[petsc-users] METIS 5 in PETSc 3, 3 [not directly related to PETSc]
Tabrez Ali stali at geology.wisc.edu
Fri Jun 8 10:35:45 CDT 2012
Here it is for the 3 compilers.
GNU FC http://bpaste.net/show/31029/
Intel FC http://bpaste.net/show/QJ6k5jc52t7MGUlvrlEV/
PGI FC http://bpaste.net/show/DZzY6Re5iXMgLSHydOgJ/
On 06/08/2012 09:15 AM, John Mousel wrote:
> Attaching the Valgrind output would probably help a lot.
> On Fri, Jun 8, 2012 at 9:02 AM, Tabrez Ali <stali at geology.wisc.edu
> <mailto:stali at geology.wisc.edu>> wrote:
>     Thanks for your answer. Unfortunately its not that.
>     Based on past experience I am sure I am overlooking something very
>     simple but I cant seem to find out what. Btw METIS 4 worked fine
>     before.
>     On 06/08/2012 08:39 AM, John Mousel wrote:
>>     It's hard to tell from the info you provided, but you seem to be
>>     playing fast and loose with your type declarations. METIS is
>>     expecting real_t, which is a 32 bit real if you haven't changed
>>     the definition in metis.h. I know this has caused me problems in
>>     the past.
>>     On Fri, Jun 8, 2012 at 7:38 AM, Tabrez Ali
>>     <stali at geology.wisc.edu <mailto:stali at geology.wisc.edu>> wrote:
>>         Sorry about a question not directly related to PETSc but has
>>         anyone here been able to use the METIS 5.0 (that PETSc
>>         3.3/dev downloads/builds) with Fortran? There has been an API
>>         change from 4 to 5 but I am having some trouble and METIS
>>         manual/forums havent been useful.
>>         For example consider the simple code (below) that partitions
>>         a two element mesh made of linear quads into two. The
>>         elements are numbered 0 1 2 3 and 1 4 5 2.It works fine with
>>         GNU FC (no valgrind errors). With Intel FC it works fines
>>         (though valgrind throws a bunch of errors). However with PGI
>>         compilers I get a segfault.
>>          program test
>>          implicit none
>>          integer, parameter   :: nels=2, nnds=6, npel=4
>>          integer              :: eptr(nels+1), nodes(nels*npel),
>>         epart(nels), npart(nnds), n
>>          integer, pointer     :: vwgt(:)=>null(), vsize(:)=>null(),
>>         mopts(:)=>null()
>>          real(8), pointer     :: tpwgts(:)=>null()
>>          eptr=(/0,4,7/)
>>          nodes=(/0,1,2,3,1,4,5,2/)
>>          call
>>         METIS_PartMeshNodal(nels,nnds,eptr,nodes,vwgt,vsize,2,tpwgts,mopts,n,epart,npart)
>>          print*, npart; print*, epart
>>         end program test
>>         According to the manual moving from METIS 4 to 5 only
>>         involves passing some additional nulls. I am not sure what I
>>         missed.
>>         http://glaros.dtc.umn.edu/gkhome/fetch/sw/metis/manual.pdf
>>         Thanks in advance.
>>         Tabrez
>     No one trusts a model except the one who wrote it; Everyone trusts an observation except the one who made it- Harlow Shapley
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120608/9d740373/attachment.html>
