[petsc-users] [petsc-dev] does petsc filter out zeros in MatSetValues?
Thu Jan 26 23:20:11 CST 2012
On Thu, Jan 26, 2012 at 11:13 PM, Xuefei (Rebecca) Yuan <xyuan at lbl.gov>wrote:
> Here is another error message if running on local mac:
> *************petsc-Dev = yes*****************
> ******* start solving for time = 0.10000 at time step = 1******
>   0 SNES Function norm 2.452320964164e-02
> Matrix Object: 1 MPI processes
>   type: seqaij
>   rows=16384, cols=16384
>   total: nonzeros=831552, allocated nonzeros=1577536
>   total number of mallocs used during MatSetValues calls =0
>     using I-node routines: found 4096 nodes, limit used is 5
>   type: seqaij
>  Runtime parameters:
>    Objective type: Unknown!
>    Coarsening type: Unknown!
>    Initial partitioning type: Unknown!
>    Refinement type: Unknown!
>    Number of balancing constraints: 1
>    Number of refinement iterations: 1606408608
>    Random number seed: 1606408644
>    Number of separators: 48992256
>    Compress graph prior to ordering: Yes
>    Detect & order connected components separately: Yes
>    Prunning factor for high degree vertices: 0.100000
>    Allowed maximum load imbalance: 1.001
> Input Error: Incorrect objective type.
>  nbrpool statistics
>         nbrpoolsize:            0   nbrpoolcpos:            0
>     nbrpoolreallocs:            0
Can you run that through valgrind? It looks like it might be prior memory
corruption.
   Matt
> [0]PETSC ERROR:
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSCERROR: or try
> http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
> corruption errors
> [0]PETSC ERROR: likely location of problem given in stack below
> [0]PETSC ERROR: ---------------------  Stack Frames
> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> [0]PETSC ERROR:       INSTEAD the line number of the start of the function
> [0]PETSC ERROR:       is given.
> [0]PETSC ERROR: [0] MatLUFactorNumeric_SuperLU_DIST line 284
> /Users/xyuan/Software_macbook/petsc-dev/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c
> [0]PETSC ERROR: [0] MatLUFactorNumeric line 2871
> /Users/xyuan/Software_macbook/petsc-dev/src/mat/interface/matrix.c
> [0]PETSC ERROR: [0] PCSetUp_LU line 108
> /Users/xyuan/Software_macbook/petsc-dev/src/ksp/pc/impls/factor/lu/lu.c
> [0]PETSC ERROR: [0] PCSetUp line 810
> /Users/xyuan/Software_macbook/petsc-dev/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: [0] KSPSetUp line 184
> /Users/xyuan/Software_macbook/petsc-dev/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: [0] KSPSolve line 334
> [0]PETSC ERROR: [0] SNES_KSPSolve line 3874
> /Users/xyuan/Software_macbook/petsc-dev/src/snes/interface/snes.c
> [0]PETSC ERROR: [0] SNESSolve_LS line 593
> /Users/xyuan/Software_macbook/petsc-dev/src/snes/impls/ls/ls.c
> [0]PETSC ERROR: [0] SNESSolve line 3061
> [0]PETSC ERROR: [0] DMMGSolveSNES line 538
> /Users/xyuan/Software_macbook/petsc-dev/src/snes/utils/damgsnes.c
> [0]PETSC ERROR: [0] DMMGSolve line 303
> /Users/xyuan/Software_macbook/petsc-dev/src/snes/utils/damg.c
> [0]PETSC ERROR: [0] Solve line 374 twcartffxmhd.c
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Signal received!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Development HG revision:
> 905af3a7d7cdee7d0b744502bace1d74dc34b204  HG Date: Sun Jan 22 16:10:04 2012
> -0700
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: ./twcartffxmhd.exe on a arch-osx- named DOE6897708.local
> by xyuan Thu Jan 26 21:09:47 2012
> [0]PETSC ERROR: Libraries linked from
> /Users/xyuan/Software_macbook/petsc-dev/arch-osx-10.6-c-pkgs-opt-debug/lib
> [0]PETSC ERROR: Configure run at Mon Jan 23 10:21:17 2012
> [0]PETSC ERROR: Configure options --with-cc="gcc -m64" --with-fc="gfortran
> -m64" --with-cxx=g++ --with-debugging=1 -download-f-blas-lapack=1
> --download-mpich=1 --download-plapack=1 --download-parmetis=1
> --download-metis=1 --download-triangle=1 --download-spooles=1
> --download-superlu=1
> --download-superlu_dist=/Users/xyuan/Software_macbook/superlu_dist_3.0.tar.gz
> --download-blacs=1 --download-scalapack=1 --download-mumps=1
> --download-hdf5=1 --download-sundials=1 --download-prometheus=1
> --download-umfpack=1 --download-chaco=1 --download-spai=1
> --download-ptscotch=1 --download-pastix=1 --download-prometheus=1
> --download-cmake=1 PETSC_ARCH=arch-osx-10.6-c-pkgs-opt-debug
> [0]PETSC ERROR:
> [0]PETSC ERROR: User provided function() line 0 in unknown directory
> unknown file
> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
> [unset]: aborting job:
>  Runtime parameters:
>  nbrpool statistics
>     nbrpoolreallocs:            0
> [0]PETSC ERROR:
> corruption errors
> available,
> [0]PETSC ERROR:
> -0700
> [0]PETSC ERROR:
> [0]PETSC ERROR:
> unknown file
> R
> On Jan 26, 2012, at 9:05 PM, Xuefei (Rebecca) Yuan wrote:
> Hello Mark,
> Actually I have tried those options  for a sequential run where I need to
> use superlu to get the condition number of some matrix.
