[petsc-users] Slow speed when using PETSc multigrid
Wed Jun 6 15:31:05 CDT 2012
On Jun 6, 2012, at 3:04 PM, TAY wee-beng wrote:
> Hi,
> I have used 3 KSP, 2 to solve momentum eqns and 1 for the multigrid. I have used
> call KSPSetOptionsPrefix(ksp,"mg_",ierr) for the multigrid.
> I run with :
> -log_summary -mg_ksp_view so as to single out the multigrid ksp, but I'm not sure if it's really working...
   Are you sure the KSPSetOptionsPrefix() is called before the KSPSetFromOptions()? It appears the prefix is not being set correctly.
   From the limited data below it is running multigrid with one level (hence you cannot expect great performance). You need to at least provide MG with a bit more information like how many levels you would like it to use.
   Barry
> Here's the output:
> ---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
> ./a.out on a petsc-3.2 named n12-50 with 4 processors, by wtay Wed Jun  6 21:57:33 2012
> Using Petsc Development HG revision: c76fb3cac2a4ad0dfc9436df80f678898c867e86  HG Date: Thu May 31 00:33:26 2012 -0500
>                         Max       Max/Min        Avg      Total
> Time (sec):           1.064e+01      1.00000   1.064e+01
> Objects:              2.700e+01      1.00000   2.700e+01
> Flops:                4.756e+08      1.00811   4.744e+08  1.897e+09
> Flops/sec:            4.468e+07      1.00811   4.457e+07  1.783e+08
> MPI Messages:         4.080e+02      2.00000   3.060e+02  1.224e+03
> MPI Message Lengths:  2.328e+06      2.00000   5.706e+03  6.984e+06
> MPI Reductions:       8.750e+02      1.00000
> Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
>                            e.g., VecAXPY() for real vectors of length N --> 2N flops
>                            and VecAXPY() for complex vectors of length N --> 8N flops
> Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
>                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
> 0:      Main Stage: 1.0644e+01 100.0%  1.8975e+09 100.0%  1.224e+03 100.0%  5.706e+03      100.0%  8.740e+02  99.9%
> See the 'Profiling' chapter of the users' manual for details on interpreting output.
> Phase summary info:
>   Count: number of times phase was executed
>   Time and Flops: Max - maximum over all processors
>                   Ratio - ratio of maximum to minimum over all processors
>   Mess: number of messages sent
>   Avg. len: average message length
>   Reduct: number of global reductions
>   Global: entire computation
>   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
>      %T - percent time in this phase         %f - percent flops in this phase
>      %M - percent messages in this phase     %L - percent message lengths in this phase
>      %R - percent reductions in this phase
>   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
> Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
>                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %f %M %L %R  %T %f %M %L %R Mflop/s
> --- Event Stage 0: Main Stage
> MatMult              202 1.0 5.5096e-01 1.0 1.38e+08 1.0 1.2e+03 5.7e+03 0.0e+00  5 29 99100  0   5 29 99100  0   998
> MatSolve             252 1.0 6.9136e-01 1.1 1.71e+08 1.0 0.0e+00 0.0e+00 0.0e+00  6 36  0  0  0   6 36  0  0  0   986
> MatLUFactorNum        50 1.0 4.6002e-01 1.0 7.31e+07 1.0 0.0e+00 0.0e+00 0.0e+00  4 15  0  0  0   4 15  0  0  0   634
> MatILUFactorSym        1 1.0 9.5899e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatAssemblyBegin      50 1.0 1.6270e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+02  0  0  0  0 11   0  0  0  0 11     0
