[petsc-users] GMRES pc right fails while pc left succeeds
Klaij, Christiaan C.Klaij at marin.nl
Fri Jun 1 03:36:12 CDT 2012
To solve the incompressible Navier-Stokes equations, I'm using
cell-centered finite volumes and Picard linearization. At each
non-linear iteration, I'm using one linear (Krylov) iteration with a
SIMPLE-type block preconditioner (for example Elman e.a, JCP 227,
2008). The matrix and preconditioner are shells. Below, I'm showing
the results for the first few non-linear iterations using
(1) KSPRICHARDSON to check that the shells are ok
(2) GMRES with right preconditioning
(3) GMRES with left preconditioning
To my surprise (2) fails while (1) and (3) succeed. The reason I'm
interested in right preconditioning is that SIMPLE is a variable
preconditioner so in theory I should be using FGMRES as soon as I
increase the number of linear (Krylov) iterations. What could be the
reason that GMRES fails with right pc?
KSPRICHARDSON
KSP Object:(sys_) 64 MPI processes
  type: richardson
    Richardson: damping factor=1
  maximum iterations=1, initial guess is zero
  tolerances:  relative=0.1, absolute=1e-50, divergence=10000
  using PRECONDITIONED norm type for convergence test
PC Object:(sys_) 64 MPI processes
  type: shell
    Shell: no name
  linear system matrix = precond matrix:
  Matrix Object:   64 MPI processes
    type: shell
    rows=13599580, cols=13599580
  Residual norms for sys_ solve.
  0 KSP preconditioned resid norm 3.002292124139e+07 true resid norm 2.449788038787e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 2.466728998567e+08 true resid norm 1.184153811354e+02 ||r(i)||/||b|| 4.833699049085e+00
  0 KSP preconditioned resid norm 4.633884476245e+06 true resid norm 2.178463431810e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.026742626974e+07 true resid norm 7.583593359073e+01 ||r(i)||/||b|| 3.481166242379e+00
  0 KSP preconditioned resid norm 7.603912564752e+06 true resid norm 2.063977595102e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.334118865425e+07 true resid norm 4.644866011115e+01 ||r(i)||/||b|| 2.250444007792e+00
  0 KSP preconditioned resid norm 4.837763400164e+06 true resid norm 1.744796447506e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 3.366091965735e+07 true resid norm 3.667361782612e+01 ||r(i)||/||b|| 2.101885172826e+00
  0 KSP preconditioned resid norm 3.164837635443e+06 true resid norm 1.379343201904e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 2.076321593136e+07 true resid norm 2.580128984813e+01 ||r(i)||/||b|| 1.870548954932e+00
  0 KSP preconditioned resid norm 2.740236061285e+06 true resid norm 1.089190060245e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.774062456490e+07 true resid norm 1.905053703637e+01 ||r(i)||/||b|| 1.749055351467e+00
  0 KSP preconditioned resid norm 2.116828431953e+06 true resid norm 8.739520919331e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.292581773188e+07 true resid norm 1.417058997539e+01 ||r(i)||/||b|| 1.621437846101e+00
  0 KSP preconditioned resid norm 1.732540786832e+06 true resid norm 7.103614423801e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.024675862117e+07 true resid norm 1.143160619326e+01 ||r(i)||/||b|| 1.609266144141e+00
  0 KSP preconditioned resid norm 1.352305197787e+06 true resid norm 5.785689719087e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 7.564758442669e+06 true resid norm 8.227117972441e+00 ||r(i)||/||b|| 1.421977045416e+00
  0 KSP preconditioned resid norm 1.150715386196e+06 true resid norm 4.793529363445e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 6.372682588351e+06 true resid norm 6.688883029785e+00 ||r(i)||/||b|| 1.395398363635e+00
  0 KSP preconditioned resid norm 9.572132583239e+05 true resid norm 3.988785666972e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.261708756365e+06 true resid norm 6.009243780630e+00 ||r(i)||/||b|| 1.506534640452e+00
  0 KSP preconditioned resid norm 7.708272340553e+05 true resid norm 3.328712835238e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.063709557864e+06 true resid norm 4.716564750520e+00 ||r(i)||/||b|| 1.416933506727e+00
  0 KSP preconditioned resid norm 6.237006694662e+05 true resid norm 2.840137112965e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 3.236149418914e+06 true resid norm 3.966057508670e+00 ||r(i)||/||b|| 1.396431704148e+00
  0 KSP preconditioned resid norm 5.836468734124e+05 true resid norm 2.463325405601e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 3.222197400481e+06 true resid norm 3.320264231000e+00 ||r(i)||/||b|| 1.347878856545e+00
  0 KSP preconditioned resid norm 4.369688632472e+05 true resid norm 2.149175735231e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 2.330816379175e+06 true resid norm 2.741356483857e+00 ||r(i)||/||b|| 1.275538542018e+00
  0 KSP preconditioned resid norm 3.363278393552e+05 true resid norm 1.909837709921e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.681890437397e+06 true resid norm 2.308561048035e+00 ||r(i)||/||b|| 1.208773413596e+00
  0 KSP preconditioned resid norm 2.802377915000e+05 true resid norm 1.728472606236e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.336982911437e+06 true resid norm 1.968373614139e+00 ||r(i)||/||b|| 1.138793641876e+00
  0 KSP preconditioned resid norm 2.365927099152e+05 true resid norm 1.596065109380e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.049884061323e+06 true resid norm 1.732502774165e+00 ||r(i)||/||b|| 1.085483771297e+00
  0 KSP preconditioned resid norm 2.002859406874e+05 true resid norm 1.495493921635e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 8.497026355879e+05 true resid norm 1.561301201038e+00 ||r(i)||/||b|| 1.044003709043e+00
  0 KSP preconditioned resid norm 1.860953637588e+05 true resid norm 1.414036045246e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 7.970043961017e+05 true resid norm 1.414991682369e+00 ||r(i)||/||b|| 1.000675822321e+00
  0 KSP preconditioned resid norm 1.644104206835e+05 true resid norm 1.346916532259e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 7.648634021008e+05 true resid norm 1.246596455132e+00 ||r(i)||/||b|| 9.255187127602e-01
  0 KSP preconditioned resid norm 1.872174371851e+05 true resid norm 1.290333542891e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 8.372959177536e+05 true resid norm 1.202317588926e+00 ||r(i)||/||b|| 9.317882151865e-01
  0 KSP preconditioned resid norm 1.661343842757e+05 true resid norm 1.243144485951e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 7.563429909910e+05 true resid norm 1.057154297198e+00 ||r(i)||/||b|| 8.503873114867e-01
  0 KSP preconditioned resid norm 1.672029389906e+05 true resid norm 1.199158775660e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 7.625434467940e+05 true resid norm 1.018232434251e+00 ||r(i)||/||b|| 8.491222804841e-01
  0 KSP preconditioned resid norm 1.609863909906e+05 true resid norm 1.166442633617e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 7.594136262967e+05 true resid norm 8.852250142544e-01 ||r(i)||/||b|| 7.589100301566e-01
  0 KSP preconditioned resid norm 1.589084188509e+05 true resid norm 1.133575353542e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 7.531640641766e+05 true resid norm 8.680191349580e-01 ||r(i)||/||b|| 7.657357159767e-01
  0 KSP preconditioned resid norm 1.545741532506e+05 true resid norm 1.109246759396e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 7.068835202912e+05 true resid norm 7.541905012706e-01 ||r(i)||/||b|| 6.799122872184e-01
  0 KSP preconditioned resid norm 1.505271454290e+05 true resid norm 1.083901826677e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 6.895666749586e+05 true resid norm 7.334526058239e-01 ||r(i)||/||b|| 6.766780789296e-01
  0 KSP preconditioned resid norm 1.429767942414e+05 true resid norm 1.065392345898e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 6.674722288653e+05 true resid norm 6.605153582236e-01 ||r(i)||/||b|| 6.199738159999e-01
  0 KSP preconditioned resid norm 1.349552981353e+05 true resid norm 1.046479546594e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 6.420791854107e+05 true resid norm 6.061030158236e-01 ||r(i)||/||b|| 5.791828591358e-01
  0 KSP preconditioned resid norm 1.294549761112e+05 true resid norm 1.030516295057e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 6.009630735908e+05 true resid norm 5.682902043831e-01 ||r(i)||/||b|| 5.514616383159e-01
  0 KSP preconditioned resid norm 1.263203266274e+05 true resid norm 1.016513956599e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.685817059997e+05 true resid norm 5.312671230577e-01 ||r(i)||/||b|| 5.226363293968e-01
  0 KSP preconditioned resid norm 1.218894584644e+05 true resid norm 1.004638417180e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.506946781986e+05 true resid norm 5.019080583246e-01 ||r(i)||/||b|| 4.995907480160e-01
  0 KSP preconditioned resid norm 1.140914318170e+05 true resid norm 9.947019980499e-01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.382103111998e+05 true resid norm 4.655872827257e-01 ||r(i)||/||b|| 4.680671031510e-01
  0 KSP preconditioned resid norm 1.067119548244e+05 true resid norm 9.863770120848e-01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.108428061151e+05 true resid norm 4.424022035790e-01 ||r(i)||/||b|| 4.485122809624e-01
  0 KSP preconditioned resid norm 1.019474184396e+05 true resid norm 9.799542793429e-01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.721773506635e+05 true resid norm 4.199861021046e-01 ||r(i)||/||b|| 4.285772417732e-01
  0 KSP preconditioned resid norm 9.830423129037e+04 true resid norm 9.751559280594e-01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.361650301572e+05 true resid norm 3.923976141692e-01 ||r(i)||/||b|| 4.023947379883e-01
  0 KSP preconditioned resid norm 9.330148868500e+04 true resid norm 9.719876905233e-01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.197457401960e+05 true resid norm 3.711703982110e-01 ||r(i)||/||b|| 3.818673855954e-01
  0 KSP preconditioned resid norm 8.685377015665e+04 true resid norm 9.705157913387e-01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.050538464657e+05 true resid norm 3.521450162021e-01 ||r(i)||/||b|| 3.628431596320e-01
  0 KSP preconditioned resid norm 8.104143121935e+04 true resid norm 9.707989920233e-01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 3.788424265633e+05 true resid norm 3.340342892670e-01 ||r(i)||/||b|| 3.440818253950e-01
