[petsc-users] one compilation error in PETSc-dev with enabling GPU and complex number
Sun Jan 29 13:43:42 CST 2012
On Sun, Jan 29, 2012 at 1:35 PM, recrusader <recrusader at gmail.com> wrote:
> Dear Matt,
> Without PETSc library calls, the errors, that is
> "/opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(51):>>
> error: a value of type "int" cannot be assigned to an entity of type
> "_ZNSt7complexIdE9_ComplexTE",
> disappear.
> Since I meet the errors when compiling PETSc-dev, is it possible to run
> PETSc example?
1) If you have an error compiling petsc-dev ALWAYS send make.log to
petsc-maint at mcs.anl.gov
2) petsc-dev only works with the latest cusp-dev from the repository
  Thanks
     Matt
> Thank you very much.
> Best,
> Yujie
> On Sun, Jan 29, 2012 at 1:29 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Sun, Jan 29, 2012 at 1:24 PM, recrusader <recrusader at gmail.com> wrote:
>>> I have thought I send this question to CUSP mailing list. Therefore, I
>>> wish I could get the same errors using the simple codes. However, the
>>> errors disappear.
>> The code below has no PETSc library calls. I really do not understand
>> what you are asking.
>> Can you run a simple PETSc example with the GPU?
>>   cd src/snes/examples/tutorials
>>   make ex5
>>   ./ex5 -vec_type cusp -log_summary
>>   Matt
>>> Is it possible to provide simple codes with PETSc to show the errors?
>>> Thanks again.
>>> Best,
>>> Yujie
>>> On Sun, Jan 29, 2012 at 1:20 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>> On Sun, Jan 29, 2012 at 1:05 PM, recrusader <recrusader at gmail.com>wrote:
>>>>> Thank you very much, Matt,
>>>>> You mean the headers of the simple codes, I further simply the codes as
>>>> This is a question for the CUSP mailing list.
>>>>   Thanks,
>>>>      Matt
>>>>> #include <cusp/blas.h>
>>>>> #include <cusp/array1d.h>
>>>>> int main(void)
>>>>>    cusp::array1d<std::complex<double>, cusp::host_memory> *x;
>>>>>    x=new cusp::array1d<std::complex<double>, cusp::host_memory>(2,0.0);
>>>>>    std::complex<double> alpha(1,2.0);
>>>>>    cusp::blas::scal(*x,alpha);
>>>>>    return 0;
>>>>> I got the same compilation results "
>>>>> login1$ nvcc gputest.cu -o gputest
>>>>> /opt/apps/cuda/4.0/cuda/bin/../include/cusp/detail/blas.inl(134):
>>>>> warning: calling a __host__ function from a __host__ __device__
>>>>> function is not allowed
>>>>>          detected during:
>>>>>            instantiation of "void
>>>>> cusp::blas::detail::SCAL<T>::operator()(T2 &) [with
>>>>> T=std::complex<double>, T2=std::complex<double>]"
>>>>> /opt/apps/cuda/4.0/cuda/bin/../include/thrust/detail/host/for_each.inl(37):
>>>>> here
>>>>>            instantiation of "InputIterator
>>>>> thrust::detail::host::for_each(InputIterator, InputIterator,
>>>>> UnaryFunction) [with
>>>>> InputIterator=thrust::detail::normal_iterator<std::complex<double> *>,
>>>>> UnaryFunction=cusp::blas::detail::SCAL<std::complex<double>>]"
>>>>> /opt/apps/cuda/4.0/cuda/bin/../include/thrust/detail/dispatch/for_each.h(46):
>>>>> here
>>>>> thrust::detail::dispatch::for_each(InputIterator, InputIterator,
>>>>> UnaryFunction, thrust::host_space_tag) [with
>>>>> /opt/apps/cuda/4.0/cuda/bin/../include/thrust/detail/for_each.inl(51):
>>>>> here
>>>>> thrust::detail::for_each(InputIterator, InputIterator, UnaryFunction)
>>>>> [with
>>>>> *>, UnaryFunction=cusp::blas::detail::SCAL<std::complex<double>>]"
>>>>> /opt/apps/cuda/4.0/cuda/bin/../include/thrust/detail/for_each.inl(67):
>>>>> here
>>>>>            instantiation of "void thrust::for_each(InputIterator,
>>>>> InputIterator, UnaryFunction) [with
>>>>> (367): here
>>>>> cusp::blas::detail::scal(ForwardIterator, ForwardIterator, ScalarType)
>>>>> [with
>>>>> ForwardIterator=thrust::detail::normal_iterator<std::complex<double>
>>>>> *>, ScalarType=std::complex<double>]"
>>>>> (748): here
>>>>>            instantiation of "void cusp::blas::scal(Array &,
>>>>> ScalarType) [with Array=cusp::array1d<std::complex<double>,
>>>>> cusp::host_memory>, ScalarType=std::complex<double>]"
>>>>> gputest.cu(25): here
>>>>> Thanks a lot.