> MatAssemblyEnd        50 1.0 1.0896e-01 1.0 0.00e+00 0.0 1.2e+01 1.4e+03 8.0e+00  1  0  1  0  1   1  0  1  0  1     0
> MatGetRowIJ            1 1.0 2.8610e-06 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatGetOrdering         1 1.0 7.2002e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00  0  0  0  0  0   0  0  0  0  0     0
> KSPSetUp             100 1.0 2.9130e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> KSPSolve              50 1.0 2.0737e+00 1.0 4.76e+08 1.0 1.2e+03 5.7e+03 4.6e+02 19100 99100 52  19100 99100 53   915
> VecDot               202 1.0 7.3588e-02 1.1 1.63e+07 1.0 0.0e+00 0.0e+00 2.0e+02  1  3  0  0 23   1  3  0  0 23   885
> VecDotNorm2          101 1.0 3.9155e-02 1.7 1.63e+07 1.0 0.0e+00 0.0e+00 1.0e+02  0  3  0  0 12   0  3  0  0 12  1664
> VecNorm              151 1.0 5.8769e-02 1.7 1.22e+07 1.0 0.0e+00 0.0e+00 1.5e+02  0  3  0  0 17   0  3  0  0 17   829
> VecCopy              100 1.0 2.3459e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> VecSet               403 1.0 5.9994e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
> VecAXPBYCZ           202 1.0 6.6376e-02 1.0 3.26e+07 1.0 0.0e+00 0.0e+00 0.0e+00  1  7  0  0  0   1  7  0  0  0  1963
> VecWAXPY             202 1.0 6.9311e-02 1.0 1.63e+07 1.0 0.0e+00 0.0e+00 0.0e+00  1  3  0  0  0   1  3  0  0  0   940
> VecAssemblyBegin     100 1.0 4.0355e-0214.1 0.00e+00 0.0 0.0e+00 0.0e+00 3.0e+02  0  0  0  0 34   0  0  0  0 34     0
> VecAssemblyEnd       100 1.0 5.0378e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> VecScatterBegin      202 1.0 6.2275e-03 1.5 0.00e+00 0.0 1.2e+03 5.7e+03 0.0e+00  0  0 99100  0   0  0 99100  0     0
> VecScatterEnd        202 1.0 2.0878e-02 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> PCSetUp              100 1.0 4.7225e-01 1.0 7.31e+07 1.0 0.0e+00 0.0e+00 5.0e+00  4 15  0  0  1   4 15  0  0  1   617
> PCSetUpOnBlocks       50 1.0 4.7191e-01 1.0 7.31e+07 1.0 0.0e+00 0.0e+00 3.0e+00  4 15  0  0  0   4 15  0  0  0   618
> PCApply              252 1.0 7.3425e-01 1.1 1.71e+08 1.0 0.0e+00 0.0e+00 0.0e+00  7 36  0  0  0   7 36  0  0  0   928
> Memory usage is given in bytes:
> Object Type          Creations   Destructions     Memory  Descendants' Mem.
> Reports information only for process 0.
>              Matrix     4              4     16900896     0
>       Krylov Solver     2              2         2168     0
>              Vector    12             12      2604080     0
>      Vector Scatter     1              1         1060     0
>           Index Set     5              5       167904     0
>      Preconditioner     2              2         1800     0
>              Viewer     1              0            0     0
> Average time to get PetscTime(): 1.09673e-06
> Average time for MPI_Barrier(): 4.00543e-06
> Average time for zero size MPI_Send(): 1.22786e-05
> #PETSc Option Table entries:
> -log_summary
> -mg_ksp_view
> #End of PETSc Option Table entries
> Compiled without FORTRAN kernels
> Compiled with full precision matrices (default)
> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
> Configure run at: Thu May 31 09:53:43 2012
> Configure options: --with-mpi-dir=/opt/openmpi-1.5.3/ --with-blas-lapack-dir=/opt/intelcpro-11.1.059/mkl/lib/em64t/ --with-debugging=0 --download-hypre=1 --prefix=/home/wtay/Lib/petsc-3.2-dev_shared_rel --known-mpi-shared=1 --with-shared-libraries
> Libraries compiled on Thu May 31 09:53:43 2012 on hpc12