  0 KSP preconditioned resid norm 7.724089365112e+04 true resid norm 9.730581336050e-01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 3.457900621193e+05 true resid norm 3.145704907970e-01 ||r(i)||/||b|| 3.232802644911e-01
  0 KSP preconditioned resid norm 7.429452857765e+04 true resid norm 9.778147647982e-01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 3.229330560666e+05 true resid norm 3.032903181340e-01 ||r(i)||/||b|| 3.101715468538e-01
  0 KSP preconditioned resid norm 6.995091708215e+04 true resid norm 9.844124677010e-01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 3.109695743465e+05 true resid norm 2.925574699740e-01 ||r(i)||/||b|| 2.971899275689e-01
  0 KSP preconditioned resid norm 6.431621141247e+04 true resid norm 9.932717704670e-01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 2.988547543300e+05 true resid norm 2.828386955713e-01 ||r(i)||/||b|| 2.847545898122e-01
  0 KSP preconditioned resid norm 6.059506259530e+04 true resid norm 1.004501645405e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 2.817009034402e+05 true resid norm 2.805123677650e-01 ||r(i)||/||b|| 2.792552596088e-01
  0 KSP preconditioned resid norm 5.745261235425e+04 true resid norm 1.017758014319e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 2.542169446329e+05 true resid norm 2.724197244073e-01 ||r(i)||/||b|| 2.676664988874e-01
  0 KSP preconditioned resid norm 5.516674377618e+04 true resid norm 1.034201742913e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 2.378530798956e+05 true resid norm 2.667643670507e-01 ||r(i)||/||b|| 2.579422911232e-01
  0 KSP preconditioned resid norm 5.194287548926e+04 true resid norm 1.053156823791e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 2.290402092140e+05 true resid norm 2.646974039255e-01 ||r(i)||/||b|| 2.513371208787e-01
  0 KSP preconditioned resid norm 4.808857001240e+04 true resid norm 1.074849466996e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 2.215939060099e+05 true resid norm 2.616032993026e-01 ||r(i)||/||b|| 2.433859878386e-01
  0 KSP preconditioned resid norm 4.475831147279e+04 true resid norm 1.099007926051e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 2.083656356962e+05 true resid norm 2.560599441241e-01 ||r(i)||/||b|| 2.329918993799e-01
  0 KSP preconditioned resid norm 4.221563346784e+04 true resid norm 1.125751964901e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.881930780060e+05 true resid norm 2.531356206610e-01 ||r(i)||/||b|| 2.248591417590e-01
  0 KSP preconditioned resid norm 4.150036386185e+04 true resid norm 1.154770933556e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.799205358655e+05 true resid norm 2.606336712952e-01 ||r(i)||/||b|| 2.257016207470e-01
  0 KSP preconditioned resid norm 3.926677498970e+04 true resid norm 1.185826544114e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.729849090921e+05 true resid norm 2.633851055090e-01 ||r(i)||/||b|| 2.221109881679e-01
  0 KSP preconditioned resid norm 3.669501750810e+04 true resid norm 1.218539067690e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.693046383608e+05 true resid norm 2.628742815537e-01 ||r(i)||/||b|| 2.157290550003e-01
  0 KSP preconditioned resid norm 3.426522258130e+04 true resid norm 1.253394141865e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.611167773181e+05 true resid norm 2.560938856149e-01 ||r(i)||/||b|| 2.043203147845e-01
  0 KSP preconditioned resid norm 3.265287560670e+04 true resid norm 1.289828098593e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.491234168952e+05 true resid norm 2.613672993010e-01 ||r(i)||/||b|| 2.026373123567e-01
  0 KSP preconditioned resid norm 3.197888583685e+04 true resid norm 1.327073787929e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.443230044262e+05 true resid norm 2.706087663843e-01 ||r(i)||/||b|| 2.039138809354e-01
  0 KSP preconditioned resid norm 3.073727378270e+04 true resid norm 1.365403569274e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.402005787526e+05 true resid norm 2.764196786979e-01 ||r(i)||/||b|| 2.024454050936e-01
  0 KSP preconditioned resid norm 2.932459486969e+04 true resid norm 1.403841601895e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.387678749811e+05 true resid norm 2.808710347819e-01 ||r(i)||/||b|| 2.000731666612e-01
KSPGMRES, PC_RIGHT
  type: gmres
    GMRES: restart=30, using Modified Gram-Schmidt Orthogonalization
    GMRES: happy breakdown tolerance 1e-30
  using UNPRECONDITIONED norm type for convergence test
  type: shell
    Shell: no name
    type: shell
  0 KSP unpreconditioned resid norm 2.449788038787e+01 true resid norm 2.449788038787e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.398039251803e+01 true resid norm 2.398039251803e+01 ||r(i)||/||b|| 9.788762186097e-01
  0 KSP unpreconditioned resid norm 2.420226272871e+01 true resid norm 2.420226272871e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.377979701744e+01 true resid norm 2.377979701744e+01 ||r(i)||/||b|| 9.825443713255e-01
  0 KSP unpreconditioned resid norm 2.390757858574e+01 true resid norm 2.390757858574e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.357584168912e+01 true resid norm 2.357584168912e+01 ||r(i)||/||b|| 9.861241950775e-01
  0 KSP unpreconditioned resid norm 2.365589714406e+01 true resid norm 2.365589714406e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.338729986835e+01 true resid norm 2.338729986835e+01 ||r(i)||/||b|| 9.886456525376e-01
  0 KSP unpreconditioned resid norm 2.343424425490e+01 true resid norm 2.343424425490e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.321506908653e+01 true resid norm 2.321506908653e+01 ||r(i)||/||b|| 9.906472269394e-01
  0 KSP unpreconditioned resid norm 2.323743871191e+01 true resid norm 2.323743871191e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.306701649761e+01 true resid norm 2.306701649761e+01 ||r(i)||/||b|| 9.926660499717e-01
  0 KSP unpreconditioned resid norm 2.306939620566e+01 true resid norm 2.306939620566e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.293212356739e+01 true resid norm 2.293212356739e+01 ||r(i)||/||b|| 9.940495781924e-01
  0 KSP unpreconditioned resid norm 2.292139442317e+01 true resid norm 2.292139442317e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.280900557416e+01 true resid norm 2.280900557416e+01 ||r(i)||/||b|| 9.950967708624e-01
  0 KSP unpreconditioned resid norm 2.278915281573e+01 true resid norm 2.278915281573e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.269700749818e+01 true resid norm 2.269700749818e+01 ||r(i)||/||b|| 9.959566150487e-01
  0 KSP unpreconditioned resid norm 2.267076491906e+01 true resid norm 2.267076491906e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.259790463024e+01 true resid norm 2.259790463024e+01 ||r(i)||/||b|| 9.967861565731e-01
  0 KSP unpreconditioned resid norm 2.256763385923e+01 true resid norm 2.256763385923e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.250777172301e+01 true resid norm 2.250777172301e+01 ||r(i)||/||b|| 9.973474340910e-01
  0 KSP unpreconditioned resid norm 2.247501724325e+01 true resid norm 2.247501724325e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.242579138506e+01 true resid norm 2.242579138506e+01 ||r(i)||/||b|| 9.978097521503e-01
  0 KSP unpreconditioned resid norm 2.239174013732e+01 true resid norm 2.239174013732e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.235122856474e+01 true resid norm 2.235122856474e+01 ||r(i)||/||b|| 9.981907805138e-01
  0 KSP unpreconditioned resid norm 2.231677642916e+01 true resid norm 2.231677642916e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.228341200759e+01 true resid norm 2.228341200759e+01 ||r(i)||/||b|| 9.985049623239e-01
  0 KSP unpreconditioned resid norm 2.224922495513e+01 true resid norm 2.224922495513e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.222172256133e+01 true resid norm 2.222172256133e+01 ||r(i)||/||b|| 9.987638942997e-01
  0 KSP unpreconditioned resid norm 2.218828968686e+01 true resid norm 2.218828968686e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.216560438029e+01 true resid norm 2.216560438029e+01 ||r(i)||/||b|| 9.989776000364e-01
  0 KSP unpreconditioned resid norm 2.213327413534e+01 true resid norm 2.213327413534e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.211455047562e+01 true resid norm 2.211455047562e+01 ||r(i)||/||b|| 9.991540492564e-01
  0 KSP unpreconditioned resid norm 2.208356267974e+01 true resid norm 2.208356267974e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.206809964045e+01 true resid norm 2.206809964045e+01 ||r(i)||/||b|| 9.992997941721e-01
  0 KSP unpreconditioned resid norm 2.203860985605e+01 true resid norm 2.203860985605e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.202583242681e+01 true resid norm 2.202583242681e+01 ||r(i)||/||b|| 9.994202252626e-01
  0 KSP unpreconditioned resid norm 2.199793147806e+01 true resid norm 2.199793147806e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.198736759090e+01 true resid norm 2.198736759090e+01 ||r(i)||/||b|| 9.995197781584e-01
  0 KSP unpreconditioned resid norm 2.196109697446e+01 true resid norm 2.196109697446e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.195235874753e+01 true resid norm 2.195235874753e+01 ||r(i)||/||b|| 9.996021042602e-01
  0 KSP unpreconditioned resid norm 2.192772281273e+01 true resid norm 2.192772281273e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.192049128260e+01 true resid norm 2.192049128260e+01 ||r(i)||/||b|| 9.996702106190e-01
  0 KSP unpreconditioned resid norm 2.189746681274e+01 true resid norm 2.189746681274e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.189218569645e+01 true resid norm 2.189218569645e+01 ||r(i)||/||b|| 9.997588252409e-01
  0 KSP unpreconditioned resid norm 2.187196087205e+01 true resid norm 2.187196087205e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.186758679430e+01 true resid norm 2.186758679430e+01 ||r(i)||/||b|| 9.998000143755e-01
  0 KSP unpreconditioned resid norm 2.184881028281e+01 true resid norm 2.184881028281e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.184355960145e+01 true resid norm 2.184355960145e+01 ||r(i)||/||b|| 9.997596811319e-01
