[petsc-users] multigrid implementation problem
Sun Jun 10 20:49:12 CDT 2012
On Sun, Jun 10, 2012 at 8:32 PM, Nakib Haider Protik <nprot048 at uottawa.ca>wrote:
> Here's the code with the changes you suggested followed by the terminal
> output:
>    KSPCreate(PETSC_COMM_WORLD, &ksp);
>    //KSPCreate(PETSC_COMM_WORLD, &cksp);
>    //KSPCreate(PETSC_COMM_WORLD, &uksp);
>    //KSPCreate(PETSC_COMM_WORLD, &dksp);
>    //KSPSetType(ksp, KSPGMRES);
>    //KSPSetType(cksp, KSPGMRES);
>    //KSPSetType(uksp, KSPGMRES);
>    //KSPSetType(dksp, KSPGMRES);
>    KSPGetPC(ksp, &pc);
>    //KSPGetPC(cksp, &pc);
>    //KSPGetPC(uksp, &pc);
>    //KSPGetPC(dksp, &pc);
>    KSPSetFromOptions(ksp);
>    PCSetType(pc, PCMG);
>    PCMGSetLevels(pc, 2, PETSC_NULL);
>    PCMGSetType(pc, PC_MG_MULTIPLICATIVE);
>    PCMGSetCycleType(pc, PC_MG_CYCLE_V);
>    MatDuplicate(A, MAT_COPY_VALUES, &P);
>    PCMGSetCyclesOnLevel(pc, 0, 1);
>    PCMGSetCyclesOnLevel(pc, 1, 1);
>     //PCMGGetCoarseSolve(pc, &cksp);
>    //PCMGGetSmootherDown(pc, 0,  &dksp);
>    //PCMGGetSmootherUp(pc, 1, &uksp);
>    PCMGSetInterpolation(pc, 1, P);
>    PCMGSetRestriction(pc, 1, P);
>    PCMGSetResidual(pc, 0, PCMGDefaultResidual, P);
>    PCMGSetResidual(pc, 1, PCMGDefaultResidual, P);
^^ I already explained that these lines are semantically incorrect. You are
using the matrix P in different places that do not make sense.
You have not set an operator for the smoother and you haven't set a vector.
You have to do at least one of those if you want to use the "advanced" PCMG
interface.
Before trying anything else, install petsc-3.3 and read through this
example.
http://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/examples/tutorials/ex45.c.html
Compile it and run it with
./ex45 -da_refine 3 -ksp_monitor -pc_type mg -ksp_view
Read through the output and understand what algorithm it is using.
Run with -help and look at the options starting with "-pc_mg" and
"-mg_levels".
Change the algorithm using command line parameters.
Then, and only then, consider using the low-level PCMG interface directly.
>     KSPSetOperators(ksp, A, P, SAME_NONZERO_PATTERN);
>    KSPSolve(ksp, breal, xreal_harm);
>    KSPSolve(ksp, bimag, ximag_harm);
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Null argument, when expecting valid pointer!
> [0]PETSC ERROR: Null Object: Parameter # 1!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Release Version 3.0.0, Patch 12, Tue Mar 16 23:20:08
> CDT 2010
I have asked you several times to upgrade to petsc-3.3. Please do that now,
before you write back to this list.
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: ./3dPoissonSolver-cyl-test on a linux-gnu named nakib-F82Q
> by nakib Sun Jun 10 21:30:04 2012
> [0]PETSC ERROR: Libraries linked from
> /home/nakib/petsc-3.0.0-p12/linux-gnu-c-debug/lib
> [0]PETSC ERROR: Configure run at Wed May  9 13:44:03 2012
> [0]PETSC ERROR: Configure options --with-cc=gcc --with-fc=gfortran
> --download-f-blas-lapack=1 --download-mpich=1 --with-shared=0
> [0]PETSC ERROR:
> [0]PETSC ERROR: MatGetVecs() line 7098 in src/mat/interface/matrix.c
> [0]PETSC ERROR: KSPGetVecs() line 820 in src/ksp/ksp/interface/iterativ.c
> [0]PETSC ERROR: PCSetUp_MG() line 465 in src/ksp/pc/impls/mg/mg.c
> [0]PETSC ERROR: PCSetUp() line 794 in src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: KSPSetUp() line 237 in src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: KSPSolve() line 353 in src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR:
> CDT 2010
> [0]PETSC ERROR:
> [0]PETSC ERROR:
> The code converges to the wrong solution too.
The error above is fatal, the solver is not configured correctly. You are
supposed to catch the error (you can use the CHKERRQ macro).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120610/64211ac5/attachment.html>
