[petsc-users] Set vector elements after VecAssembly?
Tue Jun 5 06:56:50 CDT 2012
On Tue, Jun 5, 2012 at 1:48 AM, Thomas Witkowski <
thomas.witkowski at tu-dresden.de> wrote:
> Is it possible to update some vector entries after VecAssembly has been
> called?
If you use VecSetValues(), call VecAssemblyBegin/End again when you are
done.
You can also use VecGetArray() (or variants) to manipulate vector entries
without needing to call VecAssemblyBegin/End.
> Is due to some boundary conditions. In principle, I need something that is
> also done in MatZeroRows on the last two vector parameters, but without the
> need to provide some matrix information. Is this possible?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120605/8c44f1fe/attachment.html>
