[petsc-users] SNESSetUpdate function
Fri Jan 20 08:55:53 CST 2012
On Fri, Jan 20, 2012 at 08:28, Bernardo Rocha <
bernardomartinsrocha at gmail.com> wrote:
> I'm using SNES but I would like to update my data after each successful
> step computation within the nonlinear solver using a different function. I
> mean, after the solution of each linear system I would like to get \Delta
> x_k to update x_{k+1} which is stored somewhere in my application class
> (C++ code).
Can you explain more about what you are trying to do? What you describe
does not sound algorithmically correct.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120120/bd66f817/attachment.htm>
