[petsc-users] CUDA with complex number
Paul Mullowney paulm at txcorp.com
Mon Jan 23 17:09:37 CST 2012
Yujie,
I'm developing GPU code for PETSc that will, at some point, support
complex numbers. However, I cannot give you a time frame as to when that
will be complete as I have several other tasks that are higher priority
right now.
-Paul
> Dear Barry,
> For complex number-based implementation, will the functions in Vec,
> Mat, KSP, and PC having been realized for real number work at least at
> the running level?
> Do I need to do more coding for them?
> To my knowledge, Victor Minden finished most of the coding work for
> GPU implementation in PETSc with your and Matt's help.
> However, it seems there is not people to further realize and optimize
> other GPU functions in PETSc.
> Do you think GPU-based computation is not important or has low
> efficiency compared to current CPU-based implementation in PETSc?
> Thank you very much,
> Yujie
> On Mon, Jan 23, 2012 at 3:46 PM, Barry Smith <bsmith at mcs.anl.gov
> <mailto:bsmith at mcs.anl.gov>> wrote:
>       Yujie,
>        As I said we have never tried it. You are welcome to try it
>     following the directions I gave. You must realize that we do not
>     have an army of people to support GPUs so you are largely on your
>     on in terms of getting things done and need to use your initiative
>     in trying things yourself and working through the problems that
>     may arise.
>       Barry
>     On Jan 23, 2012, at 3:36 PM, recrusader wrote:
>     > Dear Paul,
>     > Please find the changelog in the following link for CUSP 0.2.0
>     > http://code.google.com/p/cusp-library/source/browse/CHANGELOG
>     > They has added cusp:complex class to support complex
>     number-based operation.
>     > does it not work for PETSc?
>     > Thanks a lot,
>     > Yujie
>     > On Mon, Jan 23, 2012 at 3:28 PM, Paul Mullowney
>     <paulm at txcorp.com <mailto:paulm at txcorp.com>> wrote:
>     > I would claim that Petsc does not support GPU capabilities for
>     complex numbers right now.
>     > The CUSP library is templated over the scalar type (i.e. float
>     or double), however I don't think it supports complex numbers.
>     Although, I could be wrong on this.
>     > It could be somewhat straightforward to move from CUSP to
>     CUSPARSE (yes, these are different Nvidia libraries). I believe
>     CUSPARSE supports SpMV for complex types. It also supports
>     triangular solve for complex types.
>     > -Paul
>     >     This is an installation issue, please send all installation
>     issues to petsc-maint at mcs.anl.gov <mailto:petsc-maint at mcs.anl.gov>
>     with the entire configure.log
>     >    You can try editing config/PETSc/packages/cuda.py and
>     removing the two lines
>     >     if self.scalartypes.scalartype == 'complex':
>     >       raise RuntimeError('Must use real numbers with CUDA')
>     >    As it says we have never tested for complex so I do not know
>     how far it is from working.
>     >     Barry
>     > On Jan 23, 2012, at 1:24 PM, recrusader wrote:
>     > Dear PETSc Developers,
>     > I am compiling PETSc-dev using GPU in complex number mode.
>     > However, when I configure PETSc-dev, I get the following errors
>     >         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
>     > for details):
>     > Cannot use cuda with complex numbers it is not coded for this
>     capability
>     > I have checked CUSP. The latest version can support complex number.
>     > What should I do for CUDA?
>     > Thank you very much.
>     > Best,
>     > Yujie
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120123/12699092/attachment-0001.htm>
