[petsc-users] DOF in DMDACreate3d and staggered grid
TAY wee-beng zonexo at gmail.com
Sun Jun 17 07:26:52 CDT 2012
On 16/6/2012 9:24 AM, Jed Brown wrote:
> It depends how you want to solve the problem. I usually group all dofs
> together. There is a 2D Stokes+Thermodynamics example in SNES ex30 (or
> 31?).
I tried to understand ex30. I have some questions since it's in C and
I'm using to Fortran programming.
Supposed I have a field - u,v,w,p, so in order to use them, I do the
following:
type field
real u,v,w,p
end type field
type(field), pointer :: field1(:,:,:)    -> make a derived variable/
Also:
Vec field_local,field_global
call DMDACreate3d with dof = 4
call DMCreateGlobalVector(da, field_local,ierr)
call DMCreateLocalVector(da,field_global,ierr)
call DMGetLocalVector(da, field_local,ierr)    ->    To insert values
call DMDAVecGetArrayF90(da, field_local,field1,ierr)
do k = zs, zs + zm - 1
do j = ys, ys + ym -1
     do i = xs, xs + xm - 1
         field1(i,j,k)%u = ...     ->    evaluate u,v,w,p etc
     end do
end do
call DMDAVecRestoreArrayF90(da,field_local,field1,ierr)
call DMLocalToGlobalBegin(da,field_local,INSERT_VALUES,field_global,ierr)
call DMLocalToGlobalEnd(da,field_local,INSERT_VALUES,field_global,ierr)
call DMRestoreLocalVector(da,field_local,ierr)/
Is this the correct way?
Also, supposed I now want to solve my u,v,w momentum eqns. Although
they're not coupled together, I believe it's faster if I assemble them
into 1 big matrix.
So for Ax = b, x =
(field(1,1,1)%u,field(1,1,1)%v,field(1,1,1)%w,field(2,1,1)%u.... )
For b, do I duplicate a Vec similar to field_local?
What about matrix A? Do I use the MatSetValuesStencil?
Lastly, the type field contains u,v,w and p. However, I'm only solving
u,v,w. Do I have to skip some values or use identity matrix to solve it?
Thanks!
> On Jun 16, 2012 8:11 AM, "TAY wee-beng" <zonexo at gmail.com
> <mailto:zonexo at gmail.com>> wrote:
>     Hi,
>     I'm abit unclear about dof used in DMDACreate3d. If I have u,v,w
>     for my CFD code, does it mean that I should have dof = 3? Or can i
>     create 3 local/global vector using DMCreateGlobalVector and
>     DMCreateLocalVector to define u,v,w?
>     Does it matter if I'm using staggered grids? Also, if I am only
>     using PETSc for u,v,w (and not pressure, which uses HYPRE), does
>     it mean a difference?
>     I remember there 's an example using staggered grid somewhere but
>     I can't find it now. May I know which PETSc 's example it is?
>     Thanks!
>     Yours sincerely,
>     TAY wee-beng
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120617/aae65435/attachment.html>
