[petsc-users] Réf. : Re: Réf. : Re: Avoiding malloc overhead for unstructured finite element meshes
Thomas DE-SOZA thomas.de-soza at edf.fr
Fri Jun 29 04:10:42 CDT 2012
Or does it mean that in the preallocation we have to take care of the
values that come from the stash of another processor even if they are
added to preexisting entries on the process ?
You only have to allocate the entries once, but there are entries that
were not preallocated at all.
We haven't been able to narrow the problem in our preallocation yet but by
preallocating the entries for the incoming stash values (even if it should
not be needed as you pointed out) we're now overestimating the nnz and
performance is OK (log attached for those curious) : no more mallocs in
MatSetValues.
Many thanks for your help !
Thomas
jedbrown at mcs.anl.gov
Envoyé par : petsc-users-bounces at mcs.anl.gov
28/06/2012 19:33
Veuillez répondre à petsc-users
        Pour :  petsc-users at mcs.anl.gov
        cc :    nicolas.sellenet at edf.fr, (ccc : Thomas DE-SOZA/A/EDF/FR)
        Objet : Re: [petsc-users]       Réf. : Re: Avoiding malloc overhead for
On Thu, Jun 28, 2012 at 9:29 AM, Thomas DE-SOZA <thomas.de-soza at edf.fr> wrote:
Since 9900 coefficients were uneeded, we had first thought that enough
room was preallocated.
>From what you're telling us, I understand that we may have given an
overall size which is large enough to contain the diagonal block but whose
nnz line by line is not correct hence the mallocs. Is that correct ?
Unlikely, extra space is dynamically allocated in bigger chunks so there
is usually some left over when mallocs are needed in MatSetValues. You
should be careful to get nnz correct, but that is not the only problem
here.
Ce message et toutes les pièces jointes (ci-après le 'Message') sont établis à l'intention exclusive des destinataires et les informations qui y figurent sont strictement confidentielles. Toute utilisation de ce Message non conforme à sa destination, toute diffusion ou toute publication totale ou partielle, est interdite sauf autorisation expresse.
Si vous n'êtes pas le destinataire de ce Message, il vous est interdit de le copier, de le faire suivre, de le divulguer ou d'en utiliser tout ou partie. Si vous avez reçu ce Message par erreur, merci de le supprimer de votre système, ainsi que toutes ses copies, et de n'en garder aucune trace sur quelque support que ce soit. Nous vous remercions également d'en avertir immédiatement l'expéditeur par retour du message.
Il est impossible de garantir que les communications par messagerie électronique arrivent en temps utile, sont sécurisées ou dénuées de toute erreur ou virus.
____________________________________________________
This message and any attachments (the 'Message') are intended solely for the addressees. The information contained in this Message is confidential. Any use of information contained in this Message not in accord with its purpose, any dissemination or disclosure, either whole or partial, is prohibited except formal approval.
If you are not the addressee, you may not copy, forward, disclose or use any part of it. If you have received this message in error, please delete it and all copies from your system and notify the sender immediately by return message.
E-mail communication cannot be guaranteed to be timely secure, error or virus-free.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120629/b470fa40/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120629/b470fa40/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120629/b470fa40/attachment-0001.obj>
