[petsc-users] Preallocation woes again
Fri Jan 27 12:14:14 CST 2012
On Fri, Jan 27, 2012 at 12:04 PM, Tabrez Ali <stali at geology.wisc.edu> wrote:
> Matt
> Thanks. Yes I can wait for a few weeks/months (its only a local memory
> footprint issue and in no way hampers my ability to solve problems).
> Btw just for curiosity are you using the same technique discussed by Barry?
Basically. You have to store indices while counting if you don't want to
overcount. This is the part he glosses over.
   Matt
> Maybe I am overlooking something trivial in his post.
> Tabrez
> On Jan 27, 2012, at 10:26 AM, Matthew Knepley wrote:
> On Fri, Jan 27, 2012 at 10:32 AM, Tabrez Ali <stali at geology.wisc.edu>wrote:
>> PETSc Gurus
>> First I want to thank you for patiently answering questions that I have
>> asked in past regarding preallocation. Unfortunately I am still having
>> problems.
>> I have a small unstructured FE (elasticity) code that uses PETSc.
>> Unfortunately I am not yet able to find an _efficient_ way of calculating
>> the non-zero structure so I simply overestimate the o_nz and d_nz values (=
>> dimension x max_number_of nodes _a_node_contributes_to) which means that my
>> stiffness matrix consumes at least 2X more memory. For example, for a
>> perfectly structured mesh of linear hexes this number is 3*27=81=o_nz=d_nz.
>> In complicated 3D linear tet/hex meshes that I have generated I rarely need
>> to set a value greater than 150. In general I have found that as long as I
>> keep DOF/core between 100-200K (assuming 1GB/per core) there is enough
>> local RAM left even when memory for stiffness matrix is overestimated by
>> 2X-6X.
>> In any case now I do want to preallocate exactly for better memory
>> performance and the ambiguity involved in choosing a reasonable o_nz/d_nz.
>> The way I am trying to do it involves loops like ...
>> do i=1, num_local_elements
>>   do j=1, num_total_nodes
>>   end do
>> end do
>> or using lists that involve searches.
>> This unfortunately takes much time (much more than assembly and solve)
>> due to the second loop. I am aware of many posts/slides by PETSc authors
>> that mention that the non-zero structure can be found simply by looping
>> once through elements but what to do next is not quite clear.
>> I am also aware of this post by Barry [ http://lists.mcs.anl.gov/**
>> pipermail/petsc-users/2008-**May/003020.html<http://lists.mcs.anl.gov/pipermail/petsc-users/2008-May/003020.html>] but I cannot get it to work for a simple 4 element problem. Can some one
>> please expand on the strategy being suggested by Barry specially where the
>> loops are discussed (I understand the arrays and the vecscatter part). I am
>> also not sure how does using a t of 0.5 and 1 prevents double counting.
>> Shouldn't it be 0 and 1?
>> I am also aware of some capabilities in DMMESH but right now I dont
>> understand it well enough to utilize it.
> I agree with you here. Its not easy enough to use. However, I have
> rewritten the basics of it completely in C, which
> will all have easy Fortran bindings. You can specify your mesh with
> adjacency lists using Fortran arrays. The last part
> I am working on is matrix preallocation. I would not normally ask you to
> wait, but I think I am pretty close. Mail me
> directly if you want more info. I think it should only take me a few weeks
> to finish.
>   Thanks,
>      Matt
> Alternatively does PETSc support MATMPIAIJ of size=integer(1)/logical
>> instead of real(8) which I can use to put zeros/ones (when I loop over
>> elements the first time) to get the non-zero structure?
>> Thanks in advance.
>> Tabrez
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120127/ce1b5ba6/attachment.htm>
