[petsc-users] DOF in DMDACreate3d and staggered grid
TAY wee-beng zonexo at gmail.com
Mon Jun 18 21:21:15 CDT 2012
On 18/6/2012 9:52 PM, Matthew Knepley wrote:
> On Mon, Jun 18, 2012 at 7:30 PM, TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>> wrote:
>     On 17/6/2012 2:33 PM, Jed Brown wrote:
>>     On Sun, Jun 17, 2012 at 7:26 AM, TAY wee-beng <zonexo at gmail.com
>>         On 16/6/2012 9:24 AM, Jed Brown wrote:
>>>         It depends how you want to solve the problem. I usually
>>>         group all dofs together. There is a 2D Stokes+Thermodynamics
>>>         example in SNES ex30 (or 31?).
>>         I tried to understand ex30. I have some questions since it's
>>         in C and I'm using to Fortran programming.
>>     This looks about right, see src/dm/examples/tutorials/ex11f90.F.
>     I tried to build and run ex11f90 in linux. However, it's not working:
>     I have attached the run and valgrind output:
> It appears to be a problem with your MPI.
>    Matt
Is there anyway to solve this problem? I'm running on a cluster using
openmpi 1.5.3 and I've no admin rights.
>     run output:
>     [wtay at hpc12:tutorials]$ ./ex11f90
>     [0]PETSC ERROR:
>     [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>     Violation, probably memory access out of range
>     [0]PETSC ERROR: Try option -start_in_debugger or
>     -on_error_attach_debugger
>     [0]PETSC ERROR: or see
>     http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSC
>     ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X
>     to find memory corruption errors
>     [0]PETSC ERROR: likely location of problem given in stack below
>     [0]PETSC ERROR: ---------------------  Stack Frames
>     [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>     available,
>     [0]PETSC ERROR:       INSTEAD the line number of the start of the
>     function
>     [0]PETSC ERROR:       is given.
>     [0]PETSC ERROR: --------------------- Error Message
>     [0]PETSC ERROR: Signal received!
>     [0]PETSC ERROR:
>     [0]PETSC ERROR: Petsc Development HG revision:
>     f3b998b41b349e16d47fe42b0e223d3462737e05  HG Date: Fri Jun 15
>     17:50:32 2012 -0500
>     [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>     [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>     [0]PETSC ERROR: See docs/index.html for manual pages.
>     [0]PETSC ERROR:
>     [0]PETSC ERROR: ./ex11f90 on a petsc-3.3 named hpc12 by wtay Tue
>     Jun 19 03:22:52 2012
>     [0]PETSC ERROR: Libraries linked from
>     /home/wtay/Lib/petsc-3.3-dev_shared_debug/lib
>     [0]PETSC ERROR: Configure run at Sun Jun 17 16:51:29 2012
>     [0]PETSC ERROR: Configure options
>     --with-mpi-dir=/opt/openmpi-1.5.3/
>     --with-blas-lapack-dir=/opt/intelcpro-11.1.059/mkl/lib/em64t/
>     --with-debugging=1 --download-hypre=1
>     --prefix=/home/wtay/Lib/petsc-3.3-dev_shared_debug
>     --known-mpi-shared=1 --with-shared-libraries
>     [0]PETSC ERROR:
>     [0]PETSC ERROR: User provided function() line 0 in unknown
>     directory unknown file
>     MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
>     with errorcode 59.
>     NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>     You may or may not see output from other processes, depending on
>     exactly when Open MPI kills them.
>     valgrind output:
>     ==6027== Memcheck, a memory error detector
>     ==6027== Copyright (C) 2002-2011, and GNU GPL'd, by Julian Seward
>     et al.
>     ==6027== Using Valgrind-3.7.0 and LibVEX; rerun with -h for
>     copyright info
>     ==6027== Command: ex11f90
>     ==6027==
>     ==6027== Invalid read of size 8
>     ==6027==    at 0xA60148D: _wordcopy_fwd_dest_aligned (in
>     /lib64/libc-2.12.so <http://libc-2.12.so>)
>     ==6027==    by 0xA5FB11D: __GI_memmove (in /lib64/libc-2.12.so
>     ==6027==    by 0xA6027DB: argz_insert (in /lib64/libc-2.12.so
>     ==6027==    by 0x95CAF25: lt_argz_insert (ltdl.c:1679)
>     ==6027==    by 0x95CB7D0: foreachfile_callback (ltdl.c:1718)
>     ==6027==    by 0x95CB4F1: foreach_dirinpath (ltdl.c:710)
>     ==6027==    by 0x95CB580: lt_dlforeachfile (ltdl.c:1865)
>     ==6027==    by 0x95DB999: mca_base_component_find
>     (mca_base_component_find.c:301)
>     ==6027==    by 0x95DC4B0: mca_base_components_open
>     (mca_base_components_open.c:128)
>     ==6027==    by 0x95F7CE7: opal_paffinity_base_open
>     (paffinity_base_open.c:112)
