[petsc-users] Wrong answers from KSPSolve
NAN ZHAO zhaonanavril at gmail.com
Tue Nov 6 11:38:49 CST 2012
Dear all,
I tried to solve a 18 by 18 linear system with KSPsolve, the right hand
vector and matrix can be found in the file in the attachment. The right
hand vector has several zeros and the corresponding row in the matrix only
have values in diagonal, I expected zero at this element but got -1 for the
answer. I am using the tutorial code
in  petsc-3.2-p6/src/ksp/ksp/examples/tutorials/ex1.c as an example to
assemble the matrix and vector and to solve the system. I also include the
code in the attachment. I am working on a solution now but have run out of
ideas.
If you have any hint on the potential solution to this problems let me know.
Nan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121106/b76eaf7b/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121106/b76eaf7b/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121106/b76eaf7b/attachment-0003.obj>
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121106/b76eaf7b/attachment-0001.c>