  0 KSP unpreconditioned resid norm 2.182297473777e+01 true resid norm 2.182297473777e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.181859649271e+01 true resid norm 2.181859649271e+01 ||r(i)||/||b|| 9.997993745070e-01
  0 KSP unpreconditioned resid norm 2.179944311209e+01 true resid norm 2.179944311209e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.179579052478e+01 true resid norm 2.179579052478e+01 ||r(i)||/||b|| 9.998324458429e-01
  0 KSP unpreconditioned resid norm 2.177799695396e+01 true resid norm 2.177799695396e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.177494837915e+01 true resid norm 2.177494837915e+01 ||r(i)||/||b|| 9.998600158305e-01
  0 KSP unpreconditioned resid norm 2.175844331512e+01 true resid norm 2.175844331512e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.175631168374e+01 true resid norm 2.175631168374e+01 ||r(i)||/||b|| 9.999020319905e-01
  0 KSP unpreconditioned resid norm 2.174229725863e+01 true resid norm 2.174229725863e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.174051695969e+01 true resid norm 2.174051695969e+01 ||r(i)||/||b|| 9.999181181770e-01
  0 KSP unpreconditioned resid norm 2.172756288450e+01 true resid norm 2.172756288450e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.172607550829e+01 true resid norm 2.172607550829e+01 ||r(i)||/||b|| 9.999315442685e-01
  0 KSP unpreconditioned resid norm 2.171411393798e+01 true resid norm 2.171411393798e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.171287087957e+01 true resid norm 2.171287087957e+01 ||r(i)||/||b|| 9.999427534358e-01
  0 KSP unpreconditioned resid norm 2.170183476197e+01 true resid norm 2.170183476197e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.170079556874e+01 true resid norm 2.170079556874e+01 ||r(i)||/||b|| 9.999521149596e-01
  0 KSP unpreconditioned resid norm 2.169062063291e+01 true resid norm 2.169062063291e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.168975161538e+01 true resid norm 2.168975161538e+01 ||r(i)||/||b|| 9.999599357922e-01
  0 KSP unpreconditioned resid norm 2.168037662550e+01 true resid norm 2.168037662550e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.167964971448e+01 true resid norm 2.167964971448e+01 ||r(i)||/||b|| 9.999664714762e-01
  0 KSP unpreconditioned resid norm 2.167101664634e+01 true resid norm 2.167101664634e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.167040844422e+01 true resid norm 2.167040844422e+01 ||r(i)||/||b|| 9.999719347673e-01
  0 KSP unpreconditioned resid norm 2.166246255652e+01 true resid norm 2.166246255652e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.166195355024e+01 true resid norm 2.166195355024e+01 ||r(i)||/||b|| 9.999765028434e-01
  0 KSP unpreconditioned resid norm 2.165464338097e+01 true resid norm 2.165464338097e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.165421750324e+01 true resid norm 2.165421750324e+01 ||r(i)||/||b|| 9.999803331913e-01
  0 KSP unpreconditioned resid norm 2.164749647713e+01 true resid norm 2.164749647713e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.164714009809e+01 true resid norm 2.164714009809e+01 ||r(i)||/||b|| 9.999835371704e-01
  0 KSP unpreconditioned resid norm 2.164096314641e+01 true resid norm 2.164096314641e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.164066488237e+01 true resid norm 2.164066488237e+01 ||r(i)||/||b|| 9.999862176173e-01
  0 KSP unpreconditioned resid norm 2.163498993965e+01 true resid norm 2.163498993965e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.163474028123e+01 true resid norm 2.163474028123e+01 ||r(i)||/||b|| 9.999884604331e-01
  0 KSP unpreconditioned resid norm 2.162952818847e+01 true resid norm 2.162952818847e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.162931918941e+01 true resid norm 2.162931918941e+01 ||r(i)||/||b|| 9.999903373271e-01
  0 KSP unpreconditioned resid norm 2.162453352280e+01 true resid norm 2.162453352280e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.162440726736e+01 true resid norm 2.162440726736e+01 ||r(i)||/||b|| 9.999941614721e-01
  0 KSP unpreconditioned resid norm 2.162067417859e+01 true resid norm 2.162067417859e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.162056845965e+01 true resid norm 2.162056845965e+01 ||r(i)||/||b|| 9.999951102847e-01
  0 KSP unpreconditioned resid norm 2.161714328429e+01 true resid norm 2.161714328429e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.161705475368e+01 true resid norm 2.161705475368e+01 ||r(i)||/||b|| 9.999959046114e-01
  0 KSP unpreconditioned resid norm 2.161391323696e+01 true resid norm 2.161391323696e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.161383909277e+01 true resid norm 2.161383909277e+01 ||r(i)||/||b|| 9.999965696081e-01
  0 KSP unpreconditioned resid norm 2.161095817269e+01 true resid norm 2.161095817269e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.161089607130e+01 true resid norm 2.161089607130e+01 ||r(i)||/||b|| 9.999971263934e-01
  0 KSP unpreconditioned resid norm 2.160825448313e+01 true resid norm 2.160825448313e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.160820246425e+01 true resid norm 2.160820246425e+01 ||r(i)||/||b|| 9.999975926384e-01
  0 KSP unpreconditioned resid norm 2.160578062431e+01 true resid norm 2.160578062431e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.160573704698e+01 true resid norm 2.160573704698e+01 ||r(i)||/||b|| 9.999979830709e-01
  0 KSP unpreconditioned resid norm 2.160351690469e+01 true resid norm 2.160351690469e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.160348039592e+01 true resid norm 2.160348039592e+01 ||r(i)||/||b|| 9.999983100543e-01
  0 KSP unpreconditioned resid norm 2.160144534378e+01 true resid norm 2.160144534378e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.160141475452e+01 true resid norm 2.160141475452e+01 ||r(i)||/||b|| 9.999985839253e-01
  0 KSP unpreconditioned resid norm 2.159954951790e+01 true resid norm 2.159954951790e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.159952388641e+01 true resid norm 2.159952388641e+01 ||r(i)||/||b|| 9.999988133324e-01
  0 KSP unpreconditioned resid norm 2.159781442369e+01 true resid norm 2.159781442369e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.159779294497e+01 true resid norm 2.159779294497e+01 ||r(i)||/||b|| 9.999990055140e-01
  0 KSP unpreconditioned resid norm 2.159622635482e+01 true resid norm 2.159622635482e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.159620835481e+01 true resid norm 2.159620835481e+01 ||r(i)||/||b|| 9.999991665207e-01
  0 KSP unpreconditioned resid norm 2.159477278300e+01 true resid norm 2.159477278300e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.159475769728e+01 true resid norm 2.159475769728e+01 ||r(i)||/||b|| 9.999993014183e-01
  0 KSP unpreconditioned resid norm 2.159344225598e+01 true resid norm 2.159344225598e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.159342961192e+01 true resid norm 2.159342961192e+01 ||r(i)||/||b|| 9.999994144493e-01
  0 KSP unpreconditioned resid norm 2.159222430526e+01 true resid norm 2.159222430526e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.159221370694e+01 true resid norm 2.159221370694e+01 ||r(i)||/||b|| 9.999995091600e-01
  0 KSP unpreconditioned resid norm 2.159110935464e+01 true resid norm 2.159110935464e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.159110047019e+01 true resid norm 2.159110047019e+01 ||r(i)||/||b|| 9.999995885138e-01
  0 KSP unpreconditioned resid norm 2.159008863404e+01 true resid norm 2.159008863404e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.159008118520e+01 true resid norm 2.159008118520e+01 ||r(i)||/||b|| 9.999996549884e-01
  0 KSP unpreconditioned resid norm 2.158915410143e+01 true resid norm 2.158915410143e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.158914785454e+01 true resid norm 2.158914785454e+01 ||r(i)||/||b|| 9.999997106468e-01
  0 KSP unpreconditioned resid norm 2.158829835518e+01 true resid norm 2.158829835518e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.158829311446e+01 true resid norm 2.158829311446e+01 ||r(i)||/||b|| 9.999997572425e-01
  0 KSP unpreconditioned resid norm 2.158751461042e+01 true resid norm 2.158751461042e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.158751021199e+01 true resid norm 2.158751021199e+01 ||r(i)||/||b|| 9.999997962514e-01
  0 KSP unpreconditioned resid norm 2.158679665551e+01 true resid norm 2.158679665551e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.158679296227e+01 true resid norm 2.158679296227e+01 ||r(i)||/||b|| 9.999998289121e-01
  0 KSP unpreconditioned resid norm 2.158613880883e+01 true resid norm 2.158613880883e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.158613570587e+01 true resid norm 2.158613570587e+01 ||r(i)||/||b|| 9.999998562521e-01
  0 KSP unpreconditioned resid norm 2.158553585461e+01 true resid norm 2.158553585461e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.158553324556e+01 true resid norm 2.158553324556e+01 ||r(i)||/||b|| 9.999998791299e-01
  0 KSP unpreconditioned resid norm 2.158498299495e+01 true resid norm 2.158498299495e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.158498079906e+01 true resid norm 2.158498079906e+01 ||r(i)||/||b|| 9.999998982679e-01
  0 KSP unpreconditioned resid norm 2.158447581795e+01 true resid norm 2.158447581795e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.158447396778e+01 true resid norm 2.158447396778e+01 ||r(i)||/||b|| 9.999999142825e-01
  0 KSP unpreconditioned resid norm 2.158401029254e+01 true resid norm 2.158401029254e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.158400873212e+01 true resid norm 2.158400873213e+01 ||r(i)||/||b|| 9.999999277051e-01
  0 KSP unpreconditioned resid norm 2.158358278593e+01 true resid norm 2.158358278593e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.158358146892e+01 true resid norm 2.158358146892e+01 ||r(i)||/||b|| 9.999999389808e-01
  0 KSP unpreconditioned resid norm 2.158319004640e+01 true resid norm 2.158319004640e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.158318893382e+01 true resid norm 2.158318893382e+01 ||r(i)||/||b|| 9.999999484516e-01
  0 KSP unpreconditioned resid norm 2.158282908258e+01 true resid norm 2.158282908258e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.158282814200e+01 true resid norm 2.158282814200e+01 ||r(i)||/||b|| 9.999999564200e-01
