[petsc-users] Some change in 3.3 about --with-x?
w_ang_temp w_ang_temp at 163.com
Wed Nov 7 07:41:42 CST 2012
Hello,
    I get a problem when configuring about the command "--with-x=1" in version 3.3.
The command "./configure --with-mpi-dir=/home/ubu/soft/mpich2/ --download-f-blas-lapack=1 --with-x=1 --with-hypre=1 --download-hypre=1"
is ok in version 3.2 but makes an error in 3.3:"Could not locate X *development* package. Perhaps its not installed".
I do not find the detail about the change in "Documentation/Changes". Do I need "--with-x=1 --download-x=1"?
The configure.log:
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
  File "./config/configure.py", line 311, in petsc_configure
    framework.configure(out = sys.stdout)
  File "/home/ubu/soft/petsc/petsc-3.3-p4/config/BuildSystem/config/framework.py", line 933, in configure
    child.configure()
  File "/home/ubu/soft/petsc/petsc-3.3-p4/config/PETSc/packages/X.py", line 263, in configure
    self.executeTest(self.configureLibrary)
  File "/home/ubu/soft/petsc/petsc-3.3-p4/config/BuildSystem/config/base.py", line 115, in executeTest
    ret = apply(test, args,kargs)
  File "/home/ubu/soft/petsc/petsc-3.3-p4/config/PETSc/packages/X.py", line 247, in configureLibrary
    raise RuntimeError("Could not locate X *development* package. Perhaps its not installed")
Thanks.
        Jim
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121107/295ed86b/attachment-0001.html>
