[petsc-users] Solutions different after program restart
Sun Jun 3 08:44:23 CDT 2012
On Sun, Jun 3, 2012 at 8:37 AM, Niceno Bojan <bojan.niceno at psi.ch> wrote:
> I don't know.  Is there a way to find out?
-ksp_monitor or -ksp_monitor_true_residual
> > In that case, check that the system being solved is identical. You can
> save
> > it with -ksp_view_binary. Load it with
> > src/ksp/ksp/examples/tutorials/ex10.c as an independent test. Also be
> sure
> > to use the same initial guess.
> Thanks.  I was checking norms of matrix "A" and "x" and "b" vectors (2nd
> order) and they ARE the same before and after restart.  Does the same norm
> ensure the matrices and and vectors are the same?
They could be ordered differently. A different ordering would change the
ILU algorithm. You can also run with -pc_type jacobi to avoid this source
of variation (norms are still order-dependent up to rounding error).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120603/c6bf26d3/attachment-0001.html>
