[petsc-users] Conjugate transpose for rectangular complex matrices
Thu Nov 8 12:58:34 CST 2012
   We need the entire error message and stack frames to see what happened. Cut and paste all the output and send it to petsc-maint at mcs.anl.gov
On Nov 8, 2012, at 11:55 AM, Ganesh Hegde <ghegde at purdue.edu> wrote:
> Hi,
> I have been using the MatHermitianTranspose method to get the conjugate transpose for complex square matrices.
> To optimize code, I needed to make my matrix rectangular.
> Doing so and using the same function call gave me the following error with code 60:
> 'Nonconforming object sizes'
> I then decided to do this in two steps - get the conjugate of the rectangular complex matrix and then call MatTranspose.
> The error still persists. Can you suggest any alternatives to this problem?
> Regards,
> Ganesh