  0 KSP unpreconditioned resid norm 2.158249719929e+01 true resid norm 2.158249719929e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.158249640367e+01 true resid norm 2.158249640367e+01 ||r(i)||/||b|| 9.999999631362e-01
  0 KSP unpreconditioned resid norm 2.158219196835e+01 true resid norm 2.158219196835e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.158219129508e+01 true resid norm 2.158219129508e+01 ||r(i)||/||b|| 9.999999688042e-01
  0 KSP unpreconditioned resid norm 2.158191118898e+01 true resid norm 2.158191118898e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.158191061899e+01 true resid norm 2.158191061899e+01 ||r(i)||/||b|| 9.999999735895e-01
  0 KSP unpreconditioned resid norm 2.158165284721e+01 true resid norm 2.158165284721e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.158165236453e+01 true resid norm 2.158165236453e+01 ||r(i)||/||b|| 9.999999776347e-01
  0 KSP unpreconditioned resid norm 2.158141511745e+01 true resid norm 2.158141511745e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.158141470849e+01 true resid norm 2.158141470849e+01 ||r(i)||/||b|| 9.999999810502e-01
  0 KSP unpreconditioned resid norm 2.158119629651e+01 true resid norm 2.158119629651e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.158119594981e+01 true resid norm 2.158119594981e+01 ||r(i)||/||b|| 9.999999839349e-01
  0 KSP unpreconditioned resid norm 2.158099482231e+01 true resid norm 2.158099482231e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.158099452820e+01 true resid norm 2.158099452820e+01 ||r(i)||/||b|| 9.999999863719e-01
  0 KSP unpreconditioned resid norm 2.158080926117e+01 true resid norm 2.158080926117e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.158080901147e+01 true resid norm 2.158080901147e+01 ||r(i)||/||b|| 9.999999884296e-01
  0 KSP unpreconditioned resid norm 2.158063828525e+01 true resid norm 2.158063828525e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.158063807308e+01 true resid norm 2.158063807308e+01 ||r(i)||/||b|| 9.999999901686e-01
  0 KSP unpreconditioned resid norm 2.158048068325e+01 true resid norm 2.158048068325e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.158048050284e+01 true resid norm 2.158048050284e+01 ||r(i)||/||b|| 9.999999916402e-01
  0 KSP unpreconditioned resid norm 2.158033535701e+01 true resid norm 2.158033535701e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.158033520349e+01 true resid norm 2.158033520349e+01 ||r(i)||/||b|| 9.999999928862e-01
  0 KSP unpreconditioned resid norm 2.158020130005e+01 true resid norm 2.158020130005e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.158020116932e+01 true resid norm 2.158020116932e+01 ||r(i)||/||b|| 9.999999939419e-01
  0 KSP unpreconditioned resid norm 2.158007759139e+01 true resid norm 2.158007759139e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.158007747999e+01 true resid norm 2.158007747999e+01 ||r(i)||/||b|| 9.999999948381e-01
  0 KSP unpreconditioned resid norm 2.157996340108e+01 true resid norm 2.157996340108e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157996330609e+01 true resid norm 2.157996330609e+01 ||r(i)||/||b|| 9.999999955983e-01
  0 KSP unpreconditioned resid norm 2.157985795541e+01 true resid norm 2.157985795541e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157985787435e+01 true resid norm 2.157985787435e+01 ||r(i)||/||b|| 9.999999962437e-01
  0 KSP unpreconditioned resid norm 2.157976054754e+01 true resid norm 2.157976054754e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157976047831e+01 true resid norm 2.157976047831e+01 ||r(i)||/||b|| 9.999999967920e-01
  0 KSP unpreconditioned resid norm 2.157967053027e+01 true resid norm 2.157967053027e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157967047110e+01 true resid norm 2.157967047110e+01 ||r(i)||/||b|| 9.999999972582e-01
  0 KSP unpreconditioned resid norm 2.157958731219e+01 true resid norm 2.157958731219e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157958726157e+01 true resid norm 2.157958726157e+01 ||r(i)||/||b|| 9.999999976545e-01
  0 KSP unpreconditioned resid norm 2.157951034517e+01 true resid norm 2.157951034517e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157951030184e+01 true resid norm 2.157951030184e+01 ||r(i)||/||b|| 9.999999979917e-01
  0 KSP unpreconditioned resid norm 2.157943912577e+01 true resid norm 2.157943912577e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157943908862e+01 true resid norm 2.157943908862e+01 ||r(i)||/||b|| 9.999999982787e-01
  0 KSP unpreconditioned resid norm 2.157937319229e+01 true resid norm 2.157937319229e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157937316042e+01 true resid norm 2.157937316042e+01 ||r(i)||/||b|| 9.999999985232e-01
  0 KSP unpreconditioned resid norm 2.157931212167e+01 true resid norm 2.157931212167e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157931209430e+01 true resid norm 2.157931209430e+01 ||r(i)||/||b|| 9.999999987316e-01
  0 KSP unpreconditioned resid norm 2.157925552663e+01 true resid norm 2.157925552663e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157925550310e+01 true resid norm 2.157925550310e+01 ||r(i)||/||b|| 9.999999989096e-01
  0 KSP unpreconditioned resid norm 2.157920305267e+01 true resid norm 2.157920305267e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157920303242e+01 true resid norm 2.157920303242e+01 ||r(i)||/||b|| 9.999999990617e-01
  0 KSP unpreconditioned resid norm 2.157915437730e+01 true resid norm 2.157915437730e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157915435986e+01 true resid norm 2.157915435986e+01 ||r(i)||/||b|| 9.999999991916e-01
  0 KSP unpreconditioned resid norm 2.157910919689e+01 true resid norm 2.157910919689e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157910918184e+01 true resid norm 2.157910918184e+01 ||r(i)||/||b|| 9.999999993028e-01
  0 KSP unpreconditioned resid norm 2.157906723996e+01 true resid norm 2.157906723996e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157906722697e+01 true resid norm 2.157906722697e+01 ||r(i)||/||b|| 9.999999993978e-01
  0 KSP unpreconditioned resid norm 2.157902824830e+01 true resid norm 2.157902824830e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157902823705e+01 true resid norm 2.157902823705e+01 ||r(i)||/||b|| 9.999999994791e-01
  0 KSP unpreconditioned resid norm 2.157899198387e+01 true resid norm 2.157899198387e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157899197413e+01 true resid norm 2.157899197413e+01 ||r(i)||/||b|| 9.999999995487e-01
  0 KSP unpreconditioned resid norm 2.157895823195e+01 true resid norm 2.157895823195e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157895822349e+01 true resid norm 2.157895822349e+01 ||r(i)||/||b|| 9.999999996083e-01
  0 KSP unpreconditioned resid norm 2.157892678874e+01 true resid norm 2.157892678874e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157892678139e+01 true resid norm 2.157892678139e+01 ||r(i)||/||b|| 9.999999996594e-01
  0 KSP unpreconditioned resid norm 2.157889746679e+01 true resid norm 2.157889746679e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157889746039e+01 true resid norm 2.157889746039e+01 ||r(i)||/||b|| 9.999999997032e-01
  0 KSP unpreconditioned resid norm 2.157887009677e+01 true resid norm 2.157887009677e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157887009118e+01 true resid norm 2.157887009118e+01 ||r(i)||/||b|| 9.999999997409e-01
  0 KSP unpreconditioned resid norm 2.157884452362e+01 true resid norm 2.157884452362e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157884451873e+01 true resid norm 2.157884451873e+01 ||r(i)||/||b|| 9.999999997733e-01
  0 KSP unpreconditioned resid norm 2.157882060369e+01 true resid norm 2.157882060369e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157882059940e+01 true resid norm 2.157882059940e+01 ||r(i)||/||b|| 9.999999998012e-01
  0 KSP unpreconditioned resid norm 2.157879820540e+01 true resid norm 2.157879820540e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157879820163e+01 true resid norm 2.157879820163e+01 ||r(i)||/||b|| 9.999999998253e-01
  0 KSP unpreconditioned resid norm 2.157877720874e+01 true resid norm 2.157877720874e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157877720542e+01 true resid norm 2.157877720542e+01 ||r(i)||/||b|| 9.999999998461e-01
  0 KSP unpreconditioned resid norm 2.157875750190e+01 true resid norm 2.157875750190e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157875749897e+01 true resid norm 2.157875749897e+01 ||r(i)||/||b|| 9.999999998640e-01
  0 KSP unpreconditioned resid norm 2.157873897847e+01 true resid norm 2.157873897847e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157873897587e+01 true resid norm 2.157873897587e+01 ||r(i)||/||b|| 9.999999998795e-01
  0 KSP unpreconditioned resid norm 2.157872154251e+01 true resid norm 2.157872154251e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157872154020e+01 true resid norm 2.157872154020e+01 ||r(i)||/||b|| 9.999999998929e-01
  0 KSP unpreconditioned resid norm 2.157870510897e+01 true resid norm 2.157870510897e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157870510691e+01 true resid norm 2.157870510691e+01 ||r(i)||/||b|| 9.999999999046e-01
  0 KSP unpreconditioned resid norm 2.157868959888e+01 true resid norm 2.157868959888e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157868959704e+01 true resid norm 2.157868959704e+01 ||r(i)||/||b|| 9.999999999148e-01
  0 KSP unpreconditioned resid norm 2.157867494197e+01 true resid norm 2.157867494197e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157867494032e+01 true resid norm 2.157867494032e+01 ||r(i)||/||b|| 9.999999999237e-01
  0 KSP unpreconditioned resid norm 2.157866107352e+01 true resid norm 2.157866107352e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157866107205e+01 true resid norm 2.157866107205e+01 ||r(i)||/||b|| 9.999999999316e-01
  0 KSP unpreconditioned resid norm 2.157864793570e+01 true resid norm 2.157864793570e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157864793437e+01 true resid norm 2.157864793437e+01 ||r(i)||/||b|| 9.999999999384e-01
  0 KSP unpreconditioned resid norm 2.157863547316e+01 true resid norm 2.157863547316e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157863547196e+01 true resid norm 2.157863547196e+01 ||r(i)||/||b|| 9.999999999444e-01
