[petsc-users] MatSetBlockSize no longer works after MatCreateSeqAIJ
Geoffrey Irving irving at naml.us
Wed Jun 13 19:55:30 CDT 2012
Hello,
The following code used to work, but breaks after upgrading to 3.3:
    CHECK(MatCreateSeqAIJ(comm,3*n,3*n,0,scalar_view(nnz).data(),&mat));
    CHECK(MatSetBlockSize(mat,3));
The error follows.  Presumably MatSetBlockSize got more strict, and I
need to break the single MatCreateSeqAIJ into multiple lines (matrix
creation followed by preallocation) in order to insert MatSetBlockSize
in the middle.  What are the correct functions to call?
Geoffrey
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Arguments are incompatible!
[0]PETSC ERROR: Cannot change block size 1 to 3!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Release Version 3.3.0, Patch 0, Tue Jun  5
14:20:42 CDT 2012
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: Unknown Name on a darwin named tile.local by irving
Wed Jun 13 17:51:34 2012
[0]PETSC ERROR: Libraries linked from
/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_math_petsc/petsc/work/destroot/opt/local/lib/petsc/lib
[0]PETSC ERROR: Configure run at Wed Jun 13 12:11:05 2012
[0]PETSC ERROR: Configure options --prefix=/opt/local --with-python
--with-debugging=0 --with-c-support=1 --with-c++-support=1
--with-pic=fPIC --with-shared-libraries=0 --with-mpi=1
--PETSC_ARCH=darwin
--prefix=/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_math_petsc/petsc/work/destroot/opt/local/lib/petsc
--with-cc=/opt/local/bin/openmpicc
--with-cxx=/opt/local/bin/openmpicxx
--with-mpiexec=/opt/local/bin/openmpiexec
--with-lapack-lib=/usr/lib/liblapack.dylib
--with-blas-lib=/usr/lib/libblas.dylib --download-umfpack=1
--download-ml --download-metis --download-parmetis --download-blacs
--download-scalapack --download-mumps --download-ptscotch
--with-fc=/opt/local/bin/openmpif90 --LIBS=-lstdc++
[0]PETSC ERROR:
[0]PETSC ERROR: PetscLayoutSetBlockSize() line 460 in
/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_math_petsc/petsc/work/petsc-3.3-p0/src/vec/vec/impls/mpi/pmap.c
[0]PETSC ERROR: MatSetBlockSize() line 6691 in
/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_math_petsc/petsc/work/petsc-3.3-p0/src/mat/interface/matrix.c
[0]PETSC ERROR:  !
[0]PETSC ERROR:
14:20:42 CDT 2012
[0]PETSC ERROR:
--PETSC_ARCH=darwin
[0]PETSC ERROR:
[0]PETSC ERROR: PetscSolidMat() line 114 in petsc/ksp.cpp
