[petsc-users] Saving graphical matrix structure to a file
    Habbal, Feras (353G-Affiliate)
    Feras.A.Habbal at jpl.nasa.gov
    Wed Mar 21 18:02:50 CDT 2012
Ok, no problem. Thank you for your assistance!
From: Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>>
Reply-To: PETSc users list <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
Date: Wed, 21 Mar 2012 15:43:07 -0700
Subject: Re: [petsc-users] Saving graphical matrix structure to a file
On Wed, Mar 21, 2012 at 5:31 PM, Habbal, Feras (353G-Affiliate) <Feras.A.Habbal at jpl.nasa.gov<mailto:Feras.A.Habbal at jpl.nasa.gov>> wrote:
I tried using the commands from the previous post:
xwd | xpr -device ps > foo.ps<http://foo.ps>
That worked fine for me when I made movies this way. I'm not sure what else to recommend.
   Matt
But the output was bizarre: reversed and had some artifacts.
I can certainly use the mac screen capture tools, but I am needing an automated capability to capture the structure of several matrices (~1000) during a run.
Feras
Date: Wed, 21 Mar 2012 15:14:39 -0700
On Wed, Mar 21, 2012 at 5:11 PM, Habbal, Feras (353G-Affiliate) <Feras.A.Habbal at jpl.nasa.gov<mailto:Feras.A.Habbal at jpl.nasa.gov>> wrote:
Hello,
I am trying to save the matrix structure visualization from (-mat_view_draw) to a file (jpeg, ps, or anything else).
I saw the post: "help in capturing matrix patterns to files,"
The easiest thing to do is use screen capture for that window.
    Matt
but adding the options did not work for me:
 –mat_view_draw –draw_type ps
I have been trying to do this with the example file: ksp/examples/tutorials/ex1.c
I included "petscdraw.h"
$ mpiexec ex1 -mat_view_draw -draw_type ps
[0]PETSC ERROR: --------------------- Error Message ------------------------------------
[0]PETSC ERROR: Unknown type. Check for miss-spelling or missing external package needed for type
 seehttp://www.mcs.anl.gov/petsc/petsc-as/documentation/installation.html#external!
[0]PETSC ERROR: Unknown PetscDraw type given: ps!
[0]PETSC ERROR: ------------------------------------------------------------------------
[0]PETSC ERROR: Petsc Release Version 3.2.0, Patch 3, Fri Sep 30 10:28:33 CDT 2011
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR: ex1 on a macosx-gn named habbalf.jpl.nasa.gov<http://habbalf.jpl.nasa.gov> by habbalf Wed Mar 21 14:56:30 2012
[0]PETSC ERROR: Libraries linked from /Users/habbalf/issm/trunk-jpl/externalpackages/petsc/install/lib
[0]PETSC ERROR: Configure run at Tue Mar  6 11:39:23 2012
[0]PETSC ERROR: Configure options --prefix=/Users/habbalf/issm/trunk-jpl/externalpackages/petsc/install --PETSC_DIR=/Users/habbalf/issm/trunk-jpl/externalpackages/petsc/src --PETSC_ARCH=macosx-gnu --with-mpi-dir=/Users/habbalf/issm/trunk-jpl/externalpackages/mpich2/install --with-debugging=1 --download-c2html=1 --with-shared-libraries=0 --download-mumps=yes --download-scalapack=yes --download-blacs=yes --download-blas=yes --download-plapack=yes --download-parmetis=yes --download-f-blas-lapack=yes
[0]PETSC ERROR: PetscDrawSetType() line 147 in src/sys/draw/interface/drawreg.c
[0]PETSC ERROR: PetscDrawSetFromOptions() line 278 in src/sys/draw/interface/drawreg.c
[0]PETSC ERROR: PetscViewerDrawGetDraw() line 109 in src/sys/viewer/impls/draw/drawv.c
[0]PETSC ERROR: MatView_SeqAIJ_Draw() line 752 in src/mat/impls/aij/seq/aij.c
[0]PETSC ERROR: MatView_SeqAIJ() line 781 in src/mat/impls/aij/seq/aij.c
[0]PETSC ERROR: MatView() line 757 in src/mat/interface/matrix.c
[0]PETSC ERROR: MatView_Private() line 4881 in src/mat/interface/matrix.c
[0]PETSC ERROR: MatAssemblyEnd() line 4965 in src/mat/interface/matrix.c
[0]PETSC ERROR: main() line 89 in src/ksp/ksp/examples/tutorials/ex1.c
application called MPI_Abort(MPI_COMM_WORLD, 86) - process 0
Thank you for your assistance,
Feras
-- Norbert Wiener
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120321/0c33ff25/attachment.htm>
