[petsc-users] about parallel preconditioned matrix-free gmres
RenZhengYong renzhengyong at gmail.com
Sat Jun 30 06:39:16 CDT 2012
Hi, Matt,
Thanks a lot for your suggestions. I will try it today and once I had
specific questions, I mightbe needs your helps.
Best wishes
Zhengyong
On Sat, Jun 30, 2012 at 1:30 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Jun 29, 2012 at 7:25 PM, RenZhengYong <renzhengyong at gmail.com>wrote:
>> Dear Petscs,
>> Use the uniprocessor complex-value based version petsc, I recently
>> successfully make a FETI_DP domain
>> decomposition approach working for 3D electromagnetic induction (earth)
>> problem.  The number of iteration of
>> the interface problem seems to be scalable with regard to the number of
>> sub-domains.
>> To do this, I had two subroutines for petsc
>> (1) int mat_vec_product_interface_problem(Mat A, Vec X, Vec Y) for
>> matrix-free GMRES solver
>> (2) int preconditioner_mat_vec(PC pc,Vec X,Vec Y) for shell
>> preconditioner.
>> Now, I want to solve the interface problem by paralleled GMRES solver so
>> that I can solve real large-scale problems.  Could you please tell me the
>> easiest way to accomplish it. Which specific data structures of petsc
>> should be used.  I have been using Petsc for 3.5 years, I really want to
>> have a try the real MPI-based Petsc.
> 1) The solver logic should be parallel already since it only uses calls to
> Vec or Mat functions. The problems will be
>     in building data structures.
> 2) It looks like your two items above are the things to be parallelized
> 3) Decide how to partition the problem
> 4) Use VecScatter() to communicate data along the interface of your
> partitions
> I don't think we can give better advice than that without more specific
> questions. Note that there is
> a current effort to put BDDCinto PETSc. You can see it in petsc-dev, as
> PCBDDC.
>   Thanks,
>     Matt
>> Thanks in advance.
>> Have a nice weekeed
>> Zhengyong
>> Zhengyong Ren
>> AUG Group, Institute of Geophysics
>> Department of Geosciences, ETH Zurich
>> NO H 47 Sonneggstrasse 5
>> CH-8092, Zürich, Switzerland
>> Tel: +41 44 633 37561
>> e-mail: zhengyong.ren at aug.ig.erdw.ethz.ch
>> Gmail: renzhengyong at gmail.com
> experiments lead.
> -- Norbert Wiener
Zhengyong Ren
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120630/976a10d0/attachment.html>
