[petsc-users] Options to set when solving Ax=b if matrix A changes its non-zero position at each solve
TAY wee-beng zonexo at gmail.com
Sun Jun 10 11:09:17 CDT 2012
On 10/6/2012 2:42 PM, Matthew Knepley wrote:
> On Sun, Jun 10, 2012 at 5:42 PM, TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>> wrote:
>     Hi,
>     Currently, my matrix A changes its non zero position at each time
>     step.
>     For e.g.: At a particular node, at time step = 1, I  will insert
>     values into its east, west neighbours. At time step = 2, I  will
>     insert values into its east, north neighbours. Hence, the non-zero
>     positions at each row will be different at each time step.
>     However, the max values per row will always be 5 or less.
>     Currently, after MatSetValues and MatAssemblyBegin/End, I call:
>     /call MatSetOption(A_mat,MAT_NEW_NONZERO_LOCATIONS,PETSC_TRUE,ierr)
>     call KSPSetOperators(ksp,A_mat,A_mat,DIFFERENT_NONZERO_PATTERN,ierr)
>     call KSPGetPC(ksp,pc,ierr)
>     ksptype=KSPBCGS
>     call KSPSetType(ksp,ksptype,ierr)
>     call KSPSetFromOptions(ksp,ierr)
>     call KSPSolve(ksp,b_rhs,xx,ierr)/
>     Is this sufficient and correct? If so, apart from KSPSolve,
>     MatSetValues and MatAssemblyBegin/End, can I only call the other
>     subroutines once at the 1st time step?
>     Or do I have to explicitly destroy the matrix and create a new
>     one? I think I ask this question a while ago but I can't find the
>     email now.
> After assembly the nonzero pattern is fixed. The right thing to do is
> put in explicit zeros for the rest of the stencil.
>   Matt
Just to clarify, do you mean that I create a bigger stencil and put in
explicit zeros for those which I don't need at each time step?
I realise that for my problem, instead of the original 5 non-zero
locations (east, west, north, south, center) for the stencil, I now have
4 more (east-east, west-west etc). So now I call MATCREATEAIJ with dnz +
o_nz = 9 (instead of previously 5). Is that correct?
>     Yours sincerely,
>     TAY wee-beng
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120610/2e05dddf/attachment.html>
