[petsc-users] Slow speed when using PETSc multigrid
TAY wee-beng zonexo at gmail.com
Mon Jun 4 16:11:37 CDT 2012
I tried using PETSc multigrid on my 2D CFD code. I had converted ksp eg.
ex29 to Fortran and then added into my code to solve the Poisson equation.
The main subroutines are:
call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)
call
DMDACreate2d(PETSC_COMM_WORLD,DMDA_BOUNDARY_NONE,DMDA_BOUNDARY_NONE,DMDA_STENCIL_STAR,i3,i3,PETSC_DECIDE,PETSC_DECIDE,i1,i1,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,da,ierr)
call DMSetFunction(da,ComputeRHS,ierr)
call DMSetJacobian(da,ComputeMatrix,ierr)
call KSPSetDM(ksp,da,ierr)
call KSPSetFromOptions(ksp,ierr)
call KSPSetUp(ksp,ierr)
call KSPSolve(ksp,PETSC_NULL_OBJECT,PETSC_NULL_OBJECT,ierr)
call KSPGetSolution(ksp,x,ierr)
call VecView(x,PETSC_VIEWER_STDOUT_WORLD,ierr)
call KSPDestroy(ksp,ierr)
call DMDestroy(da,ierr)
call PetscFinalize(ierr)
Since the LHS matrix doesn't change, I only set up at the 1st time step,
thereafter I only called ComputeRHS every time step.
I was using HYPRE's geometric multigrid and the speed was much faster.
What other options can I tweak to improve the speed? Or should I call
the subroutines above at every timestep?
Thanks!
Yours sincerely,
TAY wee-beng
