[petsc-users] hdf5 and FILE_MODE_APPEND
Fri Jan 20 15:27:25 CST 2012
On Fri, Jan 20, 2012 at 3:22 PM, Mohamad M. Nasr-Azadani
<mmnasr at gmail.com>wrote:
> Thanks Matt,
> So, this cannot be done this way, i.e. generate an hdf5 file at one
> instance and write a field data, close it then add another field data at
> later instance to the same file?
Can't you just open up the file and write something with a different name?
   Matt
> On Fri, Jan 20, 2012 at 1:19 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Fri, Jan 20, 2012 at 3:15 PM, Mohamad M. Nasr-Azadani <
>> mmnasr at gmail.com> wrote:
>>> Hi guys,
>>> Does *PetscViewerHDF5Open()*work with *FILE_MODE_APPEND*?
>> No, but HDF5 does not work like that.
>>   Matt
>>> This is the error I get when I first open the file, write some data to
>>> it using VecView(), close it and then again reopen (with append mode) it to
>>> add data to the end of it.
>>> [0]PETSC ERROR: Operation done in wrong order!
>>> [0]PETSC ERROR: Must call PetscViewerFileSetMode() before
>>> PetscViewerFileSetName()!
>>> Thanks,
>>> Mohamad
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120120/e91bf602/attachment.htm>
