[petsc-users] The matrix allocated by calling MatMPIAIJSetProallocation() was flushed out after calling DMMGSetSNESLocal()
Sat Jan 21 12:27:30 CST 2012
On Sat, Jan 21, 2012 at 12:19 PM, Xuefei (Rebecca) Yuan <xyuan at lbl.gov>wrote:
> Hello,
> After I was not able to get rid of the zeros in the matrix by
> ierr = MatSetOption(jacobian, MAT_IGNORE_ZERO_ENTRIES,
>>> PETSC_TRUE);CHKERRQ(ierr);
> I would like to create the matrix by the following routine:
>  ierr = MatCreate(PETSC_COMM_WORLD, &jacobian);CHKERRQ(ierr);
> ierr = MatSetType(jacobian, MATMPIAIJ);CHKERRQ(ierr);
> ierr = MatSetSizes(jacobian, PETSC_DECIDE, PETSC_DECIDE, (PetscInt)(
> info.mx*info.my*4), (PetscInt)(info.mx*info.my*4));CHKERRQ(ierr);
> ierr = MatMPIAIJSetPreallocation(jacobian, 11, PETSC_NULL, 18,
> PETSC_NULL);CHKERRQ(ierr);
> instead of using
> ierr = DMGetMatrix(DMMGGetDM(dmmg), MATAIJ, &jacobian);CHKERRQ(ierr);
> to save the memory. However, I found that the routine DMGetMatrix() was
> still called inside DMMGSetSNESLocal(), therefore, the matrix I created was
> useless:
What exactly are you getting out of using the DM? If it does not express
the pattern of your problem, why use it?
  Matt
> Breakpoint 2, main (argc=3, argv=0x7fff5fbff770) at twcartffxmhd.c:255
> 255 ierr = MatCreate(PETSC_COMM_WORLD, &jacobian);CHKERRQ(ierr);
> (gdb) n
> 256 ierr = MatSetType(jacobian, MATMPIAIJ);CHKERRQ(ierr);
> (gdb)
> 257 ierr = MatSetSizes(jacobian, PETSC_DECIDE, PETSC_DECIDE, (PetscInt)(
> (gdb)
> 258 ierr = MatMPIAIJSetPreallocation(jacobian, 11, PETSC_NULL, 18,
> (gdb)
> Breakpoint 3, main (argc=3, argv=0x7fff5fbff770) at twcartffxmhd.c:260
> 260 ierr = DMMGSetSNESLocal(dmmg, FormFunctionLocal,
> FormJacobianLocal,0,0);CHKERRQ(ierr);
> (gdb) s
> DMMGSetSNESLocal_Private (dmmg=0x102004480, function=0x100016ba9
> <FormFunctionLocal>, jacobian=0x100050e83 <FormJacobianLocal>,
> ad_function=0, admf_function=0) at damgsnes.c:932
> 932  PetscInt       i,nlevels = dmmg[0]->nlevels;
> (gdb) n
> 934  PetscErrorCode
> (*computejacobian)(SNES,Vec,Mat*,Mat*,MatStructure*,void*) = 0;
> (gdb) s
> 937  PetscFunctionBegin;
> (gdb) n
> 938  if (jacobian)         computejacobian = DMMGComputeJacobian;
> (gdb)
> 942  CHKMEMQ;
> (gdb)
> 943  ierr = PetscObjectGetCookie((PetscObject)
> dmmg[0]->dm,&cookie);CHKERRQ(ierr);
> (gdb)
> 944  if (cookie == DM_COOKIE) {
> (gdb)
> 948    ierr = PetscOptionsHasName(PETSC_NULL,
> "-dmmg_form_function_ghost", &flag);CHKERRQ(ierr);
> (gdb)
> 949    if (flag) {
> (gdb)
> 952      ierr =
> DMMGSetSNES(dmmg,DMMGFormFunction,computejacobian);CHKERRQ(ierr);
> (gdb)
> Matrix Object:
>   type=seqaij, rows=100, cols=100
>   total: nonzeros=5776, allocated nonzeros=5776
>     using I-node routines: found 25 nodes, limit used is 5
> 954    for (i=0; i<nlevels; i++) {
> (gdb) b twcartffxmhd.c:280
> Breakpoint 4 at 0x100004032: file twcartffxmhd.c, line 282.
