[petsc-users] Wrapping PetscFPrintf
Sun Nov 11 09:18:56 CST 2012
On Sun, Nov 11, 2012 at 8:35 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> But I found a very promising solution: PetscVFPrintf. It solves my
>> problem for my own Print function. But I do not seem to find a
>> corresponding function for synchronized printing (PetscFPrintf). Any
>> clues how to use PetscVFPrintf for synchronized printing please?
> PetscSynchronizedVFPrintf is missing, but should be added.
There is actually an implementation issue. The current version dynamically
sizes the local buffer by calling PetscVSNPrintf repeatedly, increasing the
buffer size as necessary [1]. We cannot offer a PetscSynchronizedVFPrintf()
without either (a) truncating sufficient long strings or (b) using
vasprintf() which is a GNU extension. You can roll your own loop over
va_start, vsnprintf(), va_end, resize-array-if-necessary and then call
PetscSynchronizedPrintf(), or, if you can use the GNU extension, just use
asprintf().
[1] The implementation is hideous, leaking memory quadratic in the input
size for large data volume.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121111/92241a0b/attachment.html>
