant pinpoint what part of the solver is running on the CPU. When I run
top while running the solver there seems to be ~800% CPU utilization
that I wasn't expecting. I cant tell if i'm slowing things down
by transferring between CPU/GPU on accident?
thanks again,
df
On Sat, Nov 17, 2012 at 1:49 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Please read the large boxed message about debugging mode.
> (Replying from phone so can't make it 72 point blinking red, sorry.)
> On Nov 17, 2012 1:41 PM, "David Fuentes" <fuentesdt at gmail.com> wrote:
>> thanks Matt,
>> My log summary is below.
>> ***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r
>> -fCourier9' to print this document            ***
>> ---------------------------------------------- PETSc Performance Summary:
>> ./FocusUltraSoundModel on a gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg named
>> SCRGP2 with 1 processor, by fuentes Sat Nov 17 13:35:06 2012
>> Using Petsc Release Version 3.3.0, Patch 4, Fri Oct 26 10:46:51 CDT 2012
>>                          Max       Max/Min        Avg      Total
>> Time (sec):           3.164e+01      1.00000   3.164e+01
>> Objects:              4.100e+01      1.00000   4.100e+01
>> Flops:                2.561e+09      1.00000   2.561e+09  2.561e+09
>> Flops/sec:            8.097e+07      1.00000   8.097e+07  8.097e+07
>> Memory:               2.129e+08      1.00000              2.129e+08
>> MPI Messages:         0.000e+00      0.00000   0.000e+00  0.000e+00
>> MPI Message Lengths:  0.000e+00      0.00000   0.000e+00  0.000e+00
>> MPI Reductions:       4.230e+02      1.00000
>> Flop counting convention: 1 flop = 1 real number operation of type
>> (multiply/divide/add/subtract)
>>                             e.g., VecAXPY() for real vectors of length N
>> --> 2N flops
>>                             and VecAXPY() for complex vectors of length N
>> --> 8N flops
>> Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages
>> ---  -- Message Lengths --  -- Reductions --
>>                         Avg     %Total     Avg     %Total   counts
>> %Total     Avg         %Total   counts   %Total
>>  0:      Main Stage: 3.1636e+01 100.0%  2.5615e+09 100.0%  0.000e+00
>> 0.0%  0.000e+00        0.0%  4.220e+02  99.8%
>> See the 'Profiling' chapter of the users' manual for details on
>> interpreting output.
>> Phase summary info:
>>    Count: number of times phase was executed
>>    Time and Flops: Max - maximum over all processors
>>                    Ratio - ratio of maximum to minimum over all processors
>>    Mess: number of messages sent
>>    Avg. len: average message length
>>    Reduct: number of global reductions
>>    Global: entire computation
>>    Stage: stages of a computation. Set stages with PetscLogStagePush()
>> and PetscLogStagePop().
>>       %T - percent time in this phase         %f - percent flops in this
>> phase
>>       %M - percent messages in this phase     %L - percent message
>> lengths in this phase
>>       %R - percent reductions in this phase
>>    Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time
>>       #                          WARNING!!!                    #
>>       #   This code was compiled with a debugging option,      #
>>       #   To get timing results run ./configure                #
>>       #   using --with-debugging=no, the performance will      #
>>       #   be generally two or three times faster.              #
>> Event                Count      Time (sec)     Flops
>>         --- Global ---  --- Stage ---   Total
>>                    Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len
>> Reduct  %T %f %M %L %R  %T %f %M %L %R Mflop/s
>> --- Event Stage 0: Main Stage
>> ComputeFunction       52 1.0 3.9104e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> 3.0e+00  1  0  0  0  1   1  0  0  0  1     0
>> VecDot                50 1.0 3.2072e-02 1.0 9.70e+07 1.0 0.0e+00 0.0e+00
>> 0.0e+00  0  4  0  0  0   0  4  0  0  0  3025
>> VecMDot               50 1.0 1.3100e-01 1.0 9.70e+07 1.0 0.0e+00 0.0e+00
>> 0.0e+00  0  4  0  0  0   0  4  0  0  0   741
>> VecNorm              200 1.0 9.7943e-02 1.0 3.88e+08 1.0 0.0e+00 0.0e+00
>> 0.0e+00  0 15  0  0  0   0 15  0  0  0  3963
>> VecScale             100 1.0 1.3496e-01 1.0 9.70e+07 1.0 0.0e+00 0.0e+00
>> 0.0e+00  0  4  0  0  0   0  4  0  0  0   719
>> VecCopy              150 1.0 4.8405e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
