[petsc-users] About the ./configure of petsc and mpi
w_ang_temp w_ang_temp at 163.com
Sat Jun 2 09:28:36 CDT 2012
Hello Jed
    It is true that LTR is uninitialized. But before the reconfiguration, it is ok by the default compiler. The codes are the same before and after the reconfiguration.
    Also I use ifort to compile the fortran project before I add petsc code to it and it is ok. So I think that this line (line 126) should not be incorrect when use ifort.
   Maybethere'sany otherreason related to the new compiler.
   Thanks.
                                                Jim
>At 2012-06-02 22:13:06,"Jed Brown" <jedbrown at mcs.anl.gov> wrote:
>Looks like LTR is uninitialized or has been overwritten by earlier corruption. This does not have anything to do with PETSc.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120602/263d73d1/attachment.html>
