[petsc-users] How to simplify the nonzero structure of the jacobian matrix.
Fri Jan 20 19:23:43 CST 2012
On Fri, Jan 20, 2012 at 7:07 PM, Xuefei (Rebecca) Yuan <xyuan at lbl.gov>wrote:
> Here is the output:
> On Jan 20, 2012, at 5:01 PM, Matthew Knepley wrote:
> On Fri, Jan 20, 2012 at 6:55 PM, Xuefei (Rebecca) Yuan <xyuan at lbl.gov>wrote:
>> Hello Matt,
>> I tried several times for 3.1-p8 and dev version by putting MatSetOption
> Are you sure your entries are exactly 0.0?
Are you using ADD_VALUES?
http://petsc.cs.iit.edu/petsc/petsc-dev/file/783e93230143/src/mat/impls/aij/seq/aij.c#l310
    Matt
>    Matt
>> 1) right after creation of the matrix:
>> #ifdef petscDev
>>         ierr = DMCreateMatrix(DMMGGetDM(dmmg), MATAIJ,
>> &jacobian);CHKERRQ(ierr);
>> #else
>>         ierr = DAGetMatrix(DMMGGetDA(dmmg), MATAIJ,
>> #endif
>>         ierr = MatSetOption(jacobian, MAT_IGNORE_ZERO_ENTRIES,
>> PETSC_TRUE);CHKERRQ(ierr);
>> 2) at the beginning of the FormJacobianLocal() routine:
>>        PetscFunctionBegin;
>> 3) before calling MatAssemblyBegin() in FormJacobianLocal() routine:
>>         ierr = MatAssemblyBegin(jacobian,
>> MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>>         ierr = MatAssemblyEnd(jacobian, MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>> None of those works. What is wrong here?
>> Thanks,
>> R
>> On Jan 20, 2012, at 4:32 PM, Matthew Knepley wrote:
>> On Fri, Jan 20, 2012 at 6:28 PM, Xuefei (Rebecca) Yuan <xyuan at lbl.gov>wrote:
>>> Hello Matt,
>>> I have changed the code as
>> You have to set it before you start setting values, so we know to ignore
>> them.
>>    Matt
>>> but still get the same result as before, the matrix still has 5776
>>> nonzeros:
>>> % Size = 100 100
>>>    2 % Nonzeros = 5776
>>>    3 zzz = zeros(5776,3);
>>> Then I switch the order as
>>> nothing changed.
>>> The version is 3.1-p8.
>>> Thanks very much!
>>> Best regards,
>>> Rebecca
>>> On Jan 20, 2012, at 4:09 PM, Matthew Knepley wrote:
>>> On Fri, Jan 20, 2012 at 6:02 PM, Xuefei (Rebecca) Yuan <xyuan at lbl.gov>wrote:
>>>> Hello all,
>>>> This is a test for np=1 case of the nonzero structure of the jacobian
>>>> matrix. The jacobian matrix is created via
>>>> ierr =
>>>> DMDACreate2d(comm,DMDA_BOUNDARY_NONE,DMDA_BOUNDARY_NONE,DMDA_STENCIL_BOX,
>>>> parameters.mxfield, parameters.myfield, PETSC_DECIDE, PETSC_DECIDE, 4, 2,
>>>> 0, 0, &da);CHKERRQ(ierr);
>>>> ierr = DMCreateMatrix(DMMGGetDM(dmmg), MATAIJ, &jacobian);CHKERRQ(ierr);
>>>> After creation of the jacobian matrix,
>>>>                PetscViewer viewer;
>>>>                char fileName[120];
>>>>                sprintf(fileName,
>>>> "jacobian_after_creation.m");CHKERRQ(ierr);
>>>>                FILE * fp;
>>>>                ierr =
>>>> PetscViewerASCIIOpen(PETSC_COMM_WORLD,fileName,&viewer);CHKERRQ(ierr);
>>>>                ierr =
>>>> PetscViewerSetFormat(viewer,PETSC_VIEWER_ASCII_MATLAB);CHKERRQ(ierr);
>>>>                ierr = MatView (jacobian, viewer); CHKERRQ (ierr);
>>>>                ierr = PetscFOpen(PETSC_COMM_WORLD,fileName,"a",&fp);
>>>> CHKERRQ(ierr);
>>>>                ierr =
>>>> PetscViewerASCIIPrintf(viewer,"spy((spconvert(zzz)));\n");CHKERRQ(ierr);
>>>>                ierr = PetscFClose(PETSC_COMM_WORLD,fp);CHKERRQ(ierr);
>>>>                PetscViewerDestroy(&viewer);
>>>> I took a look at the structure of the jacobian by storing it in the
>>>> matlab format, the matrix has 5776 nonzeros entries, however, those values
>>>> are all zeros at the moment as I have not insert or add any values into it
>>>> yet, the structure shows: (the following figure shows a global replacement
>>>> of 0.0 by 1.0 for those 5776 numbers)
>>>> Inside the FormJacobianLocal() function, I have selected the index to
>>>> pass to the nonzero values to jacobian, for example,
>>>>  ierr = MatSetValuesStencil(jacobian, 1, &row, 6, col, v,
>>>> INSERT_VALUES);CHKERRQ(ierr);
>>>> where
>>>>                    col[0].i = column[4].i;
>>>>                    col[1].i = column[5].i;
>>>>                    col[2].i = column[6].i;
>>>>                    col[3].i = column[9].i;
>>>>                    col[4].i = column[10].i;
>>>>                    col[5].i = column[12].i;
>>>>                    col[0].j = column[4].j;
>>>>                    col[1].j = column[5].j;
>>>>                    col[2].j = column[6].j;
>>>>                    col[3].j = column[9].j;
>>>>                    col[4].j = column[10].j;
>>>>                    col[5].j = column[12].j;
>>>>                    col[0].c = column[4].c;
>>>>                    col[1].c = column[5].c;
>>>>                    col[2].c = column[6].c;
>>>>                    col[3].c = column[9].c;
>>>>                    col[4].c = column[10].c;
>>>>                    col[5].c = column[12].c;
>>>>                    v[0] = value[4];
>>>>                    v[1] = value[5];
>>>>                    v[2] = value[6];
>>>>                    v[3] = value[9];
>>>>                    v[4] = value[10];
>>>>                    v[5] = value[12];
>>>> and did not pass the zero entries into the jacobian matrix. However,
>>>>  after inserting or adding all values to the matrix, by the same routine
>>>> above to take a look at the jacobian matrix in matlab format, the matrix
>>>> still has 5776 nonzeros, in which 1075 numbers are nonzeros, and the other
>>>> 4701 numbers are all zeros. The spy() gives
>>>> for the true nonzero structures.
>>>> But the ksp_view will give the nonzeros number as 5776, instead of 1075:
>>>>  linear system matrix = precond matrix:
>>>>  Matrix Object:  Mat_0x84000000_1   1 MPI processes
>>>>    type: seqaij
>>>>    rows=100, cols=100
>>>>    total: nonzeros=5776, allocated nonzeros=5776
>>>> It is a waste of memory to have all those values of zeros been stored
>>>> in the jacobian.
>>>> Is there anyway to get rid of those zero values in jacobian and has the
>>>> only nonzero numbers stored in jacobian? In such a case, the ksp_view will
>>>> tell that total:  nonzeros=1075.
>>> MatSetOption(MAT_IGNORE_ZERO_ENTRIES, PETSC_TRUE);
>>>    Matt
>>>> Thanks very much!
>>>> Have a nice weekend!
>>>> Cheers,
>>>> Rebecca
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120120/61e4f2e2/attachment.htm>
