[petsc-users] -log_summary for MatMult
Fri Jun 15 09:14:28 CDT 2012
On Fri, Jun 15, 2012 at 9:18 PM, Alexander Grayver
<agrayver at gfz-potsdam.de>wrote:
> On 15.06.2012 14:46, Matthew Knepley wrote:
> On Fri, Jun 15, 2012 at 8:31 PM, Alexander Grayver <
> agrayver at gfz-potsdam.de> wrote:
>>  Matt,
>> According to that code:
>> 486: *PetscErrorCode MatMult_MPIDense(Mat mat,Vec xx,Vec yy)*487: {488:   Mat_MPIDense   *mdn = (Mat_MPIDense*)mat->data;
>> 492:  VecScatterBegin(mdn->Mvctx,xx,mdn->lvec,INSERT_VALUES,SCATTER_FORWARD);493:   VecScatterEnd(mdn->Mvctx,xx,mdn->lvec,INSERT_VALUES,SCATTER_FORWARD);494:   MatMult_SeqDense(mdn->A,mdn->lvec,yy);495:   return(0);496: }
>> Each process has its own local copy of the vector?
>  I am not sure what your point is. VecScatter is just an interface that
> has many implementations.
> I'm trying to estimate the amount of data needs to be communicated over
> all processes during this operation.
> In debugger I see VecScatter from the code above reduces to the
> MPI_Allgatherv and results in (assuming vector is distributed uniformly)
> bytes_send_received = num_of_proc * ((num_of_proc - 1) * vec_size_local) *
> 2 * sizeof(PetscScalar)
> Does that look reasonable?
This is not really a useful exercise, since
  a) PETSc does not currently have an optimized parallel dense
implementation
  b) We are implementing an Elemental interface this summer. You can try it
out in petsc-dev
  c) Elemental is much more efficient than our simple implementation, and
uses a unique
      approach to communication (all reductions)
I would take the comp+comm estimates from Jack's slides on Elemental
   Matt
> Thanks.
> Regards,
> Alexander
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120615/13ee2058/attachment-0001.html>
