[petsc-users] Are there any functions (objects ) for scattering and gathering 64-bit integers just like VecScatter for PetscScalar?
Fri Nov 2 21:25:53 CDT 2012
On Fri, 2 Nov 2012, Fande Kong wrote:
> But I have tested code on mvapich.
> It also has bugs, when the finite mesh is larger than 50M.
Can you confirm this problem you see is with newer mvapich2 not some
old mvapich1? I see the current release is: MVAPICH2 1.8.1
[MVAPICH is based on mpich - so presumably onesided stuff should work
with it.]
Satish