> (gdb) c
> Continuing.
> Matrix Object:
>   type=mpiaij, rows=100, cols=100
>   total: nonzeros=0, allocated nonzeros=2900
>     using I-node (on process 0) routines: found 20 nodes, limit used is 5
> The final matrix after FormJacobianlLocal() call still have 5776 nonzeros:
> % Size = 100 100
>    2 % Nonzeros = 5776
>    3 zzz = zeros(5776,3);
> Is there a way that I can pass the matrix created via line 255-258 to
> FormJacobianLocal()?
> Thanks very much!
> Cheers,
> Rebecca
> On Jan 20, 2012, at 5:23 PM, Matthew Knepley wrote:
> On Fri, Jan 20, 2012 at 7:07 PM, Xuefei (Rebecca) Yuan <xyuan at lbl.gov>wrote:
>> Here is the output:
>> On Jan 20, 2012, at 5:01 PM, Matthew Knepley wrote:
>> On Fri, Jan 20, 2012 at 6:55 PM, Xuefei (Rebecca) Yuan <xyuan at lbl.gov>wrote:
>>> Hello Matt,
>>> I tried several times for 3.1-p8 and dev version by putting MatSetOption
>> Are you sure your entries are exactly 0.0?
> Are you using ADD_VALUES?
> http://petsc.cs.iit.edu/petsc/petsc-dev/file/783e93230143/src/mat/impls/aij/seq/aij.c#l310
>     Matt
>>    Matt
>>> 1) right after creation of the matrix:
>>> #ifdef petscDev
>>>         ierr = DMCreateMatrix(DMMGGetDM(dmmg), MATAIJ,
>>> #else
>>>         ierr = DAGetMatrix(DMMGGetDA(dmmg), MATAIJ,
>>> #endif
>>> 2) at the beginning of the FormJacobianLocal() routine:
>>>        PetscFunctionBegin;
>>> 3) before calling MatAssemblyBegin() in FormJacobianLocal() routine:
>>>         ierr = MatAssemblyBegin(jacobian,
>>> MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>>>         ierr = MatAssemblyEnd(jacobian,
>>> None of those works. What is wrong here?
>>> Thanks,
>>> R
>>> On Jan 20, 2012, at 4:32 PM, Matthew Knepley wrote:
>>> On Fri, Jan 20, 2012 at 6:28 PM, Xuefei (Rebecca) Yuan <xyuan at lbl.gov>wrote:
>>>> Hello Matt,
>>>> I have changed the code as
>>> You have to set it before you start setting values, so we know to ignore
>>> them.
>>>    Matt
>>>> but still get the same result as before, the matrix still has 5776
>>>> nonzeros:
>>>> % Size = 100 100
>>>>    2 % Nonzeros = 5776
>>>> Then I switch the order as
>>>> nothing changed.
>>>> The version is 3.1-p8.
>>>> Thanks very much!
