[petsc-users] CFD code with immersed boundary
Arun Kamath arun.kamath.m at gmail.com
Wed Nov 7 14:18:46 CST 2012
My previous post gave a completely wrong meaning I guess, with a
missing punctuation.
Matt, you got it right. I wanted to know how do I deal with the ghost
cells arising from the physical domain, when I am using an
unstructured grid. Since DA works with structured grids only, as far
as I understood.
Thanks.
Are you saying that you have an unstructured grid with ghost cells, and you
would like PETSc to produce
a Vec of the correct size and Mat with the correct preallocation for that
grid and discretization, just as DA
does for structured grids?
      Matt
On Wed, Nov 7, 2012 at 9:31 AM, Arun Kamath <arun.kamath.m at
gmail.com <https://lists.mcs.anl.gov/mailman/listinfo/petsc-users>>
wrote:
>* Hi!*>* I am working with a CFD code  where I need to solve the Poisson Pressure*>* equation. We solve a two phase flow problem which results in a jump in the*>* coefficients and a non symmetric system.*>**>* The boundary conditions are fulfilled using immersed boundary method ghost*>* cells at the solid boundaries of the domain.*>* I read about the DAs to deal with the boundary conditions, but they are*>* applicable to only "IJK" matrices as per my understanding.*>* So when I am using the "Aij" (CSR) matrix, how would you suggest I deal*>* with the ghost cells of the physical domain while forming the matrix and*>* the vector?*>**
>* Thanks a lot.*>* --*>* Arun Kamath*>* PhD Stipendiat*>* NTNU, Trondheim*>**>
Arun Kamath
PhD Stipendiat
NTNU, Trondheim
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121107/61de9e57/attachment.html>