>     ==6027==    by 0x95C39FE: opal_init (opal_init.c:307)
>     ==6027==    by 0x95815A4: orte_init (orte_init.c:78)
>     ==6027==  Address 0xb39d9a8 is 40 bytes inside a block of size 43
>     alloc'd
>     ==6027==    at 0x4C267BA: malloc (vg_replace_malloc.c:263)
>     ==6027==    by 0x95CA358: lt__malloc (lt__alloc.c:54)
>     ==6027==    by 0x95CB751: foreachfile_callback (ltdl.c:1764)
>     ==6027==    by 0x95432AE: ompi_mpi_init (ompi_mpi_init.c:350)
>     ==6027==    by 0x955938F: PMPI_Init (pinit.c:84)
>     ==6027==
>     ==6027== Syscall param writev(vector[...]) points to uninitialised
>     byte(s)
>     ==6027==    at 0xA65692B: writev (in /lib64/libc-2.12.so
>     ==6027==    by 0xC9A2C56: mca_oob_tcp_msg_send_handler
>     (oob_tcp_msg.c:249)
>     ==6027==    by 0xC9A417C: mca_oob_tcp_peer_send (oob_tcp_peer.c:204)
>     ==6027==    by 0xC9A67FC: mca_oob_tcp_send_nb (oob_tcp_send.c:167)
>     ==6027==    by 0xC3953B5: orte_rml_oob_send (rml_oob_send.c:136)
>     ==6027==    by 0xC3955FF: orte_rml_oob_send_buffer
>     (rml_oob_send.c:270)
>     ==6027==    by 0xCDB1E87: modex (grpcomm_bad_module.c:573)
>     ==6027==    by 0x95436F1: ompi_mpi_init (ompi_mpi_init.c:682)
>     ==6027==    by 0x8AB4FF4: MPI_INIT (pinit_f.c:75)
>     ==6027==    by 0x50ED97E: petscinitialize_ (zstart.c:299)
>     ==6027==    by 0x40881C: MAIN__ (ex11f90.F:43)
>     ==6027==  Address 0xed30cd1 is 161 bytes inside a block of size
>     256 alloc'd
>     ==6027==    at 0x4C268B2: realloc (vg_replace_malloc.c:632)
>     ==6027==    by 0x95C4F22: opal_dss_buffer_extend
>     (dss_internal_functions.c:63)
>     ==6027==    by 0x95C5A64: opal_dss_copy_payload
>     (dss_load_unload.c:164)
>     ==6027==    by 0x95A1246: orte_grpcomm_base_pack_modex_entries
>     (grpcomm_base_modex.c:861)
>     ==6027==    by 0xCDB1E3C: modex (grpcomm_bad_module.c:563)
>     ==6027==    by 0x4087AB: main (in
>     /home/wtay/Codes/petsc-dev/src/dm/examples/tutorials/ex11f90)
>     ==6027==
>     ==6027==    at 0x50FC6D8: vecview_ (zvectorf.c:56)
>     ==6027==    by 0x408A05: MAIN__ (ex11f90.F:56)
>     ==6027==    by 0xEE1CC2F: ???
>     ==6027==    by 0xEE5A0AF: ???
>     ==6027==    by 0x6F5C9F: ??? (in
>     ==6027==    by 0x4962FF: ??? (in
>     ==6027==    by 0x7FEFFFC13: ???
>     ==6027==  Address 0xfffffffffffffeb8 is not stack'd, malloc'd or
>     (recently) free'd
>     ==6027== /
>>         Supposed I have a field - u,v,w,p, so in order to use them, I
>>         do the following:
>>         type field
>>         real u,v,w,p
>>         end type field
>>         type(field), pointer :: field1(:,:,:)    -> make a derived
>>         variable/
>>         Also:
>>         Vec field_local,field_global
>>         call DMDACreate3d with dof = 4
>>         call DMCreateGlobalVector(da, field_local,ierr)
>>         call DMCreateLocalVector(da,field_global,ierr)
>>         call DMGetLocalVector(da, field_local,ierr)    ->    To
>>         insert values
>>         call DMDAVecGetArrayF90(da, field_local,field1,ierr)
>>         do k = zs, zs + zm - 1
>>         do j = ys, ys + ym -1
>>             do i = xs, xs + xm - 1
>>                 field1(i,j,k)%u = ...     ->    evaluate u,v,w,p etc
>>             end do
>>         end do
>>         call DMDAVecRestoreArrayF90(da,field_local,field1,ierr)
>>         call
>>         DMLocalToGlobalBegin(da,field_local,INSERT_VALUES,field_global,ierr)
>>         call
>>         DMLocalToGlobalEnd(da,field_local,INSERT_VALUES,field_global,ierr)
>>         call DMRestoreLocalVector(da,field_local,ierr)/
>>         Is this the correct way?
>>         Also, supposed I now want to solve my u,v,w momentum eqns.
>>         Although they're not coupled together, I believe it's faster
>>         if I assemble them into 1 big matrix.
>>         So for Ax = b, x =
>>         (field(1,1,1)%u,field(1,1,1)%v,field(1,1,1)%w,field(2,1,1)%u....
>>         For b, do I duplicate a Vec similar to field_local?
>>         What about matrix A? Do I use the MatSetValuesStencil?
>>     Yes
>>         Lastly, the type field contains u,v,w and p. However, I'm
>>         only solving u,v,w. Do I have to skip some values or use
>>         identity matrix to solve it?
>>     Why not make a field that contains only u,v,w. I don't see what
>>     you're trying to do.
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120618/5fac0ca6/attachment-0001.html>