  0 KSP unpreconditioned resid norm 2.157862363517e+01 true resid norm 2.157862363517e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157862363408e+01 true resid norm 2.157862363408e+01 ||r(i)||/||b|| 9.999999999497e-01
  0 KSP unpreconditioned resid norm 2.157861237790e+01 true resid norm 2.157861237790e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157861237692e+01 true resid norm 2.157861237692e+01 ||r(i)||/||b|| 9.999999999545e-01
  0 KSP unpreconditioned resid norm 2.157860166238e+01 true resid norm 2.157860166238e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157860166149e+01 true resid norm 2.157860166149e+01 ||r(i)||/||b|| 9.999999999586e-01
  0 KSP unpreconditioned resid norm 2.157859145093e+01 true resid norm 2.157859145093e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157859145011e+01 true resid norm 2.157859145011e+01 ||r(i)||/||b|| 9.999999999623e-01
  0 KSP unpreconditioned resid norm 2.157858170896e+01 true resid norm 2.157858170896e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157858170822e+01 true resid norm 2.157858170822e+01 ||r(i)||/||b|| 9.999999999656e-01
  0 KSP unpreconditioned resid norm 2.157857240396e+01 true resid norm 2.157857240396e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157857240328e+01 true resid norm 2.157857240328e+01 ||r(i)||/||b|| 9.999999999686e-01
  0 KSP unpreconditioned resid norm 2.157856350749e+01 true resid norm 2.157856350749e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157856350687e+01 true resid norm 2.157856350687e+01 ||r(i)||/||b|| 9.999999999713e-01
  0 KSP unpreconditioned resid norm 2.157855499672e+01 true resid norm 2.157855499672e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157855499615e+01 true resid norm 2.157855499615e+01 ||r(i)||/||b|| 9.999999999737e-01
  0 KSP unpreconditioned resid norm 2.157854685270e+01 true resid norm 2.157854685270e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157854685218e+01 true resid norm 2.157854685218e+01 ||r(i)||/||b|| 9.999999999759e-01
  0 KSP unpreconditioned resid norm 2.157853905689e+01 true resid norm 2.157853905689e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157853905641e+01 true resid norm 2.157853905641e+01 ||r(i)||/||b|| 9.999999999779e-01
  0 KSP unpreconditioned resid norm 2.157853159183e+01 true resid norm 2.157853159183e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157853159139e+01 true resid norm 2.157853159139e+01 ||r(i)||/||b|| 9.999999999797e-01
  0 KSP unpreconditioned resid norm 2.157852444358e+01 true resid norm 2.157852444358e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157852444318e+01 true resid norm 2.157852444318e+01 ||r(i)||/||b|| 9.999999999814e-01
  0 KSP unpreconditioned resid norm 2.157851759980e+01 true resid norm 2.157851759980e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157851759943e+01 true resid norm 2.157851759943e+01 ||r(i)||/||b|| 9.999999999830e-01
  0 KSP unpreconditioned resid norm 2.157851104819e+01 true resid norm 2.157851104819e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157851104785e+01 true resid norm 2.157851104785e+01 ||r(i)||/||b|| 9.999999999844e-01
  0 KSP unpreconditioned resid norm 2.157850477824e+01 true resid norm 2.157850477824e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157850477793e+01 true resid norm 2.157850477793e+01 ||r(i)||/||b|| 9.999999999857e-01
  0 KSP unpreconditioned resid norm 2.157849878133e+01 true resid norm 2.157849878133e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157849878105e+01 true resid norm 2.157849878105e+01 ||r(i)||/||b|| 9.999999999870e-01
  0 KSP unpreconditioned resid norm 2.157849305030e+01 true resid norm 2.157849305030e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157849305004e+01 true resid norm 2.157849305004e+01 ||r(i)||/||b|| 9.999999999881e-01
  0 KSP unpreconditioned resid norm 2.157848757711e+01 true resid norm 2.157848757711e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157848757687e+01 true resid norm 2.157848757687e+01 ||r(i)||/||b|| 9.999999999892e-01
  0 KSP unpreconditioned resid norm 2.157848235719e+01 true resid norm 2.157848235719e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157848235698e+01 true resid norm 2.157848235698e+01 ||r(i)||/||b|| 9.999999999902e-01
  0 KSP unpreconditioned resid norm 2.157847738622e+01 true resid norm 2.157847738622e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157847738603e+01 true resid norm 2.157847738603e+01 ||r(i)||/||b|| 9.999999999911e-01
  0 KSP unpreconditioned resid norm 2.157847265980e+01 true resid norm 2.157847265980e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157847265963e+01 true resid norm 2.157847265963e+01 ||r(i)||/||b|| 9.999999999920e-01
  0 KSP unpreconditioned resid norm 2.157846817397e+01 true resid norm 2.157846817397e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157846817382e+01 true resid norm 2.157846817382e+01 ||r(i)||/||b|| 9.999999999928e-01
  0 KSP unpreconditioned resid norm 2.157846392420e+01 true resid norm 2.157846392420e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157846392406e+01 true resid norm 2.157846392406e+01 ||r(i)||/||b|| 9.999999999936e-01
  0 KSP unpreconditioned resid norm 2.157845990653e+01 true resid norm 2.157845990653e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157845990640e+01 true resid norm 2.157845990640e+01 ||r(i)||/||b|| 9.999999999943e-01
  0 KSP unpreconditioned resid norm 2.157845611701e+01 true resid norm 2.157845611701e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157845611690e+01 true resid norm 2.157845611690e+01 ||r(i)||/||b|| 9.999999999949e-01
  0 KSP unpreconditioned resid norm 2.157845255034e+01 true resid norm 2.157845255034e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157845255025e+01 true resid norm 2.157845255025e+01 ||r(i)||/||b|| 9.999999999956e-01
  0 KSP unpreconditioned resid norm 2.157844920388e+01 true resid norm 2.157844920388e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157844920379e+01 true resid norm 2.157844920379e+01 ||r(i)||/||b|| 9.999999999961e-01
  0 KSP unpreconditioned resid norm 2.157844607422e+01 true resid norm 2.157844607422e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157844607415e+01 true resid norm 2.157844607415e+01 ||r(i)||/||b|| 9.999999999966e-01
  0 KSP unpreconditioned resid norm 2.157844315693e+01 true resid norm 2.157844315693e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157844315687e+01 true resid norm 2.157844315687e+01 ||r(i)||/||b|| 9.999999999971e-01
  0 KSP unpreconditioned resid norm 2.157844044827e+01 true resid norm 2.157844044827e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157844044822e+01 true resid norm 2.157844044822e+01 ||r(i)||/||b|| 9.999999999975e-01
  0 KSP unpreconditioned resid norm 2.157843794377e+01 true resid norm 2.157843794377e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157843794373e+01 true resid norm 2.157843794373e+01 ||r(i)||/||b|| 9.999999999979e-01
  0 KSP unpreconditioned resid norm 2.157843563819e+01 true resid norm 2.157843563819e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157843563815e+01 true resid norm 2.157843563815e+01 ||r(i)||/||b|| 9.999999999982e-01
  0 KSP unpreconditioned resid norm 2.157843352838e+01 true resid norm 2.157843352838e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.157843352835e+01 true resid norm 2.157843352835e+01 ||r(i)||/||b|| 9.999999999985e-01
KSPGMRES, PC_LEFT
  type: gmres
  type: shell
    Shell: no name
    type: shell
  1 KSP preconditioned resid norm 3.326190403246e+06 true resid norm 2.531245015428e+01 ||r(i)||/||b|| 1.033250622238e+00
  0 KSP preconditioned resid norm 2.739717855655e+07 true resid norm 2.371669076695e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 2.985543379911e+06 true resid norm 2.498578718744e+01 ||r(i)||/||b|| 1.053510687176e+00
  0 KSP preconditioned resid norm 2.398796929309e+07 true resid norm 2.298427442616e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 2.704589856316e+06 true resid norm 2.460415108198e+01 ||r(i)||/||b|| 1.070477606810e+00
  0 KSP preconditioned resid norm 2.089236032515e+07 true resid norm 2.235588179878e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 2.386114462569e+06 true resid norm 2.416221471778e+01 ||r(i)||/||b|| 1.080799001142e+00
  0 KSP preconditioned resid norm 1.804685701080e+07 true resid norm 2.181662672264e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 2.064860185507e+06 true resid norm 2.378648886156e+01 ||r(i)||/||b|| 1.090291783600e+00
  0 KSP preconditioned resid norm 1.537564640323e+07 true resid norm 2.135564314362e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.777612345074e+06 true resid norm 2.327085270069e+01 ||r(i)||/||b|| 1.089681661385e+00
  0 KSP preconditioned resid norm 1.294279593659e+07 true resid norm 2.095726616172e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.488886320866e+06 true resid norm 2.279763848506e+01 ||r(i)||/||b|| 1.087815476940e+00
  0 KSP preconditioned resid norm 1.098084576735e+07 true resid norm 2.060917986542e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.248376549327e+06 true resid norm 2.240008012911e+01 ||r(i)||/||b|| 1.086898182042e+00
  0 KSP preconditioned resid norm 9.019561456782e+06 true resid norm 2.030700962013e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.085939671118e+06 true resid norm 2.185134911519e+01 ||r(i)||/||b|| 1.076049577163e+00
  0 KSP preconditioned resid norm 7.300050101780e+06 true resid norm 2.002931432764e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 9.269346186616e+05 true resid norm 2.142563478176e+01 ||r(i)||/||b|| 1.069713841986e+00
  0 KSP preconditioned resid norm 5.652884669299e+06 true resid norm 1.978066555523e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 7.640771390486e+05 true resid norm 2.081442904500e+01 ||r(i)||/||b|| 1.052261309756e+00
  0 KSP preconditioned resid norm 4.353524975065e+06 true resid norm 1.953549132711e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 6.522143761649e+05 true resid norm 2.038404011524e+01 ||r(i)||/||b|| 1.043436265509e+00
  0 KSP preconditioned resid norm 3.252964898432e+06 true resid norm 1.930842328583e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.888698887425e+05 true resid norm 1.996299465284e+01 ||r(i)||/||b|| 1.033900819208e+00