>> VecSet               164 1.0 2.9707e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
>> VecAXPY               50 1.0 3.2194e-02 1.0 9.70e+07 1.0 0.0e+00 0.0e+00
>> 0.0e+00  0  4  0  0  0   0  4  0  0  0  3014
>> VecWAXPY              50 1.0 2.9040e-01 1.0 4.85e+07 1.0 0.0e+00 0.0e+00
>> 0.0e+00  1  2  0  0  0   1  2  0  0  0   167
>> VecMAXPY             100 1.0 5.4555e-01 1.0 1.94e+08 1.0 0.0e+00 0.0e+00
>> 0.0e+00  2  8  0  0  0   2  8  0  0  0   356
>> VecPointwiseMult     100 1.0 5.3003e-01 1.0 9.70e+07 1.0 0.0e+00 0.0e+00
>> 0.0e+00  2  4  0  0  0   2  4  0  0  0   183
>> VecScatterBegin       53 1.0 1.8660e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> VecReduceArith       101 1.0 6.9973e-02 1.0 1.96e+08 1.0 0.0e+00 0.0e+00
>> 0.0e+00  0  8  0  0  0   0  8  0  0  0  2801
>> VecReduceComm         51 1.0 1.0252e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> VecNormalize         100 1.0 1.8565e-01 1.0 2.91e+08 1.0 0.0e+00 0.0e+00
>> 0.0e+00  1 11  0  0  0   1 11  0  0  0  1568
>> VecCUSPCopyTo        152 1.0 5.8016e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> VecCUSPCopyFrom      201 1.0 6.0029e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> MatMult              100 1.0 6.8465e-01 1.0 1.25e+09 1.0 0.0e+00 0.0e+00
>> 0.0e+00  2 49  0  0  0   2 49  0  0  0  1825
>> MatAssemblyBegin       3 1.0 3.3379e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> MatAssemblyEnd         3 1.0 2.7767e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> MatZeroEntries         1 1.0 2.0346e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> MatCUSPCopyTo          3 1.0 1.4056e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> SNESSolve              1 1.0 2.2094e+01 1.0 2.56e+09 1.0 0.0e+00 0.0e+00
>> 3.7e+02 70100  0  0 88  70100  0  0 89   116
>> SNESFunctionEval      51 1.0 3.9031e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> SNESJacobianEval      50 1.0 1.3191e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> 0.0e+00  4  0  0  0  0   4  0  0  0  0     0
>> SNESLineSearch        50 1.0 6.2922e+00 1.0 1.16e+09 1.0 0.0e+00 0.0e+00
>> 5.0e+01 20 45  0  0 12  20 45  0  0 12   184
>> KSPGMRESOrthog        50 1.0 4.0436e-01 1.0 1.94e+08 1.0 0.0e+00 0.0e+00
>> 5.0e+01  1  8  0  0 12   1  8  0  0 12   480
>> KSPSetUp              50 1.0 2.1935e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> 1.5e+01  0  0  0  0  4   0  0  0  0  4     0
>> KSPSolve              50 1.0 1.3230e+01 1.0 1.40e+09 1.0 0.0e+00 0.0e+00
>> 3.2e+02 42 55  0  0 75  42 55  0  0 75   106
>> PCSetUp               50 1.0 1.9897e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> 4.9e+01  6  0  0  0 12   6  0  0  0 12     0
>> PCApply              100 1.0 5.7457e-01 1.0 9.70e+07 1.0 0.0e+00 0.0e+00
>> 4.0e+00  2  4  0  0  1   2  4  0  0  1   169
>> Memory usage is given in bytes:
>> Object Type          Creations   Destructions     Memory  Descendants'
>> Mem.
>> Reports information only for process 0.
>>            Container     2              2         1096     0
>>               Vector    16             16    108696592     0
>>       Vector Scatter     2              2         1240     0
>>               Matrix     1              1     96326824     0
>>     Distributed Mesh     3              3      7775936     0
>>      Bipartite Graph     6              6         4104     0
>>            Index Set     5              5      3884908     0
>>    IS L to G Mapping     1              1      3881760     0
>>                 SNES     1              1         1268     0
>>       SNESLineSearch     1              1          840     0
>>               Viewer     1              0            0     0
>>        Krylov Solver     1              1        18288     0
>>       Preconditioner     1              1          792     0
>> Average time to get PetscTime(): 9.53674e-08
>> #PETSc Option Table entries:
>> -da_vec_type cusp
>> -dm_mat_type seqaijcusp
>> -ksp_monitor
>> -log_summary
>> -pc_type jacobi
>> -snes_converged_reason
>> -snes_monitor
>> #End of PETSc Option Table entries
>> Compiled without FORTRAN kernels
>> Compiled with full precision matrices (default)
>> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
>> sizeof(PetscScalar) 8 sizeof(PetscInt) 4
>> Configure run at: Fri Nov 16 08:40:52 2012
>> Configure options: --with-clanguage=C++ --with-mpi-dir=/usr