> In the dev version,
> ierr = DMCreateMatrix(DMMGGetDM(dmmg), MATAIJ, &jacobian);CHKERRQ(ierr);
> ierr = MatSetOption(jacobian, MAT_IGNORE_ZERO_ENTRIES,
> PETSC_TRUE);CHKERRQ(ierr);
> And in the options file,
> -dm_preallocate_only
> is added.
> This is totally fine when np=1, however, when I use multiple processors,
> there are some memory corruption happened.
> For example, the number of true nonzeros for 65536 size matrix is
> 1,470,802. the output (&) is for np=1 with the following PETSc related
> options:
> -snes_ksp_ew true
> -snes_monitor
> -snes_max_it 1
> -ksp_view
> -mat_view_info
> -ksp_type preonly
> -pc_type lu
> -pc_factor_mat_solver_package superlu
> -mat_superlu_conditionnumber
> -mat_superlu_printstat
> However, when np=2, the number of nonzeros changes to 3,366,976 with the
> following PETSc related options. (*) is the output file.
> -snes_ksp_ew true
> -snes_monitor
> -ksp_view
> -mat_view_info
> -ksp_type preonly
> -pc_type lu
> -pc_factor_mat_solver_package superlu_dist
> ******* start solving for time = 1.00000 at time step = 1******
>   0 SNES Function norm 1.242539468950e-02
>   type: seqaij
>   rows=65536, cols=65536
>   total: nonzeros=1470802, allocated nonzeros=2334720
>     not using I-node routines
>   Recip. condition number = 4.345658e-07
> MatLUFactorNumeric_SuperLU():
> Factor time  =    42.45
> Factor flops = 7.374620e+10     Mflops =  1737.25
> Solve time   =     0.00
> Number of memory expansions: 3
>   No of nonzeros in factor L = 32491856
>   No of nonzeros in factor U = 39390974
>   No of nonzeros in L+U = 71817294
>   L\U MB 741.397        total MB needed 756.339
>   type: seqaij
>   package used to perform factorization: superlu
>   total: nonzeros=0, allocated nonzeros=0
>     SuperLU run parameters:
>       Equil: NO
>       ColPerm: 3
>       IterRefine: 0
>       SymmetricMode: NO
>       DiagPivotThresh: 1
>       PivotGrowth: NO
>       ConditionNumber: YES
>       RowPerm: 0
>       ReplaceTinyPivot: NO
>       PrintStat: YES
>       lwork: 0
> MatSolve__SuperLU():
> Factor time  =    42.45
> Solve time   =     0.59
> Solve flops = 1.436365e+08      Mflops =   243.45
>  1 SNES Function norm 2.645145585949e-04
> Matrix Object: 2 MPI processes
>   type: mpiaij
>   total: nonzeros=3366976, allocated nonzeros=6431296
>       type: mpiaij
>       total: nonzeros=3366976, allocated nonzeros=3366976
>         using I-node (on process 0) routines: found 8192 nodes, limit used
> is 5
> At column 0, pivotL() encounters zero diagonal at line 708 in file
> symbfact.c
> symbfact.c
> Moreover, When I use valgrind with --leak-check=yes --track-origins=yes,
> there are 441 errors from 219 contexts in PetscInitialize() before calling
> SNESSolve(). Is this normal for dev?
> Thanks very much!
> Best regards,
> Rebecca
> On Jan 26, 2012, at 5:06 PM, Jed Brown wrote:
> On Thu, Jan 26, 2012 at 19:00, Mark F. Adams <mark.adams at columbia.edu>wrote:
>> I'm guessing that PETSc recently changed and now filters out 0.0 in
>> MatSetValues ... is this true?
> Did the option MAT_IGNORE_ZERO_ENTRIES get set somehow?
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120126/8a692b2f/attachment.htm>
