[petsc-users] How to simplify the nonzero structure of the jacobian matrix.
Mon Jan 23 15:55:38 CST 2012
-dm_preallocate_only
http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/DM/DMSetMatrixPreallocateOnly.html
On Mon, Jan 23, 2012 at 15:52, Xuefei (Rebecca) Yuan <xyuan at lbl.gov> wrote:
> Hello all,
> There is one example that has used the
> ierr = MatSetOption(*B,MAT_IGNORE_ZERO_ENTRIES,PETSC_TRUE);CHKERRQ(ierr);
> in /src/mat/examples/tutorials/ex12.c,
> and this option works for this case because the matrix B is created via
> ierr = MatCreateSeqAIJ(PETSC_COMM_SELF,n+1,n+1,0,cnt,B);CHKERRQ(ierr);
> and the values are inserted by
> ierr = MatSetValues(*B,1,&i,aij->i[i+1] - aij->i[i],aij->j +
> aij->i[i],aij->a + aij->i[i],INSERT_VALUES);CHKERRQ(ierr);
> However, the option MAT_IGNORE_ZERO_ENTRIES does not work for the matrix
> if it is generated via
> ierr = DMCreateMatrix(DMMGGetDM(dmmg), MATAIJ, &jacobian);CHKERRQ(ierr);
> no matter if MatSetValues() or MatSetValuesStencil() is used.
> In the other word, if the matrix is generated based on the stencil
> information, the zero entries cannot be ignored even if the option is
> called before inserting/adding values.
> Is there anyway that can get rid of those zeros in the matrix generated
> based on the stencil information?
> Thanks very much!
> Best regards,
> Rebecca
> On Jan 20, 2012, at 5:23 PM, Matthew Knepley wrote:
> On Fri, Jan 20, 2012 at 7:07 PM, Xuefei (Rebecca) Yuan <xyuan at lbl.gov>wrote:
>> Here is the output:
>> On Jan 20, 2012, at 5:01 PM, Matthew Knepley wrote:
>> On Fri, Jan 20, 2012 at 6:55 PM, Xuefei (Rebecca) Yuan <xyuan at lbl.gov>wrote:
>>> Hello Matt,
>>> I tried several times for 3.1-p8 and dev version by putting MatSetOption
>> Are you sure your entries are exactly 0.0?
> Are you using ADD_VALUES?
> http://petsc.cs.iit.edu/petsc/petsc-dev/file/783e93230143/src/mat/impls/aij/seq/aij.c#l310
>     Matt
>>    Matt
>>> 1) right after creation of the matrix:
>>> #ifdef petscDev
>>> #else
>>>         ierr = DAGetMatrix(DMMGGetDA(dmmg), MATAIJ,
>>> #endif
>>>         ierr = MatSetOption(jacobian, MAT_IGNORE_ZERO_ENTRIES,
>>> 2) at the beginning of the FormJacobianLocal() routine:
>>>        PetscFunctionBegin;
>>> 3) before calling MatAssemblyBegin() in FormJacobianLocal() routine:
>>>         ierr = MatAssemblyBegin(jacobian,
>>> MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>>>         ierr = MatAssemblyEnd(jacobian,
>>> None of those works. What is wrong here?
>>> Thanks,
>>> R
>>> On Jan 20, 2012, at 4:32 PM, Matthew Knepley wrote:
>>> On Fri, Jan 20, 2012 at 6:28 PM, Xuefei (Rebecca) Yuan <xyuan at lbl.gov>wrote:
>>>> Hello Matt,
>>>> I have changed the code as
>>> You have to set it before you start setting values, so we know to ignore
>>> them.
>>>    Matt
>>>> but still get the same result as before, the matrix still has 5776
>>>> nonzeros:
>>>> % Size = 100 100
>>>>    2 % Nonzeros = 5776
>>>>    3 zzz = zeros(5776,3);
>>>> Then I switch the order as
>>>> nothing changed.
>>>> The version is 3.1-p8.
>>>> Thanks very much!
