[petsc-users] make test failed
Yifei Li yifli82 at gmail.com
Tue Jun 19 13:48:13 CDT 2012
Thanks! Problem fixed.  -Yifei
On Tue, Jun 19, 2012 at 2:27 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Ok - I think the sources were extracted with a windows tool - and not
> cygwin 'tar' - so the scripts [which got extracted in dos format] are
> misbehaving.
> sbalay at ps3 ~/petsc33/src/ksp/ksp/examples/tutorials
> $ unix2dos.exe /home/sbalay/petsc33/bin/mpiexec.uni
> unix2dos: converting file /home/sbalay/petsc33/bin/mpiexec.uni to DOS
> format ...
> $ /home/sbalay/petsc33/bin/mpiexec.uni -n 1 ./ex2
> /home/sbalay/petsc33/bin/mpiexec.uni: line 4: syntax error near unexpected
> token `elif'
> 'home/sbalay/petsc33/bin/mpiexec.uni: line 4: `elif  [ $2 =  "1" ]; then
> $ dos2unix.exe /home/sbalay/petsc33/bin/mpiexec.uni
> dos2unix: converting file /home/sbalay/petsc33/bin/mpiexec.uni to Unix
> format ...
> Norm of error 0.000156044 iterations 6
> Satish
> On Tue, 19 Jun 2012, Barry Smith wrote:
> >   Please run
> > /bin/sh --version
> > and send the output
> > On Jun 18, 2012, at 5:21 PM, Yifei Li wrote:
> > > Hi all,
> > > I got the following error when running 'make test':
> > > Using PETSC_DIR=/home/liyi0000/petsc-3.3-p1 and
> PETSC_ARCH=arch-mswin-c-debug
> > > Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1
> MPI process
> > > See http://www.mcs.anl.gov/petsc/documentation/faq.html
> > > /home/liyi0000/petsc-3.3-p1/bin/mpiexec.uni: line 4: syntax error near
> unexpected token 'elif'
> > > 'home/liyi0000/petsc-3.3-p1/bin/mpiexec.uni: line 4: 'elif [ $2 = "1"
> ]; then
> > > Can someone help me with this? Thanks
> > > Yifei
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120619/f741ae3e/attachment.html>
