[petsc-users] METIS 5 in PETSc 3, 3 [not directly related to PETSc]
John Mousel john.mousel at gmail.com
Fri Jun 8 08:39:27 CDT 2012
It's hard to tell from the info you provided, but you seem to be playing
fast and loose with your type declarations. METIS is expecting real_t,
which is a 32 bit real if you haven't changed the definition in metis.h. I
know this has caused me problems in the past.
On Fri, Jun 8, 2012 at 7:38 AM, Tabrez Ali <stali at geology.wisc.edu> wrote:
> Sorry about a question not directly related to PETSc but has anyone here
> been able to use the METIS 5.0 (that PETSc 3.3/dev downloads/builds) with
> Fortran? There has been an API change from 4 to 5 but I am having some
> trouble and METIS manual/forums havent been useful.
> For example consider the simple code (below) that partitions a two element
> mesh made of linear quads into two. The elements are numbered 0 1 2 3 and 1
> 4 5 2.It works fine with GNU FC (no valgrind errors). With Intel FC it
> works fines (though valgrind throws a bunch of errors). However with PGI
> compilers I get a segfault.
>  program test
>  implicit none
>  integer, parameter   :: nels=2, nnds=6, npel=4
>  integer              :: eptr(nels+1), nodes(nels*npel), epart(nels),
> npart(nnds), n
>  integer, pointer     :: vwgt(:)=>null(), vsize(:)=>null(),
> mopts(:)=>null()
>  real(8), pointer     :: tpwgts(:)=>null()
>  eptr=(/0,4,7/)
>  nodes=(/0,1,2,3,1,4,5,2/)
>  call METIS_PartMeshNodal(nels,nnds,**eptr,nodes,vwgt,vsize,2,**
> tpwgts,mopts,n,epart,npart)
>  print*, npart; print*, epart
> end program test
> According to the manual moving from METIS 4 to 5 only involves passing
> some additional nulls. I am not sure what I missed.
> http://glaros.dtc.umn.edu/**gkhome/fetch/sw/metis/manual.**pdf<http://glaros.dtc.umn.edu/gkhome/fetch/sw/metis/manual.pdf>
> Thanks in advance.
> Tabrez
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120608/ad6dcd5f/attachment.html>
