[petsc-users] Broken link for FFC
Andy Ray Terrel andy.terrel at gmail.com
Fri Jun 15 06:33:01 CDT 2012
Just change www.fenics.org to www.fenicsproject.org, but 0.3.3 is terribly
old.
-- Andy
On Fri, Jun 15, 2012 at 1:29 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Jun 15, 2012 at 7:03 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> On Fri, Jun 15, 2012 at 5:17 AM, Ajay Rawat <ajay.rawat83 at gmail.com>wrote:
>>> Dear Dev
>>> While configuring the PETSc with --download-ffc options it throws an
>>> error
>>> Downloaded package FFC from:
>>> http://www.fenics.org/pub/software/ffc/v0.3/ffc-0.3.3.tar.gz is not a
>>> tarball.
>>> [or installed python cannot process compressed files]
>> This server has not existed for a while (a troll threatened legal action
>> over the name, IIRC). Matt will have to check whether new versions of FFC
>> work with his code. It's not used by "mainstream" PETSc.
> Yes, I will have to update this link. The reason this package exists is
> that I was using it to generate CUDA
> code in a restricted case. We now have a more general routine however, so
> it is not being used.
>    Matt
>>> * If you are behind a firewall - please fix your proxy and rerun
>>> ./configure
>>>   For example at LANL you may need to set the environmental variable
>>> http_proxy (or HTTP_PROXY?) to  http://proxyout.lanl.gov
>>> * Alternatively, you can download the above URL manually, to
>>> /yourselectedlocation/ffc-0.3.3.tar.gz
>>>   and use the configure option:
>>>   --download-ffc=/yourselectedlocation/ffc-0.3.3.tar.gz
>>> I guess the link is not correct.
>>> I have one more doubt regarding ffc. I see no examples regarding how to
>>> use ffc inside PETSc, or it is used inside fenics.
>>> With regards,
>>> Ajay Rawat
>>> Kalpakkam, IGCAR
>>> Save Himalayas....
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120615/d9f4b003/attachment-0001.html>
