[petsc-users] Database key for KSP_Solve
Thu Jun 14 15:25:04 CDT 2012
On Fri, Jun 15, 2012 at 4:22 AM, Xuefeng Li <li at loyno.edu> wrote:
> On Fri, 15 Jun 2012, Matthew Knepley wrote:
>  On Fri, Jun 15, 2012 at 3:08 AM, Xuefeng Li <li at loyno.edu> wrote:
>>  Are there any database keys to control the number of
>>> times KSP_Solve() is called? Where is the loop that
>>> calls KSP_Solve?  The key -ksp_max_it does not seem
>>> to affect it.
>> Then this option did not reach the solver. You may have set a prefix.
>> Run with -snes_max_it 1 -ksp_max_it 1 -snes_view to see what you are
>> actually doing.
>>  The key -ksp_max_it affects the iteration number
> for the (main) ksp object for SNES, but not the ksp
> object for PC.
1) Why do you have a KSP object underneath your PC?
2) Since you do -sub_ksp_max_it 1 would be the default
> I observed yet another (related) problem. Even though
> I set KSP type to be GMRES, the type is GMRES only on
> the coarse level of the DMMG; the type changes to MG
> on all finer levels. How do I control KSP and PC on
> finer levels of DMMG?
3) Don't use DMMG, it has been replaced with something much simpler in the
latest release
    There you can give -mg_levels_ksp_type
   Matt
> Regards,
> --Xuefeng Li, (504)865-3340(phone)
>  Like floating clouds, the heart rests easy
>  Like flowing water, the spirit stays free
>       http://www.loyno.edu/~li/home
>  New Orleans, Louisiana (504)865-2051(fax)
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120615/3a1905ba/attachment.html>