>>>> Best regards,
>>>> Rebecca
>>>> On Jan 20, 2012, at 4:09 PM, Matthew Knepley wrote:
>>>> On Fri, Jan 20, 2012 at 6:02 PM, Xuefei (Rebecca) Yuan <xyuan at lbl.gov>wrote:
>>>>> Hello all,
>>>>> This is a test for np=1 case of the nonzero structure of the jacobian
>>>>> matrix. The jacobian matrix is created via
>>>>> ierr =
>>>>> DMDACreate2d(comm,DMDA_BOUNDARY_NONE,DMDA_BOUNDARY_NONE,DMDA_STENCIL_BOX,
>>>>> parameters.mxfield, parameters.myfield, PETSC_DECIDE, PETSC_DECIDE, 4, 2,
>>>>> 0, 0, &da);CHKERRQ(ierr);
>>>>> After creation of the jacobian matrix,
>>>>>                PetscViewer viewer;
>>>>>                char fileName[120];
>>>>>                sprintf(fileName,
>>>>> "jacobian_after_creation.m");CHKERRQ(ierr);
>>>>>                FILE * fp;
>>>>>                ierr =
>>>>> PetscViewerASCIIOpen(PETSC_COMM_WORLD,fileName,&viewer);CHKERRQ(ierr);
>>>>>                ierr =
>>>>> PetscViewerSetFormat(viewer,PETSC_VIEWER_ASCII_MATLAB);CHKERRQ(ierr);
>>>>>                ierr = MatView (jacobian, viewer); CHKERRQ (ierr);
>>>>>                ierr = PetscFOpen(PETSC_COMM_WORLD,fileName,"a",&fp);
>>>>> CHKERRQ(ierr);
>>>>>                ierr =
>>>>> PetscViewerASCIIPrintf(viewer,"spy((spconvert(zzz)));\n");CHKERRQ(ierr);
>>>>>                ierr = PetscFClose(PETSC_COMM_WORLD,fp);CHKERRQ(ierr);
>>>>>                PetscViewerDestroy(&viewer);
>>>>> I took a look at the structure of the jacobian by storing it in the
>>>>> matlab format, the matrix has 5776 nonzeros entries, however, those values
>>>>> are all zeros at the moment as I have not insert or add any values into it
>>>>> yet, the structure shows: (the following figure shows a global replacement
>>>>> of 0.0 by 1.0 for those 5776 numbers)
>>>>> Inside the FormJacobianLocal() function, I have selected the index to
>>>>> pass to the nonzero values to jacobian, for example,
>>>>>  ierr = MatSetValuesStencil(jacobian, 1, &row, 6, col, v,
>>>>> where
>>>>>                    col[0].i = column[4].i;
>>>>>                    col[1].i = column[5].i;
>>>>>                    col[2].i = column[6].i;
>>>>>                    col[3].i = column[9].i;
>>>>>                    col[4].i = column[10].i;
>>>>>                    col[5].i = column[12].i;
>>>>>                    col[0].j = column[4].j;
>>>>>                    col[1].j = column[5].j;
>>>>>                    col[2].j = column[6].j;
>>>>>                    col[3].j = column[9].j;
>>>>>                    col[4].j = column[10].j;
>>>>>                    col[5].j = column[12].j;
>>>>>                    col[0].c = column[4].c;
>>>>>                    col[1].c = column[5].c;
>>>>>                    col[2].c = column[6].c;
>>>>>                    col[3].c = column[9].c;
>>>>>                    col[4].c = column[10].c;
>>>>>                    col[5].c = column[12].c;
>>>>>                    v[0] = value[4];
>>>>>                    v[1] = value[5];
>>>>>                    v[2] = value[6];
>>>>>                    v[3] = value[9];
>>>>>                    v[4] = value[10];
>>>>>                    v[5] = value[12];
>>>>> and did not pass the zero entries into the jacobian matrix. However,
>>>>>  after inserting or adding all values to the matrix, by the same routine
>>>>> above to take a look at the jacobian matrix in matlab format, the matrix
>>>>> still has 5776 nonzeros, in which 1075 numbers are nonzeros, and the other
>>>>> 4701 numbers are all zeros. The spy() gives
>>>>> for the true nonzero structures.
>>>>> But the ksp_view will give the nonzeros number as 5776, instead of
>>>>> 1075:
>>>>>  linear system matrix = precond matrix:
>>>>>  Matrix Object:  Mat_0x84000000_1   1 MPI processes
>>>>>    type: seqaij
>>>>>    rows=100, cols=100
>>>>>    total: nonzeros=5776, allocated nonzeros=5776
>>>>> It is a waste of memory to have all those values of zeros been stored
>>>>> in the jacobian.
>>>>> Is there anyway to get rid of those zero values in jacobian and has
>>>>> the only nonzero numbers stored in jacobian? In such a case, the ksp_view
>>>>> will tell that total:  nonzeros=1075.
>>>> MatSetOption(MAT_IGNORE_ZERO_ENTRIES, PETSC_TRUE);
>>>>    Matt
>>>>> Thanks very much!
>>>>> Have a nice weekend!
>>>>> Cheers,
>>>>> Rebecca
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120123/786b85f9/attachment.htm>
