[petsc-users] about Matrix-Free
behzad baghapour behzad.baghapour at gmail.com
Mon Jun 4 08:36:39 CDT 2012
OK. Thank you.
On Mon, Jun 4, 2012 at 3:04 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Mon, Jun 4, 2012 at 1:41 AM, behzad baghapour <
> behzad.baghapour at gmail.com> wrote:
>> According to my last question, I am trying to use Shell to handle the
>> MatrixFree procedure as below:
>> 1- Define residual as:
>>        F := M * DQ/Dt - R(Q) (R is the nonlinear residual obtained from
>> discretization)
>> 2- MatCreateShell
>> 3- MatShellSetOperation -> MATOP_MULT as follows:
>>        dF/dQ * v = M * v / Dt - ( R(Q+eps*v) - R(Q) ) / eps
>> 4- Using this operation in each step of KSP (GMRES) subspace
>> construction.
>> Does the above procedure seem reasonable to use with SNES? Please help me
>> if it needs more considerations.
> You can just set the SNES function and do -snes_mf, then this will be done
> for you.
> You might also consider using TS. TSSetIFunction() is the interface you
> propose.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120604/1730b59d/attachment.html>