>>>>> Best,
>>>>> Yujie
>>>>> On 1/29/12, Matthew Knepley <knepley at gmail.com> wrote:
>>>>> > On Sun, Jan 29, 2012 at 12:53 PM, recrusader <recrusader at gmail.com>
>>>>> wrote:
>>>>> >> Dear PETSc developers,
>>>>> >> With your help, I can successfully PETSc-deve with enabling GPU and
>>>>> >> complex number.
>>>>> >> However, when I compiled the codes, I met some errors. I also tried
>>>>> to
>>>>> >> use simple codes to realize the same function. However, the errors
>>>>> >> disappear. One example is as follows:
>>>>> >> for the function "VecScale_SeqCUSP"
>>>>> >> "#undef __FUNCT__
>>>>> >> #define __FUNCT__ "VecScale_SeqCUSP"
>>>>> >> PetscErrorCode VecScale_SeqCUSP(Vec xin, PetscScalar alpha)
>>>>> >>  CUSPARRAY      *xarray;
>>>>> >>  PetscErrorCode ierr;
>>>>> >>  PetscFunctionBegin;
>>>>> >>  if (alpha == 0.0) {
>>>>> >>    ierr = VecSet_SeqCUSP(xin,alpha);CHKERRQ(ierr);
>>>>> >>  } else if (alpha != 1.0) {
>>>>> >>    ierr = VecCUSPGetArrayReadWrite(xin,&xarray);CHKERRQ(ierr);
>>>>> >>    try {
>>>>> >>      cusp::blas::scal(*xarray,alpha);
>>>>> >>    } catch(char* ex) {
>>>>> >>      SETERRQ1(PETSC_COMM_SELF,PETSC_ERR_LIB,"CUSP error: %s", ex);
>>>>> >>    ierr = VecCUSPRestoreArrayReadWrite(xin,&xarray);CHKERRQ(ierr);
>>>>> >>  ierr = WaitForGPU();CHKERRCUSP(ierr);
>>>>> >>  ierr = PetscLogFlops(xin->map->n);CHKERRQ(ierr);
>>>>> >>  PetscFunctionReturn(0);
>>>>> >> When I compiled PETSc-dev, I met the following errors:
>>>>> >> " /opt/apps/cuda/4.0/cuda/include/cusp/detail/blas.inl(134):
>>>>> warning:
>>>>> >> calling a __host__ function from a __host__ __device__ function is
>>>>> not
>>>>> >> allowed
>>>>> >>          detected during:
>>>>> >> T=std::complex<double>, T2=PetscScalar]"
>>>>> /opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/for_each.inl(72):
>>>>> >> here
>>>>> thrust::detail::device::cuda::for_each_n_closure<RandomAccessIterator,
>>>>> >> Size, UnaryFunction>::operator()() [with
>>>>> RandomAccessIterator=thrust::detail::normal_iterator<thrust::device_ptr<PetscScalar>>,
>>>>> >> Size=long,
>>>>> >> here
>>>>> thrust::detail::device::cuda::detail::launch_closure_by_value(NullaryFunction)
>>>>> >> [with
>>>>> NullaryFunction=thrust::detail::device::cuda::for_each_n_closure<thrust::detail::normal_iterator<thrust::device_ptr<PetscScalar>>,
>>>>> >> long, cusp::blas::detail::SCAL<std::complex<double>>>]"
>>>>> /opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(71):
>>>>> >> here
>>>>> >>            instantiation of "size_t
>>>>> thrust::detail::device::cuda::detail::closure_launcher_base<NullaryFunction,
>>>>> >> launch_by_value>::block_size_with_maximal_occupancy(size_t) [with
