[petsc-users] strange linking problem
Juha Jäykkä juhaj at iki.fi
Wed Jun 20 03:52:55 CDT 2012
Dear list,
I have a strange linking problem with libpetsc.so. After running 'make
PETSC_DIR=$(pwd) PETSC_ARCH=linux-gnu-cxx-opt all', the library looks like
this:
~> nm linux-gnu-cxx-opt/lib/libpetsc.so|grep SAMappingInitializePackage
000000000048b4fe T SAMappingInitializePackage
                 U _Z26SAMappingInitializePackagePKc
00000000006060b0 r _ZZ26SAMappingInitializePackageE8__func__
And, of course, make install will not fix it and therefore make test fails and
all programs using it fail.
Any ideas what could be causing this? It looks to me as if part of the code
was compiled with mpicxx and got the names mangled in C++ fashion (hence
_Z26SAMappingInitializePackagePKc) but for other parts, mpicc was used (hence
no mangling and SAMappingInitializePackage). But why?
I have --CC=mpicc.openmpi-gcc-1.4.4 --CXX=mpicxx.openmpi-gcc-1.4.4 on the
congfigure line, so the compilers should be fine. The complete configure line
is:
./configure --prefix=${PREFIX}/petsc --with-shared-libraries --with-
debugging=0 --with-fortran=0 --with-clanguage=C++ --with-dynamic-loading --
with-c-support --useThreads=0 --with-mpi-shared=1 --with-hdf5=1 --with-gnu-
compilers=1 --with-vendor-compilers=\[pathscale,intel\] --with-hdf5-
dir=${HDF5_DIR} --with-petsc-arch=linux-gnu-cxx-opt --CC=mpicc.openmpi-
and is the exact same line as I have used on numerous other machines, too.
Any ideas what's wrong or how to debug this?
Cheers,
Juha
Desc: This is a digitally signed message part.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120620/e0ddaffc/attachment.pgp>
