[petsc-users] thread model
Mohammad Mirzadeh mirzadeh at gmail.com
Sun Nov 4 13:43:03 CST 2012
>  As I said before you have to set the core affinity for OpenMP through
> environment variables.
Well I tried 'export GOMP_CPU_AFFINITY="0-7" ' before running the code but
that did not help. I'm using gcc. Am I doing it wrong.
i) Which example are you running? Please send output of -log_summary.
This was my own  code. Will try on some of the examples and report back.
> ii) Only the vector and a few matrix operations are threaded currently.
> There are no threaded preconditioners yet.
Aah! That may actually be it. I'm using hypre and I think that is not
threaded. Will try with -pc_type none to see if that makes any difference.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121104/2ade71b8/attachment.html>