  0 KSP preconditioned resid norm 2.168021537227e+06 true resid norm 1.909903544303e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.273941824146e+05 true resid norm 1.909882021881e+01 ||r(i)||/||b|| 9.999887311469e-01
  0 KSP preconditioned resid norm 1.586502807500e+06 true resid norm 1.887928409919e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.178978804995e+05 true resid norm 1.856683729467e+01 ||r(i)||/||b|| 9.834502832374e-01
  0 KSP preconditioned resid norm 1.431338236002e+06 true resid norm 1.866755324771e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.555432571318e+05 true resid norm 1.787118772154e+01 ||r(i)||/||b|| 9.573395872721e-01
  0 KSP preconditioned resid norm 1.582521011603e+06 true resid norm 1.843935677484e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.587356003840e+05 true resid norm 1.737293879753e+01 ||r(i)||/||b|| 9.421662051267e-01
  0 KSP preconditioned resid norm 1.777657485855e+06 true resid norm 1.819422251827e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.564970760440e+05 true resid norm 1.692681114533e+01 ||r(i)||/||b|| 9.303398992913e-01
  0 KSP preconditioned resid norm 1.999077015429e+06 true resid norm 1.794019518905e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.458049215411e+05 true resid norm 1.647145265048e+01 ||r(i)||/||b|| 9.181311840204e-01
  0 KSP preconditioned resid norm 2.424910751426e+06 true resid norm 1.767662653672e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.905388652516e+05 true resid norm 1.589708321984e+01 ||r(i)||/||b|| 8.993278885439e-01
  0 KSP preconditioned resid norm 2.715994507752e+06 true resid norm 1.739285389935e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 6.036420443800e+05 true resid norm 1.546755011591e+01 ||r(i)||/||b|| 8.893048952988e-01
  0 KSP preconditioned resid norm 2.943690175475e+06 true resid norm 1.710685763894e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 6.110770046581e+05 true resid norm 1.504284205561e+01 ||r(i)||/||b|| 8.793457204766e-01
  0 KSP preconditioned resid norm 3.106563874030e+06 true resid norm 1.681871238642e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 6.130852802303e+05 true resid norm 1.462182107711e+01 ||r(i)||/||b|| 8.693781510243e-01
  0 KSP preconditioned resid norm 3.249647903316e+06 true resid norm 1.652805161407e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 6.237777317436e+05 true resid norm 1.421217230878e+01 ||r(i)||/||b|| 8.598818929560e-01
  0 KSP preconditioned resid norm 3.505778194861e+06 true resid norm 1.623539189854e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 6.649340496776e+05 true resid norm 1.372091894621e+01 ||r(i)||/||b|| 8.451239755687e-01
  0 KSP preconditioned resid norm 3.614023619525e+06 true resid norm 1.592895541303e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 6.580559265000e+05 true resid norm 1.331584489444e+01 ||r(i)||/||b|| 8.359521732068e-01
  0 KSP preconditioned resid norm 3.612719298355e+06 true resid norm 1.561953501424e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 6.409861473171e+05 true resid norm 1.293121872461e+01 ||r(i)||/||b|| 8.278875595732e-01
  0 KSP preconditioned resid norm 3.682898478437e+06 true resid norm 1.530924035448e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 6.378580277190e+05 true resid norm 1.254828687949e+01 ||r(i)||/||b|| 8.196544432606e-01
  0 KSP preconditioned resid norm 3.684533662575e+06 true resid norm 1.499705950414e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 6.252042755207e+05 true resid norm 1.218146666248e+01 ||r(i)||/||b|| 8.122570067228e-01
  0 KSP preconditioned resid norm 3.676724155194e+06 true resid norm 1.468434339290e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 6.125142514911e+05 true resid norm 1.181586893460e+01 ||r(i)||/||b|| 8.046576287719e-01
  0 KSP preconditioned resid norm 3.620367728015e+06 true resid norm 1.437037340014e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.808303064703e+05 true resid norm 1.157893236061e+01 ||r(i)||/||b|| 8.057502778947e-01
  0 KSP preconditioned resid norm 3.543322081458e+06 true resid norm 1.407046606575e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.593075952540e+05 true resid norm 1.124436574706e+01 ||r(i)||/||b|| 7.991466447893e-01
  0 KSP preconditioned resid norm 3.558315700017e+06 true resid norm 1.377033063671e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.525329570906e+05 true resid norm 1.091483048471e+01 ||r(i)||/||b|| 7.926338715216e-01
  0 KSP preconditioned resid norm 3.501953125956e+06 true resid norm 1.346970900090e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.250987417525e+05 true resid norm 1.061212582212e+01 ||r(i)||/||b|| 7.878511570969e-01
  0 KSP preconditioned resid norm 3.443232987950e+06 true resid norm 1.317136990909e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.091549308229e+05 true resid norm 1.030998391524e+01 ||r(i)||/||b|| 7.827571457184e-01
  0 KSP preconditioned resid norm 3.434870831821e+06 true resid norm 1.287467557686e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.996859001509e+05 true resid norm 1.002059602578e+01 ||r(i)||/||b|| 7.783183324472e-01
  0 KSP preconditioned resid norm 3.270778963071e+06 true resid norm 1.258054858293e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.576251976483e+05 true resid norm 9.818167062907e+00 ||r(i)||/||b|| 7.804243986805e-01
  0 KSP preconditioned resid norm 3.259919991031e+06 true resid norm 1.229892817656e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.477657910940e+05 true resid norm 9.534913132080e+00 ||r(i)||/||b|| 7.752637461735e-01
  Residual norms for sys_ solve.
  0 KSP preconditioned resid norm 3.172192156953e+06 true resid norm 1.201794272161e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.318821165868e+05 true resid norm 9.268263835589e+00 ||r(i)||/||b|| 7.712021974380e-01
  0 KSP preconditioned resid norm 3.053034260242e+06 true resid norm 1.173921931783e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.090788264954e+05 true resid norm 9.020642294914e+00 ||r(i)||/||b|| 7.684192662803e-01
  0 KSP preconditioned resid norm 3.034373397350e+06 true resid norm 1.146428878811e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 3.980500829475e+05 true resid norm 8.772973461987e+00 ||r(i)||/||b|| 7.652435858986e-01
  0 KSP preconditioned resid norm 3.004418256680e+06 true resid norm 1.119280483666e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 3.841951522731e+05 true resid norm 8.519830722873e+00 ||r(i)||/||b|| 7.611881782278e-01
  0 KSP preconditioned resid norm 2.901703208103e+06 true resid norm 1.092326556480e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 3.534918573625e+05 true resid norm 8.365143541591e+00 ||r(i)||/||b|| 7.658097747385e-01
  0 KSP preconditioned resid norm 2.779906981032e+06 true resid norm 1.066752802537e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 3.384394939081e+05 true resid norm 8.144412112574e+00 ||r(i)||/||b|| 7.634769829713e-01
  0 KSP preconditioned resid norm 2.752947655142e+06 true resid norm 1.041533213584e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 3.325198316312e+05 true resid norm 7.917864085967e+00 ||r(i)||/||b|| 7.602123468267e-01
  0 KSP preconditioned resid norm 2.601890784580e+06 true resid norm 1.016542026399e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 3.143795455205e+05 true resid norm 7.722666750943e+00 ||r(i)||/||b|| 7.596997025590e-01
  0 KSP preconditioned resid norm 2.576814867294e+06 true resid norm 9.920904934448e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 3.062745658802e+05 true resid norm 7.518974859238e+00 ||r(i)||/||b|| 7.578920379662e-01
  0 KSP preconditioned resid norm 2.479362065138e+06 true resid norm 9.680474751189e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 2.830021040096e+05 true resid norm 7.403333537707e+00 ||r(i)||/||b|| 7.647696758672e-01
  0 KSP preconditioned resid norm 2.453276712245e+06 true resid norm 9.454328940381e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 2.769713948431e+05 true resid norm 7.205675984388e+00 ||r(i)||/||b|| 7.621562598284e-01
  0 KSP preconditioned resid norm 2.420658102754e+06 true resid norm 9.230656170662e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 2.689179448946e+05 true resid norm 7.012371831525e+00 ||r(i)||/||b|| 7.596829198137e-01
  0 KSP preconditioned resid norm 2.381798306664e+06 true resid norm 9.009683706803e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 2.585112062893e+05 true resid norm 6.821739997113e+00 ||r(i)||/||b|| 7.571564351323e-01
  0 KSP preconditioned resid norm 2.220455530106e+06 true resid norm 8.791330604159e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 2.440953633311e+05 true resid norm 6.654064814482e+00 ||r(i)||/||b|| 7.568893850192e-01
  0 KSP preconditioned resid norm 2.190272125145e+06 true resid norm 8.577039200533e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 2.393910756559e+05 true resid norm 6.486692899451e+00 ||r(i)||/||b|| 7.562857937093e-01
  0 KSP preconditioned resid norm 2.095597787750e+06 true resid norm 8.367095931284e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 2.191263466853e+05 true resid norm 6.405265620859e+00 ||r(i)||/||b|| 7.655303194158e-01
  0 KSP preconditioned resid norm 2.070034339137e+06 true resid norm 8.171680944025e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 2.160349866917e+05 true resid norm 6.244100217255e+00 ||r(i)||/||b|| 7.641145389825e-01
  0 KSP preconditioned resid norm 1.868248465769e+06 true resid norm 7.979246042756e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.986818842845e+05 true resid norm 6.111397264299e+00 ||r(i)||/||b|| 7.659116201646e-01
  0 KSP preconditioned resid norm 1.856855773564e+06 true resid norm 7.792134975860e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.965876687782e+05 true resid norm 5.961833143292e+00 ||r(i)||/||b|| 7.651090698200e-01
  0 KSP preconditioned resid norm 1.838299065304e+06 true resid norm 7.608397544412e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.934149405686e+05 true resid norm 5.816692415991e+00 ||r(i)||/||b|| 7.645095280625e-01
  0 KSP preconditioned resid norm 1.813798278927e+06 true resid norm 7.428099200893e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.866811261665e+05 true resid norm 5.660243617741e+00 ||r(i)||/||b|| 7.620043115553e-01
