[petsc-users] MatView and PetscViewerASCIIOpen problem when cpu > 1
TAY wee-beng zonexo at gmail.com
Mon Jun 25 16:18:30 CDT 2012
On 25/6/2012 3:40 PM, Jed Brown wrote:
> On Mon, Jun 25, 2012 at 12:25 PM, TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>> wrote:
>     Hi,
>     I'm trying to use DMDA to solve my linear equation.
>     It works fine with 1 cpu. However, problem arise when cpu > 1. I
>     get segmentation error.
>     I tried to use  MatView and PetscViewerASCIIOpen to view my matrix
>     to check if it's correct.
>     It works with 1 cpu. However now, it shows the error below when I
>     use 2 cpu.
>     [0]PETSC ERROR: --------------------- Error Message
>     [0]PETSC ERROR: Argument out of range!
>     [0]PETSC ERROR: ASCII matrix output not allowed for matrices with
>     more than 1024 rows, use binary format instead.
>     You can override this restriction using -mat_ascii_output_large.!
>      To view the matrix, my command is :
>     call PetscViewerASCIIOpen(MPI_COMM_WORLD,"A_semi.txt",viewer,ierr)
>     call MatView(A_semi,viewer,ierr)
>     call PetscViewerDestroy(viewer,ierr)
>     I tried to use -mat_ascii_output_large but then it just hangs
>     there forever.
> It may just be very slow.
I tried using 1 cpu and I got it in a few minutes. Should i take a long
time if I use 2 cpu? Also, I got the error:
[0]PETSC ERROR: ASCII matrix output not allowed for matrices with more
It doesn't happen when I use 1 cpu. Is it normal to get it when I use 2 cpu?
I also tried to use :
call MatView(A_semi,PETSC_VIEWER_STDOUT_WORLD ,ierr)
but the same error occurs. It just hangs there when 2 cpu are used.
> Why do you need ASCII? Writing anything large in ASCII is hopeless.
> Please use binary.
>     I create the matrix using DMCreateMatrix. I don't have to use
>     MatCreateAIJ, right?
>     Also, I check for the ierr value when I use MatSetValuesStencil to
>     ensure there's no error. Btw There's no problem with VecView.
>     So how can I view the matrix?
>     Thank you!
>     Yours sincerely,
>     TAY wee-beng
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120625/86002c81/attachment.html>
