[petsc-users] compilation error of petsc-3.2-p7 with metis
Sun Jun 10 21:13:43 CDT 2012
On Sun, Jun 10, 2012 at 9:10 PM, Kyunghoon Lee
<aeronova.mailing at gmail.com>wrote:
> Hi all,
> I configured petsc-3.2-p7 with the following options:
> ./configure
> --prefix=/Users/aeronova/Development/local/lib64/petsc/petsc-3.2-p7
> --download-mpich=1 --download-blacs=1 --download-parmetis=1
> --download-metis=1 --download-scalapack=1 --download-mumps=1
> --download-umfpack=1 --with-clanguage=C++
Possibly a stale package file in externalpackages/.
But you should upgrade to petsc-3.3 before bothering more with this. It has
metis-5.0 which fixes many critical bugs.
> , which threw an error saying
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> details):
> Error running make on Metis: Could not execute "cd
> /Users/aeronova/Development/local/src/petsc-3.2-p7/externalpackages/metis-4.0.3
> && make clean && make library && make minstall && make clean":
> In configure.log, there are some messages related to metis:
> TEST configureLibrary from
> config.packages.metis(/Users/aeronova/Development/local/src/petsc-3.2-p7/config/BuildSystem/config/package.py:417)
> TESTING: configureLibrary from
> config.packages.metis(config/BuildSystem/config/package.py:417)
>   Find an installation and check if it can work with PETSc
>         Checking for a functional metis
>                 Looking for METIS in directory starting with metis
>                 Found a copy of METIS in metis-4.0.3
>                   Pushing language C
>                   Popping language C
> Have to rebuild metis,
> /Users/aeronova/Development/local/src/petsc-3.2-p7/externalpackages/metis-4.0.3/make.inc
> /Users/aeronova/Development/local/src/petsc-3.2-p7/arch-darwin-cxx-debug/conf/metis
>                         Compiling & installing Metis; this may take
> several minutes
> sh: cd
> Executing: cd
> sh: (cd Lib ; make clean )
> rm -f *.o
> (cd Programs ; make clean )
> rm -f *.o
> (cd Test ; make clean )
> rm -f *.o
> details):
> rm -f *.o
> rm -f *.o
> rm -f *.o
> make: *** No rule to make target `library'.  Stop.
>   File "./config/configure.py", line 283, in petsc_configure
>     framework.configure(out = sys.stdout)
>   File
> "/Users/aeronova/Development/local/src/petsc-3.2-p7/config/BuildSystem/config/framework.py",
> line 925, in configure
>     child.configure()
>   File
> "/Users/aeronova/Development/local/src/petsc-3.2-p7/config/BuildSystem/config/package.py",
> line 506, in configure
>     self.executeTest(self.configureLibrary)
>   File
> "/Users/aeronova/Development/local/src/petsc-3.2-p7/config/BuildSystem/config/base.py",
> line 115, in executeTest
>     ret = apply(test, args,kargs)
>   File
> line 433, in configureLibrary
>     for location, directory, lib, incl in self.generateGuesses():
>   File
> line 228, in generateGuesses
>     d = self.checkDownload(1)
>   File
> line 313, in checkDownload
>     return self.getInstallDir()
>   File
> line 183, in getInstallDir
>     return os.path.abspath(self.Install())
>   File
> "/Users/aeronova/Development/local/src/petsc-3.2-p7/config/BuildSystem/config/packages/metis.py",
> line 64, in Install
>     raise RuntimeError('Error running make on Metis: '+str(e))
> I think the error was raised by missing target 'library,' but I'm not sure
> how to fix it.  I'd appreciate any suggestions.
> K. Lee.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120610/e65e8ef5/attachment-0001.html>