> Machine characteristics: Linux-2.6.32-220.2.1.el6.x86_64-x86_64-with-centos-6.2-Final
> Using PETSc directory: /home/wtay/Codes/petsc-dev
> Using PETSc arch: petsc-3.2-dev_shared_rel
> Using C compiler: /opt/openmpi-1.5.3/bin/mpicc  -fPIC -wd1572 -Qoption,cpp,--extended_float_type -O3  ${COPTFLAGS} ${CFLAGS}
> Using Fortran compiler: /opt/openmpi-1.5.3/bin/mpif90  -fPIC -O3   ${FOPTFLAGS} ${FFLAGS}
> Using include paths: -I/home/wtay/Codes/petsc-dev/petsc-3.2-dev_shared_rel/include -I/home/wtay/Codes/petsc-dev/include -I/home/wtay/Codes/petsc-dev/include -I/home/wtay/Codes/petsc-dev/petsc-3.2-dev_shared_rel/include -I/opt/openmpi-1.5.3/include
> Using C linker: /opt/openmpi-1.5.3/bin/mpicc
> Using Fortran linker: /opt/openmpi-1.5.3/bin/mpif90
> Using libraries: -Wl,-rpath,/home/wtay/Codes/petsc-dev/petsc-3.2-dev_shared_rel/lib -L/home/wtay/Codes/petsc-dev/petsc-3.2-dev_shared_rel/lib -lpetsc -lX11 -lpthread -Wl,-rpath,/home/wtay/Codes/petsc-dev/petsc-3.2-dev_shared_rel/lib -L/home/wtay/Codes/petsc-dev/petsc-3.2-dev_shared_rel/lib -lHYPRE -lmpi_cxx -Wl,-rpath,/opt/openmpi-1.5.3/lib -Wl,-rpath,/opt/intelcpro-11.1.059/lib/intel64 -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.4.6 -lstdc++ -Wl,-rpath,/opt/intelcpro-11.1.059/mkl/lib/em64t -L/opt/intelcpro-11.1.059/mkl/lib/em64t -lmkl_intel_lp64 -lmkl_intel_thread -lmkl_core -liomp5 -lpthread -ldl -L/opt/openmpi-1.5.3/lib -lmpi -lnsl -lutil -L/opt/intelcpro-11.1.059/lib/intel64 -limf -L/usr/lib/gcc/x86_64-redhat-linux/4.4.6 -lsvml -lipgo -ldecimal -lgcc_s -lirc -lpthread -lirc_s -lmpi_f90 -lmpi_f77 -lm -lm -lifport -lifcore -lm -lm -lm -lmpi_cxx -lstdc++ -lmpi_cxx -lstdc++ -ldl -lmpi -lnsl -lutil -limf -lsvml -lipgo -ldecimal -lgcc_s -lirc -lpthread -lirc_s -ldl
> Yours sincerely,
> TAY wee-beng
> On 5/6/2012 1:34 AM, Barry Smith wrote:
>>    Also run with -ksp_view to see exasctly what solver options it is using. For example the number of levels, smoother on each level etc. My guess is that the below is running on one level (because I don't see you supplying options to control the number of levels etc).
>>    Barry
>> On Jun 4, 2012, at 4:15 PM, Jed Brown wrote:
>>> Always send -log_summary when asking about performance.
>>> On Mon, Jun 4, 2012 at 4:11 PM, TAY wee-beng<zonexo at gmail.com>  wrote:
>>> Hi,
>>> I tried using PETSc multigrid on my 2D CFD code. I had converted ksp eg. ex29 to Fortran and then added into my code to solve the Poisson equation.
>>> The main subroutines are:
>>> call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)
>>> call DMDACreate2d(PETSC_COMM_WORLD,DMDA_BOUNDARY_NONE,DMDA_BOUNDARY_NONE,DMDA_STENCIL_STAR,i3,i3,PETSC_DECIDE,PETSC_DECIDE,i1,i1,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,da,ierr)
>>> call DMSetFunction(da,ComputeRHS,ierr)
>>> call DMSetJacobian(da,ComputeMatrix,ierr)
>>> call KSPSetDM(ksp,da,ierr)
>>> call KSPSetFromOptions(ksp,ierr)
>>> call KSPSetUp(ksp,ierr)
>>> call KSPSolve(ksp,PETSC_NULL_OBJECT,PETSC_NULL_OBJECT,ierr)
>>> call KSPGetSolution(ksp,x,ierr)
>>> call VecView(x,PETSC_VIEWER_STDOUT_WORLD,ierr)
>>> call KSPDestroy(ksp,ierr)
>>> call DMDestroy(da,ierr)
>>> call PetscFinalize(ierr)
>>> Since the LHS matrix doesn't change, I only set up at the 1st time step, thereafter I only called ComputeRHS every time step.
>>> I was using HYPRE's geometric multigrid and the speed was much faster.
>>> What other options can I tweak to improve the speed? Or should I call the subroutines above at every timestep?
>>> Thanks!
>>> Yours sincerely,
>>> TAY wee-beng