>> --with-shared-libraries --with-cuda-arch=sm_20 --CFLAGS=-O0 --CXXFLAGS=-O0
>> --CUDAFLAGS=-O0 --with-etags=1 --with-mpi4py=0
>> --with-blas-lapack-lib="[/opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libmkl_rt.so,/opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libmkl_intel_thread.so,/opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libmkl_core.so,/opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libiomp5.so]"
>> --download-blacs --download-superlu_dist --download-triangle
>> --download-parmetis --download-metis --download-mumps --download-scalapack
>> --with-cuda=1 --with-cusp=1 --with-thrust=1
>> --with-cuda-dir=/opt/apps/cuda/4.2//cuda --with-sieve=1
>> --download-exodusii=yes --download-netcdf --with-boost=1
>> --with-boost-dir=/usr --download-fiat=yes --download-generator
>> --download-scientificpython --with-matlab=1 --with-matlab-engine=1
>> --with-matlab-dir=/opt/MATLAB/R2011a
>> Libraries compiled on Fri Nov 16 08:40:52 2012 on SCRGP2
>> Machine characteristics:
>> Linux-2.6.32-41-server-x86_64-with-debian-squeeze-sid
>> Using PETSc directory: /opt/apps/PETSC/petsc-3.3-p4
>> Using PETSc arch: gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg
>> Using C compiler: /usr/bin/mpicxx -O0 -g   -fPIC   ${COPTFLAGS} ${CFLAGS}
>> Using Fortran compiler: /usr/bin/mpif90  -fPIC -Wall -Wno-unused-variable
>> -g   ${FOPTFLAGS} ${FFLAGS}
>> Using include paths:
>> -I/opt/apps/PETSC/petsc-3.3-p4/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/include
>> -I/opt/apps/PETSC/petsc-3.3-p4/include
>> -I/opt/apps/cuda/4.2//cuda/include
>> -I/opt/apps/PETSC/petsc-3.3-p4/include/sieve
>> -I/opt/MATLAB/R2011a/extern/include -I/usr/include
>> -I/opt/apps/PETSC/petsc-3.3-p4/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/cbind/include
>> -I/opt/apps/PETSC/petsc-3.3-p4/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/forbind/include
>> -I/usr/include/mpich2
>> Using C linker: /usr/bin/mpicxx
>> Using Fortran linker: /usr/bin/mpif90
>> Using libraries:
>> -Wl,-rpath,/opt/apps/PETSC/petsc-3.3-p4/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/lib
>> -L/opt/apps/PETSC/petsc-3.3-p4/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/lib
>> -lpetsc
>> -ltriangle -lX11 -lpthread -lsuperlu_dist_3.1 -lcmumps -ldmumps -lsmumps
>> -lzmumps -lmumps_common -lpord -lparmetis -lmetis -lscalapack -lblacs
>> -Wl,-rpath,/opt/apps/cuda/4.2//cuda/lib64 -L/opt/apps/cuda/4.2//cuda/lib64
>> -lcufft -lcublas -lcudart -lcusparse
>> -Wl,-rpath,/opt/MATLAB/R2011a/sys/os/glnxa64:/opt/MATLAB/R2011a/bin/glnxa64:/opt/MATLAB/R2011a/extern/lib/glnxa64
>> -L/opt/MATLAB/R2011a/bin/glnxa64 -L/opt/MATLAB/R2011a/extern/lib/glnxa64
>> -leng -lmex -lmx -lmat -lut -licudata -licui18n -licuuc
>> -Wl,-rpath,/opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib
>> -L/opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib -lmkl_rt -lmkl_intel_thread
>> -lmkl_core -liomp5 -lexoIIv2for -lexodus -lnetcdf_c++ -lnetcdf
>> -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.4.3
>> -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -lmpichf90 -lgfortran -lm -lm
>> -lmpichcxx -lstdc++ -lmpichcxx -lstdc++ -ldl -lmpich -lopa -lpthread -lrt
>> -lgcc_s -ldl
>> On Sat, Nov 17, 2012 at 11:02 AM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Sat, Nov 17, 2012 at 10:50 AM, David Fuentes <fuentesdt at gmail.com>
>>> wrote:
>>> > Hi,
>>> > I'm using petsc 3.3p4
>>> > I'm trying to run a nonlinear SNES solver on GPU with gmres and jacobi
>>> PC
>>> > using VECSEQCUSP and MATSEQAIJCUSP datatypes for the rhs and jacobian
>>> matrix
>>> > respectively.
>>> > When running top I still see significant CPU utilization (800-900 %CPU)
>>> > during the solve ? possibly from some multithreaded operations ?
>>> > Is this expected ?
>>> > I was thinking that since I input everything into the solver as a CUSP
>>> > datatype, all linear algebra operations would be on the GPU device from
>>> > there and wasn't expecting to see such CPU utilization during the
>>> solve ?
>>> > Do I probably have an error in my code somewhere ?
>>> We cannot answer performance questions without -log_summary
>>>    Matt
>>> > Thanks,
>>> > David
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which
>>> their experiments lead.
>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121117/a8c748af/attachment.html>
