[petsc-users] How to use multigrid?
A.L. Siahaan als88 at cam.ac.uk
Fri Nov 9 12:13:11 CST 2012
When you mentioned that ML is implemented in a more "native" way than
Hypre, did you mean that PCML is not exactly a PETSc's interface to the
Trilinos ML ?
On Nov 9 2012, Mark F. Adams wrote:
>yes
>On Nov 9, 2012, at 12:26 PM, "A.L. Siahaan" <als88 at cam.ac.uk> wrote:
>> Thank's a lot, Mark ! What does 'native' mean here ? That it is PETSc's
>> built-in and not interface ?
>> Antony
>>>> Of all algebraic multigrid implemented or interfaced in PETSc, i.e.
>>>> BoomerAMG (PCHypre), ML(PCML), and PCGAMG("agg"), what is the order of
>>>> the cost (memory) to set up the preconditioner (setting nullspace etc)
>>> Not a simple question. ML and GAMG use very similar algorithms and ML
>>> is implemented in a more "native" way than hypre (GAMG is completely
>>> native). GAMG/ML are probably better for elasticity, hypre is great for
>>> 2D low order discretizations of Laplacian, and it is a very hardened
>>> implementation. hypre is not native so there are some things that don't
>>> work as well.
>>>> Regards,
>>>> Antony
