[petsc-users] About the ./configure of petsc and mpi
w_ang_temp w_ang_temp at 163.com
Mon Jun 4 02:58:31 CDT 2012
Hello, Jed
     The problem has been solved. Just as you said, the  variable 'LTR ' shoud be initialized.
     Thanks.
                                             Jim
>在 2012-06-02 22:34:58,"Jed Brown" <jedbrown at mcs.anl.gov> 写道:
>On Sat, Jun 2, 2012 at 9:28 AM, w_ang_temp <w_ang_temp at 163.com> wrote:
>Hello Jed
 >   It is true that LTR is uninitialized.
>There are lots of ways for uninitialized variables to accidentally have valid values. That doesn't mean your program is correct, it just means that it >accidentally "worked". You have to fix your code.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120604/817a7690/attachment.html>
