[petsc-users] Are there any functions (objects ) for scattering and gathering 64-bit integers just like VecScatter for PetscScalar?
Fande Kong fd.kong at siat.ac.cn
Fri Nov 2 18:01:31 CDT 2012
Thank you very much. I don't want to use one-sided communication. It's
horrible with countless bugs in current mpi implementations.
On Fri, Nov 2, 2012 at 4:41 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Read the issue I linked. You can watch it to be notified of action. It
> should be obvious that I've known about the Open MPI problem for a long
> time. You can also ask them to fix their bug. They _should_ fix it
> regardless.
> On Nov 2, 2012 5:24 PM, "Fande Kong" <fd.kong at siat.ac.cn> wrote:
>> I got it. You still didn't fix the bugs that I encountered a few months
>> ago. All current MPI implementations couldn't support the function
>> MPI_Accumulate or others well with one-sided communication when data is
>> large.  Thus, I have to hack your code (PetscSF) to use point-point
>> communications. But  I find it's not so easy.
>> don't you want to change to use point-point?
>> On Fri, Nov 2, 2012 at 4:04 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>> The current implementation uses one-sided because that was a natural. I
>>> need a solid day to implement without one-sided. As stated in the issue I
>>> posted, this is necessary because Open MPI data types are broken.
>>> On Fri, Nov 2, 2012 at 5:01 PM, Fande Kong <fd.kong at siat.ac.cn> wrote:
>>>> did you remove horrible one-side communication? and did you make some
>>>> tests with using 64-bit integers?
>>>> On Fri, Nov 2, 2012 at 3:50 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>>>> I am using PetscSF for this. You would need petsc-dev and the current
>>>>> implementation requires an MPI with non-broken data types.
>>>>> https://bitbucket.org/petsc/petsc-dev/issue/9/implement-petscsf-without-one-sided
>>>>> Here are some (dated) notes about the communication model.
>>>>> http://59A2.org/files/StarForest.pdf
>>>>> On Fri, Nov 2, 2012 at 4:41 PM, Fande Kong <fd.kong at siat.ac.cn> wrote:
>>>>>> Hi all,
>>>>>> 64-bit integers just like VecScatter for PetscScalar? The VecScatter is
>>>>>> very useful for managing communication for PetscScalar. But I can't find
>>>>>> any functions or objects to do similar things for PetscInt. Any suggestions?
>>>>>> Regards,
>>>>>> Fande Kong
>>>>>> ShenZhen Institutes of Advanced Technology
>>>>>> Chinese Academy of Sciences
>>>> Fande Kong
>> Fande Kong
Fande Kong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121102/0f912873/attachment-0001.html>
