[petsc-users] unable to set type "agg" in GAMG preconditioner
A.L. Siahaan als88 at cam.ac.uk
Wed Nov 7 10:23:57 CST 2012
On Nov 7 2012, Mark F. Adams wrote:
>I've pushed a fix into petsc-dev.
Thank's a lot, Mark !
>> And what is the default type if I don't set to either "agg" or "geo" ?
>'agg' is the default.
In the previous version (before you pushed a fix), when I didn't set
anything, it worked fine. Only when I set it specifically to "agg" did the
problem occur.
Antony
