[petsc-users] Data decomposition in PETsc for Poisson solver
Michele Rosso mrosso at uci.edu
Tue Jun 26 12:37:39 CDT 2012
I need some help to use the PETSc library inside my Fortran 95 code.
My goal is to solve a symmetric linear system that derives from the
finite difference discretization
of the Poisson equation. I will use the preconditioned conjugate method.
I am mostly interested in how to decompose my data among the different
processes.
In particular:
1) Since my code already implements the 2D-decomposition, would it be
best to build the matrix with the  DMDA object type, DA object type
      or the regular Mat type?
2) After inserting values into a vector/matrix, PETSc performs any
needed message passing of nonlocal components, thus the values locally
contained on a process  may be communicated to another process.  How can
I revert this at the end of the computation, that is, how can I be sure
that the local solution vector contains the values associated to the
grid nodes contained into the hosting process?
Thank you,
Michele
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120626/2c28f2a7/attachment.html>
