[petsc-users] segfault running src/dm/examples/tutorials/ex11f90.F
Panruo Wu pwu at mymail.mines.edu
Tue Jun 5 22:54:57 CDT 2012
Dear list,
I run into a segfault when running src/dm/examples/tutorials/ex11f90.F
Intel Fortran Compiler 12.1.3; 1.6 OpenMPI; Ubuntu 12.04
other examples compiles and runs well.
It compiles without any warnings or errors; however it cannot run.
Any ideas?  Error message are attached.
Thank you!
Panruo Wu
$ mpirun -np 1 ex11f90
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[0]PETSCERROR:
or try
http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: ---------------------  Stack Frames
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR:       INSTEAD the line number of the start of the function
[0]PETSC ERROR:       is given.
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Signal received!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Release Version 3.2.0, Patch 7, Thu Mar 15 09:30:51
CDT 2012
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: ex11f90 on a opmi_inte named avahome by pwu Tue Jun  5
21:44:11 2012
[0]PETSC ERROR: Libraries linked from
/home/pwu/Downloads/petsc-3.2-p7/opmi_intel_dbg/lib
[0]PETSC ERROR: Configure run at Tue Jun  5 10:02:00 2012
[0]PETSC ERROR: Configure options
--with-blas-lapack-dir=/opt/intel/mkl/lib/intel64 --download-umfpack
--download-superlu --with-x=1
[0]PETSC ERROR:
[0]PETSC ERROR: User provided function() line 0 in unknown directory
unknown file
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 59.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
mpirun has exited due to process rank 0 with PID 22293 on
node avahome exiting improperly. There are two reasons this could occur:
1. this process did not call "init" before exiting, but others in
the job did. This can cause a job to hang indefinitely while it waits
for all processes to call "init". By rule, if one process calls "init",
then ALL processes must call "init" prior to termination.
2. this process called "init", but exited without calling "finalize".
By rule, all processes that call "init" MUST call "finalize" prior to
exiting or it will be considered an "abnormal termination"
This may have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120605/13345a8d/attachment.html>
