[petsc-users] MatConvert behavior 3.1 vs 3.2
Dominik Szczerba dominik at itis.ethz.ch
Fri Jan 27 08:34:57 CST 2012
> On Fri, Jan 27, 2012 at 3:18 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> I have no idea how you are missing linking libm, but that's the problem.
> Because for some reason on the linking line there is
> -lm -lmetis
> while it should be
> -lmetis -lm
I was able to compile it by hand myself, and then replacing
--download-xxx with --with-xxx pointing to external packages. Clearly,
parmetis makefile, as pulled by --download-parmetis, has an issue.
Immediately one suggestion: it would be nice to pull and build the
external packages at option separately from the rest of petsc.
Dominik