>>>> Best regards,
>>>> Rebecca
>>>> On Jan 20, 2012, at 4:09 PM, Matthew Knepley wrote:
>>>> On Fri, Jan 20, 2012 at 6:02 PM, Xuefei (Rebecca) Yuan <xyuan at lbl.gov>wrote:
>>>>> Hello all,
>>>>> This is a test for np=1 case of the nonzero structure of the jacobian
>>>>> matrix. The jacobian matrix is created via
>>>>> ierr =
>>>>> DMDACreate2d(comm,DMDA_BOUNDARY_NONE,DMDA_BOUNDARY_NONE,DMDA_STENCIL_BOX,
>>>>> parameters.mxfield, parameters.myfield, PETSC_DECIDE, PETSC_DECIDE, 4, 2,
>>>>> 0, 0, &da);CHKERRQ(ierr);
>>>>> After creation of the jacobian matrix,
>>>>>                PetscViewer viewer;
>>>>>                char fileName[120];
>>>>>                sprintf(fileName,
>>>>> "jacobian_after_creation.m");CHKERRQ(ierr);
>>>>>                FILE * fp;
>>>>>                ierr =
>>>>> PetscViewerASCIIOpen(PETSC_COMM_WORLD,fileName,&viewer);CHKERRQ(ierr);
>>>>>                ierr =
>>>>> PetscViewerSetFormat(viewer,PETSC_VIEWER_ASCII_MATLAB);CHKERRQ(ierr);
>>>>>                ierr = MatView (jacobian, viewer); CHKERRQ (ierr);
>>>>>                ierr = PetscFOpen(PETSC_COMM_WORLD,fileName,"a",&fp);
>>>>> CHKERRQ(ierr);
>>>>>                ierr =
>>>>> PetscViewerASCIIPrintf(viewer,"spy((spconvert(zzz)));\n");CHKERRQ(ierr);
>>>>>                ierr = PetscFClose(PETSC_COMM_WORLD,fp);CHKERRQ(ierr);
>>>>>                PetscViewerDestroy(&viewer);
>>>>> I took a look at the structure of the jacobian by storing it in the
>>>>> matlab format, the matrix has 5776 nonzeros entries, however, those values
>>>>> are all zeros at the moment as I have not insert or add any values into it
>>>>> yet, the structure shows: (the following figure shows a global replacement
>>>>> of 0.0 by 1.0 for those 5776 numbers)
>>>>> Inside the FormJacobianLocal() function, I have selected the index to
>>>>> pass to the nonzero values to jacobian, for example,
>>>>>  ierr = MatSetValuesStencil(jacobian, 1, &row, 6, col, v,
>>>>> INSERT_VALUES);CHKERRQ(ierr);
>>>>> where
>>>>>                    col[0].i = column[4].i;
>>>>>                    col[1].i = column[5].i;
>>>>>                    col[2].i = column[6].i;
>>>>>                    col[3].i = column[9].i;
>>>>>                    col[4].i = column[10].i;
>>>>>                    col[5].i = column[12].i;
>>>>>                    col[0].j = column[4].j;
>>>>>                    col[1].j = column[5].j;
>>>>>                    col[2].j = column[6].j;
>>>>>                    col[3].j = column[9].j;
>>>>>                    col[4].j = column[10].j;
>>>>>                    col[5].j = column[12].j;
>>>>>                    col[0].c = column[4].c;
>>>>>                    col[1].c = column[5].c;
>>>>>                    col[2].c = column[6].c;
>>>>>                    col[3].c = column[9].c;
>>>>>                    col[4].c = column[10].c;
>>>>>                    col[5].c = column[12].c;
>>>>>                    v[0] = value[4];
>>>>>                    v[1] = value[5];
>>>>>                    v[2] = value[6];
>>>>>                    v[3] = value[9];
>>>>>                    v[4] = value[10];
>>>>>                    v[5] = value[12];
>>>>> and did not pass the zero entries into the jacobian matrix. However,
>>>>>  after inserting or adding all values to the matrix, by the same routine
>>>>> above to take a look at the jacobian matrix in matlab format, the matrix
>>>>> still has 5776 nonzeros, in which 1075 numbers are nonzeros, and the other
>>>>> 4701 numbers are all zeros. The spy() gives
>>>>> for the true nonzero structures.
>>>>> But the ksp_view will give the nonzeros number as 5776, instead of
>>>>> 1075:
>>>>>  linear system matrix = precond matrix:
>>>>>  Matrix Object:  Mat_0x84000000_1   1 MPI processes
>>>>>    type: seqaij
>>>>>    rows=100, cols=100
>>>>> It is a waste of memory to have all those values of zeros been stored
>>>>> in the jacobian.
>>>>> Is there anyway to get rid of those zero values in jacobian and has
>>>>> the only nonzero numbers stored in jacobian? In such a case, the ksp_view
>>>>> will tell that total:  nonzeros=1075.
>>>> MatSetOption(MAT_IGNORE_ZERO_ENTRIES, PETSC_TRUE);
>>>>    Matt
>>>>> Thanks very much!
>>>>> Have a nice weekend!
>>>>> Cheers,
>>>>> Rebecca
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120121/491d9476/attachment-0001.htm>
