[petsc-users] replacing Schur complement in pcfieldsplit
Wed Jun 20 10:04:12 CDT 2012
On Wed, Jun 20, 2012 at 9:00 AM, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
> In order to implement SIMPLE-type preconditioners for the
> incompressible Navier-Stokes equations (Elman e.a. JCP 227, 2008)
> using the PCFieldSplit framework, it looks like I need to replace
> inv(A00) by some cheap approximation
> 1) in the Schur complement
When you have a Schur FS, the '0' solver is this approximation.
> 2) in the L and/or U of the LDU factorization
You can use whatever PC you want for the solver mentioned above.
> 3) while keeping A00 in the D
I think what you want here is -pc_fieldsplit_real_diagonal.
I would be really nice to make a PETSc example that did SIMPLE. I was
going to do this, but if you do it first, I will put it in.
   Matt
> What would be the best way?
> dr. ir. Christiaan Klaij
> CFD Researcher
> Research & Development
> E mailto:C.Klaij at marin.nl
> T +31 317 49 33 44
> MARIN
> 2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands
> T +31 317 49 39 11, F +31 317 49 32 45, I www.marin.nl
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120620/e3c8b0a9/attachment.html>