  0 KSP preconditioned resid norm 1.782955009713e+06 true resid norm 7.249607980355e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.832503284453e+05 true resid norm 5.519996301435e+00 ||r(i)||/||b|| 7.614199714513e-01
  0 KSP preconditioned resid norm 1.697128864164e+06 true resid norm 7.074208920079e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.678408915526e+05 true resid norm 5.461841748483e+00 ||r(i)||/||b|| 7.720780952596e-01
  0 KSP preconditioned resid norm 1.675173119033e+06 true resid norm 6.911947179044e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.658616776605e+05 true resid norm 5.329467567316e+00 ||r(i)||/||b|| 7.710515473085e-01
  0 KSP preconditioned resid norm 1.648286216220e+06 true resid norm 6.752185425735e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.635009273971e+05 true resid norm 5.201437885076e+00 ||r(i)||/||b|| 7.703339818323e-01
  0 KSP preconditioned resid norm 1.617441750669e+06 true resid norm 6.595076705042e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.583840611129e+05 true resid norm 5.068618832054e+00 ||r(i)||/||b|| 7.685458499942e-01
  0 KSP preconditioned resid norm 1.583093377110e+06 true resid norm 6.439815953734e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.554852141056e+05 true resid norm 4.948536450529e+00 ||r(i)||/||b|| 7.684282417513e-01
  0 KSP preconditioned resid norm 1.546190059323e+06 true resid norm 6.287556445923e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.518142544927e+05 true resid norm 4.831913836625e+00 ||r(i)||/||b|| 7.684883433148e-01
  0 KSP preconditioned resid norm 1.507347991932e+06 true resid norm 6.138314859752e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.485349878036e+05 true resid norm 4.719705970390e+00 ||r(i)||/||b|| 7.688927789183e-01
  0 KSP preconditioned resid norm 1.467165939355e+06 true resid norm 5.992268384007e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.451355088920e+05 true resid norm 4.611208646233e+00 ||r(i)||/||b|| 7.695263881270e-01
  0 KSP preconditioned resid norm 1.426138416021e+06 true resid norm 5.849468139787e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.416581839486e+05 true resid norm 4.506268079239e+00 ||r(i)||/||b|| 7.703722751455e-01
  0 KSP preconditioned resid norm 1.384716199542e+06 true resid norm 5.709993533895e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.381375465248e+05 true resid norm 4.404754648299e+00 ||r(i)||/||b|| 7.714114949784e-01
  0 KSP preconditioned resid norm 1.343217801689e+06 true resid norm 5.573991762446e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.336766508402e+05 true resid norm 4.298834355166e+00 ||r(i)||/||b|| 7.712308410875e-01
  0 KSP preconditioned resid norm 1.263318472124e+06 true resid norm 5.440643300800e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.229061513148e+05 true resid norm 4.258402282173e+00 ||r(i)||/||b|| 7.827019796624e-01
  0 KSP preconditioned resid norm 1.232003833318e+06 true resid norm 5.317697008472e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.205732909782e+05 true resid norm 4.162024122374e+00 ||r(i)||/||b|| 7.826741756335e-01
  0 KSP preconditioned resid norm 1.199738090351e+06 true resid norm 5.197158865745e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.181603724903e+05 true resid norm 4.068828287786e+00 ||r(i)||/||b|| 7.828947301581e-01
  0 KSP preconditioned resid norm 1.167193419368e+06 true resid norm 5.079125553250e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.145097492727e+05 true resid norm 3.971508985598e+00 ||r(i)||/||b|| 7.819277046728e-01
  0 KSP preconditioned resid norm 1.134138422293e+06 true resid norm 4.962980581716e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.120327011254e+05 true resid norm 3.883681905022e+00 ||r(i)||/||b|| 7.825301431422e-01
  0 KSP preconditioned resid norm 1.101437419072e+06 true resid norm 4.849442186416e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.095501233318e+05 true resid norm 3.798716850114e+00 ||r(i)||/||b|| 7.833306809502e-01
  0 KSP preconditioned resid norm 1.069277856788e+06 true resid norm 4.738577116081e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.070738547239e+05 true resid norm 3.716488594701e+00 ||r(i)||/||b|| 7.843047614629e-01
  0 KSP preconditioned resid norm 1.037845966207e+06 true resid norm 4.630413655426e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.046150346447e+05 true resid norm 3.636866352352e+00 ||r(i)||/||b|| 7.854301198533e-01
  0 KSP preconditioned resid norm 1.007234825617e+06 true resid norm 4.524959668423e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.021813999423e+05 true resid norm 3.559730545606e+00 ||r(i)||/||b|| 7.866877953514e-01
  0 KSP preconditioned resid norm 9.775544860869e+05 true resid norm 4.422214818400e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 9.978202070196e+04 true resid norm 3.484975873129e+00 ||r(i)||/||b|| 7.880611902045e-01
  0 KSP preconditioned resid norm 9.488609834218e+05 true resid norm 4.322172601371e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 9.695389359777e+04 true resid norm 3.413565002392e+00 ||r(i)||/||b|| 7.897798901666e-01
  0 KSP preconditioned resid norm 9.214696118785e+05 true resid norm 4.224931074095e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 9.469902137132e+04 true resid norm 3.343044994122e+00 ||r(i)||/||b|| 7.912661616234e-01
  0 KSP preconditioned resid norm 8.950870845934e+05 true resid norm 4.130303027271e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 9.249056720311e+04 true resid norm 3.274627825583e+00 ||r(i)||/||b|| 7.928299216694e-01
  0 KSP preconditioned resid norm 8.697116035575e+05 true resid norm 4.038264984480e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 9.033257697530e+04 true resid norm 3.208233542281e+00 ||r(i)||/||b|| 7.944584009745e-01
  0 KSP preconditioned resid norm 8.453211685827e+05 true resid norm 3.948772501683e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 8.832091875377e+04 true resid norm 3.135915021542e+00 ||r(i)||/||b|| 7.941493262034e-01
  0 KSP preconditioned resid norm 8.216797599086e+05 true resid norm 3.860864783139e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 8.627413642680e+04 true resid norm 3.072738717485e+00 ||r(i)||/||b|| 7.958679959226e-01
  0 KSP preconditioned resid norm 7.990572823054e+05 true resid norm 3.775421922124e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 8.429384370232e+04 true resid norm 3.011315430521e+00 ||r(i)||/||b|| 7.976103049236e-01
  0 KSP preconditioned resid norm 7.775271519173e+05 true resid norm 3.692383052567e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 8.240098058835e+04 true resid norm 2.950876336403e+00 ||r(i)||/||b|| 7.991793631356e-01
  0 KSP preconditioned resid norm 7.569577849408e+05 true resid norm 3.611590620066e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 8.021366473130e+04 true resid norm 2.883326560866e+00 ||r(i)||/||b|| 7.983536519466e-01
  0 KSP preconditioned resid norm 7.372058650320e+05 true resid norm 3.531991730980e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 7.846201564563e+04 true resid norm 2.825437860461e+00 ||r(i)||/||b|| 7.999559669628e-01
  0 KSP preconditioned resid norm 7.186823859844e+05 true resid norm 3.454565775181e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 7.645454100739e+04 true resid norm 2.768756790850e+00 ||r(i)||/||b|| 8.014775144078e-01
  0 KSP preconditioned resid norm 7.009039532540e+05 true resid norm 3.379179961144e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 7.486783277284e+04 true resid norm 2.714470428131e+00 ||r(i)||/||b|| 8.032926506856e-01
  0 KSP preconditioned resid norm 6.840035421923e+05 true resid norm 3.306002268451e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 7.338169307917e+04 true resid norm 2.661150947295e+00 ||r(i)||/||b|| 8.049452877543e-01
  0 KSP preconditioned resid norm 6.678461027472e+05 true resid norm 3.234883797893e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 7.196913479431e+04 true resid norm 2.609287164254e+00 ||r(i)||/||b|| 8.066092407876e-01
  0 KSP preconditioned resid norm 8.531343595954e+05 true resid norm 3.165764666136e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 8.956336475838e+04 true resid norm 2.521315542277e+00 ||r(i)||/||b|| 7.964317655217e-01
  0 KSP preconditioned resid norm 6.292647185788e+05 true resid norm 3.093937251808e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 7.011128214676e+04 true resid norm 2.491404712539e+00 ||r(i)||/||b|| 8.052537946861e-01
  0 KSP preconditioned resid norm 6.160959509194e+05 true resid norm 3.026711288751e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 6.875586200945e+04 true resid norm 2.444088996183e+00 ||r(i)||/||b|| 8.075064857579e-01
  0 KSP preconditioned resid norm 7.815185589219e+05 true resid norm 2.961675578465e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 8.278556066066e+04 true resid norm 2.379210401763e+00 ||r(i)||/||b|| 8.033325523777e-01
  0 KSP preconditioned resid norm 7.491615754964e+05 true resid norm 2.896460468227e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 7.941120293494e+04 true resid norm 2.333595475113e+00 ||r(i)||/||b|| 8.056714395767e-01
  0 KSP preconditioned resid norm 5.579588092092e+05 true resid norm 2.833310835280e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 6.440154417880e+04 true resid norm 2.303284797087e+00 ||r(i)||/||b|| 8.129305010970e-01
  0 KSP preconditioned resid norm 7.057244594752e+05 true resid norm 2.773775200151e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 7.536475866720e+04 true resid norm 2.246904523683e+00 ||r(i)||/||b|| 8.100528563239e-01
  0 KSP preconditioned resid norm 5.287715404536e+05 true resid norm 2.714588693329e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 6.209681179962e+04 true resid norm 2.216634008273e+00 ||r(i)||/||b|| 8.165634866602e-01
  0 KSP preconditioned resid norm 6.664516334566e+05 true resid norm 2.658629965864e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 7.097273715040e+04 true resid norm 2.170460851956e+00 ||r(i)||/||b|| 8.163832048175e-01
  0 KSP preconditioned resid norm 6.420836267732e+05 true resid norm 2.603823752210e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 6.903864799610e+04 true resid norm 2.130605237826e+00 ||r(i)||/||b|| 8.182601591286e-01
