[petsc-users] Report progress to an external driver code
Dominik Szczerba dominik at itis.ethz.ch
Tue Nov 13 06:21:14 CST 2012
Thanks a lot for your suggestion.
No I did not mean just KSP progress, but the overall progress from my solver.
I have solved it now by offering a custom function pointer that the
downstream user can provide. This function is then called several
times during the computation and calculates the overall progress.
Dominik
On Mon, Nov 12, 2012 at 6:29 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>      If you are calling KSP directly you can write a custom monitor and set it with KSPMonitorSet(), similarly with SNES write a custom monitor and set it with SNESMonitorSet() or both. These monitors can do anything you like, print to a GUI, communicate via a unix socket to another process, etc.
>    Barry
>    The logging stuff is really not intended for this purpose.
> On Nov 12, 2012, at 4:50 AM, Dominik Szczerba <dominik at itis.ethz.ch> wrote:
>> Hi,
>> I need to report progress (0-100%, which I compute myself) of my Petsc
>> solver code to an external driver code that is controlling my solver.
>> I had a look at the many Petsc logging functions and examples but I am
>> still not sure which way to go. I tried PetscLogStage, but it does not
>> seem to display any information during the execution, and I also do
>> not see a way this information could be sent somewhere and accessed by
>> e.g. registering a custom (static) function used to inform the
>> downstream code what the solver is doing at the moment. The most
>> trivial solution that I have found is to output a message like [STATUS
>> 50%], which could be intercepted in the downstream code by overwriting
>> PetscVFPrintf, but it sounds rather inelegant. I would be very glad to
>> receive some pointers where to start looking.
>> Regards,
>> Dominik