>>>>> >> long, cusp::blas::detail::SCAL<std::complex<double>>>,
>>>>> >> launch_by_value=true]"
>>>>> /opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(136):
>>>>> >> here
>>>>> >>            instantiation of "thrust::pair<size_t, size_t>
>>>>> thrust::detail::device::cuda::detail::closure_launcher<NullaryFunction>::configuration_with_maximal_occupancy(Size)
>>>>> >> [with
>>>>> >> long, cusp::blas::detail::SCAL<std::complex<double>>>, Size=long]"
>>>>> /opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(145):
>>>>> >> here
>>>>> >>            [ 6 instantiation contexts not shown ]
>>>>> >> UnaryFunction, thrust::device_space_tag) [with
>>>>> InputIterator=thrust::detail::normal_iterator<thrust::device_ptr<PetscScalar>>,
>>>>> >> /opt/apps/cuda/4.0/cuda/include/thrust/detail/for_each.inl(51): here
>>>>> UnaryFunction)
>>>>> >> [with
>>>>> >> /opt/apps/cuda/4.0/cuda/include/thrust/detail/for_each.inl(67): here
>>>>> >> (367): here
>>>>> ScalarType)
>>>>> >> [with
>>>>> ForwardIterator=thrust::detail::normal_iterator<thrust::device_ptr<PetscScalar>>,
>>>>> >> (748): here
>>>>> >> ScalarType) [with Array=cusp::array1d<PetscScalar,
>>>>> >> cusp::device_memory>, ScalarType=std::complex<double>]"
>>>>> >> veccusp.cu(1185): here
>>>>> >> However, I further realize simiar codes as
>>>>> >> #include <thrust/version.h>
>>>>> >> #include <cusp/version.h>
>>>>> >> #include <iostream>
>>>>> >> #include <complex>
>>>>> >> int main(void)
>>>>> >>    return 0;
>>>>> >> When I complied it using  "nvcc gputest.cu -o gputest", I only meet
>>>>> >> warning information as follows:
>>>>> >>          detected during:
>>>>> >> here
>>>>> >> here
>>>>> >> here
>>>>> UnaryFunction)
>>>>> >> [with
>>>>> >> here
>>>>> >> (367): here
>>>>> ScalarType)
>>>>> >> [with
>>>>> >> (748): here
>>>>> >> There are not errors like
>>>>> >> "_ZNSt7complexIdE9_ComplexTE" "
>>>>> >> Furthermore, the warning information is also different between
>>>>> >> PETSc-dev and simple codes.
>>>>> >> Could you give me some suggestion for this errors? Thank you very
>>>>> much.
>>>>> > The headers are complicated to get right. The whole point of what we
>>>>> did is
>>>>> > to give a way to use GPU
>>>>> > simply through the existing PETSc linear algebra interface.
>>>>> >    Matt
>>>>> >> Best,
>>>>> >> Yujie
>>>>> > What most experimenters take for granted before they begin their
>>>>> > experiments is infinitely more interesting than any results to which
>>>>> their
>>>>> > experiments lead.
>>>>> > -- Norbert Wiener
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120129/926a20f1/attachment-0001.htm>