  0 KSP preconditioned resid norm 6.193302600381e+05 true resid norm 2.550665176560e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 6.704534961724e+04 true resid norm 2.092035652085e+00 ||r(i)||/||b|| 8.201921880262e-01
  0 KSP preconditioned resid norm 5.976420790614e+05 true resid norm 2.499151338168e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 6.546930715790e+04 true resid norm 2.054795926720e+00 ||r(i)||/||b|| 8.221974777348e-01
  0 KSP preconditioned resid norm 5.772898952473e+05 true resid norm 2.449292672055e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 6.440150776633e+04 true resid norm 2.021639958784e+00 ||r(i)||/||b|| 8.253974634594e-01
  0 KSP preconditioned resid norm 5.547841050974e+05 true resid norm 2.401408442841e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 6.228612830103e+04 true resid norm 1.979081832781e+00 ||r(i)||/||b|| 8.241337864373e-01
  0 KSP preconditioned resid norm 5.376605545187e+05 true resid norm 2.353824830851e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 6.055950684309e+04 true resid norm 1.944852018306e+00 ||r(i)||/||b|| 8.262518063434e-01
  0 KSP preconditioned resid norm 5.214100388903e+05 true resid norm 2.307863909267e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.932210437804e+04 true resid norm 1.910951849107e+00 ||r(i)||/||b|| 8.280175626620e-01
  0 KSP preconditioned resid norm 5.058714302270e+05 true resid norm 2.263359307558e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.816625925645e+04 true resid norm 1.877879065313e+00 ||r(i)||/||b|| 8.296866781343e-01
  0 KSP preconditioned resid norm 4.909388121577e+05 true resid norm 2.220245909459e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.683093636919e+04 true resid norm 1.846200177286e+00 ||r(i)||/||b|| 8.315295929252e-01
  0 KSP preconditioned resid norm 5.329998823527e+05 true resid norm 2.178553811154e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.764658710799e+04 true resid norm 1.808861909494e+00 ||r(i)||/||b|| 8.303039843368e-01
  0 KSP preconditioned resid norm 5.127089481864e+05 true resid norm 2.137735868222e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.649958417254e+04 true resid norm 1.778557910112e+00 ||r(i)||/||b|| 8.319820687629e-01
  0 KSP preconditioned resid norm 4.941990340779e+05 true resid norm 2.098271544633e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.540230497975e+04 true resid norm 1.748798414302e+00 ||r(i)||/||b|| 8.334471383243e-01
  0 KSP preconditioned resid norm 4.765332435448e+05 true resid norm 2.060023230178e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.448913305182e+04 true resid norm 1.719948826180e+00 ||r(i)||/||b|| 8.349171994685e-01
  0 KSP preconditioned resid norm 4.598768923070e+05 true resid norm 2.022998527969e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.367349522674e+04 true resid norm 1.691924815438e+00 ||r(i)||/||b|| 8.363450551478e-01
  0 KSP preconditioned resid norm 4.441185294518e+05 true resid norm 1.987164947737e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.295086254071e+04 true resid norm 1.664720017972e+00 ||r(i)||/||b|| 8.377362029595e-01
  0 KSP preconditioned resid norm 4.291593856471e+05 true resid norm 1.952496796024e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.223021837007e+04 true resid norm 1.638485564698e+00 ||r(i)||/||b|| 8.391745215840e-01
  0 KSP preconditioned resid norm 4.085759008593e+05 true resid norm 1.918983748348e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.970724068852e+04 true resid norm 1.610952094581e+00 ||r(i)||/||b|| 8.394818851214e-01
  0 KSP preconditioned resid norm 3.957620749449e+05 true resid norm 1.886222568820e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.898689575863e+04 true resid norm 1.586020603508e+00 ||r(i)||/||b|| 8.408448874091e-01
  0 KSP preconditioned resid norm 3.834217221234e+05 true resid norm 1.854589698767e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.820595775150e+04 true resid norm 1.562013755714e+00 ||r(i)||/||b|| 8.422422257343e-01
  0 KSP preconditioned resid norm 3.715334666535e+05 true resid norm 1.824073602450e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.749144042261e+04 true resid norm 1.538734973139e+00 ||r(i)||/||b|| 8.435706602370e-01
  0 KSP preconditioned resid norm 3.600573676075e+05 true resid norm 1.794640301052e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.694536665814e+04 true resid norm 1.516013466664e+00 ||r(i)||/||b|| 8.447450253825e-01
  0 KSP preconditioned resid norm 3.489263161490e+05 true resid norm 1.766239187375e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.644564069678e+04 true resid norm 1.494006596876e+00 ||r(i)||/||b|| 8.458687858107e-01
  0 KSP preconditioned resid norm 3.380248715629e+05 true resid norm 1.738841235180e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.597555438996e+04 true resid norm 1.472697677485e+00 ||r(i)||/||b|| 8.469420023461e-01
  0 KSP preconditioned resid norm 3.667659247721e+05 true resid norm 1.712424571470e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.654252119480e+04 true resid norm 1.456001910831e+00 ||r(i)||/||b|| 8.502575442383e-01
  0 KSP preconditioned resid norm 3.522015594938e+05 true resid norm 1.687212156903e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.596138857678e+04 true resid norm 1.435996865255e+00 ||r(i)||/||b|| 8.511062816727e-01
  0 KSP preconditioned resid norm 3.382009852103e+05 true resid norm 1.662887023898e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.541846169028e+04 true resid norm 1.416555058016e+00 ||r(i)||/||b|| 8.518648817735e-01
  0 KSP preconditioned resid norm 3.798035449734e+05 true resid norm 1.639439971116e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.775345622551e+04 true resid norm 1.395931502986e+00 ||r(i)||/||b|| 8.514685060634e-01
  0 KSP preconditioned resid norm 3.613921495049e+05 true resid norm 1.616423964217e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.743150028153e+04 true resid norm 1.378512077811e+00 ||r(i)||/||b|| 8.528159123643e-01
  0 KSP preconditioned resid norm 3.356994988466e+05 true resid norm 1.594340402057e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.506596460379e+04 true resid norm 1.360303797588e+00 ||r(i)||/||b|| 8.532078819759e-01
  0 KSP preconditioned resid norm 3.206346919057e+05 true resid norm 1.572943344035e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.434672197720e+04 true resid norm 1.343368476274e+00 ||r(i)||/||b|| 8.540475926032e-01
  0 KSP preconditioned resid norm 3.063520836504e+05 true resid norm 1.552353359558e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.367414545423e+04 true resid norm 1.327016733209e+00 ||r(i)||/||b|| 8.548419243843e-01
  0 KSP preconditioned resid norm 2.925462634954e+05 true resid norm 1.532546815866e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.296484647842e+04 true resid norm 1.311124848703e+00 ||r(i)||/||b|| 8.555202589106e-01
  0 KSP preconditioned resid norm 2.796269808233e+05 true resid norm 1.513506025755e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.236050537716e+04 true resid norm 1.295839678441e+00 ||r(i)||/||b|| 8.561840233140e-01
  0 KSP preconditioned resid norm 2.673886535798e+05 true resid norm 1.495205690876e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.182543921288e+04 true resid norm 1.281043033911e+00 ||r(i)||/||b|| 8.567670934696e-01
  0 KSP preconditioned resid norm 2.557837875988e+05 true resid norm 1.477613168990e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.131257469770e+04 true resid norm 1.266876951660e+00 ||r(i)||/||b|| 8.573806583802e-01
  0 KSP preconditioned resid norm 2.675278069922e+05 true resid norm 1.460719526562e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.160603922336e+04 true resid norm 1.253134495738e+00 ||r(i)||/||b|| 8.578885083351e-01
  0 KSP preconditioned resid norm 2.540205307633e+05 true resid norm 1.444475156985e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.102403005834e+04 true resid norm 1.239431346704e+00 ||r(i)||/||b|| 8.580496111067e-01
  0 KSP preconditioned resid norm 2.413933374247e+05 true resid norm 1.428827657938e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.048999459623e+04 true resid norm 1.226568946489e+00 ||r(i)||/||b|| 8.584442914969e-01
  0 KSP preconditioned resid norm 2.295119387968e+05 true resid norm 1.413798173390e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 3.998525341569e+04 true resid norm 1.214114300457e+00 ||r(i)||/||b|| 8.587606939296e-01
  0 KSP preconditioned resid norm 2.426436147259e+05 true resid norm 1.399360438391e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.061485597116e+04 true resid norm 1.199471088761e+00 ||r(i)||/||b|| 8.571566380284e-01
  0 KSP preconditioned resid norm 2.291137137931e+05 true resid norm 1.385157105880e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 3.997559455883e+04 true resid norm 1.187549761533e+00 ||r(i)||/||b|| 8.573393996187e-01
  0 KSP preconditioned resid norm 2.165612328469e+05 true resid norm 1.371506164050e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 3.939565247596e+04 true resid norm 1.176493841104e+00 ||r(i)||/||b|| 8.578115592494e-01
  0 KSP preconditioned resid norm 2.048408604369e+05 true resid norm 1.358430111565e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 3.884655241270e+04 true resid norm 1.165686483196e+00 ||r(i)||/||b|| 8.581129594173e-01
  0 KSP preconditioned resid norm 1.938887692107e+05 true resid norm 1.345886911627e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 3.835195733928e+04 true resid norm 1.155381453428e+00 ||r(i)||/||b|| 8.584535917893e-01
  0 KSP preconditioned resid norm 1.973039893100e+05 true resid norm 1.333859485126e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 3.855817703015e+04 true resid norm 1.149964427844e+00 ||r(i)||/||b|| 8.621331112214e-01
  0 KSP preconditioned resid norm 1.862683499978e+05 true resid norm 1.322563930533e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 3.797803334707e+04 true resid norm 1.140369682865e+00 ||r(i)||/||b|| 8.622416327398e-01
dr. ir. Christiaan Klaij
CFD Researcher
Research & Development
E mailto:C.Klaij at marin.nl
T +31 317 49 33 44
MARIN
2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands
T +31 317 49 39 11, F +31 317 49 32 45, I www.marin.nl
